Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Henry on September 12, 2005, 10:27 am
I wonder if anyone can give a definitive answer as to why there is a minimum spacing specified on (some) ethernet cable. The thick stuff with markers every 2.5m for example which is 1 bit of delay at 10 MHz. There is some mention of it on various web sites but the reasons for it are not stated. Maximum lengths etc are simple enough to understand: you need to be sure that collisions are not late. The only reason I can think of for specifying a minimum distance is to maximise the effect of a collision when two MAUs start transmitting at the same time. Only I can't see that it would. They won't actually start together. If they're waiting for the line to become free, the last data going past them will make sure one starts after the other. So the second will start up at the eaxct moment the first's one's data arrives. So it will experience a zero time-difference collision. The first one will have a two bit difference. Even if there's an advantage in that - which I don't understand -it assumes exactly one 2.5m section of cable. But the 2.5m is only a minimum: the spec doesn't require exact multiplesof 2.5m over hundreds of metres! So I'm racking my brains as to why it was ever specified at all. | ||
Posted by William P. N. Smith on September 12, 2005, 6:06 am
Please log in for more thread options impedance discontinuities caused by taps far enough apart that they don't reinforce each other. news is your friend. | ||
Posted by Henry on September 12, 2005, 12:33 pm
Please log in for more thread options William P. N. Smith <> said Oops, just realized there's a factor of 10 missing there. My attempted guess at the reasoning was wrong... The mystery deepens. Thanks. I've found some stuff from Rich Seifert going back to 1980-something which explains it, sort of, though it's a bit woolly - not Rich's explanation but the thinking behind it. | ||
Posted by Rich Seifert on September 12, 2005, 8:05 am
Please log in for more thread options As you realized, one bit-time at 10 Mb/s is 100 ns, which corresponds to 23.5 m of coaxial cable. The basic problem is that transceiver taps appear to the transmission line as discrete, lumped capacitive loads; the specification mandates a maximum of 4 pf, but this is still significant. When the signal encounters this capacitance, it creates an out-of-phase reflection of a portion of the energy. To all other devices on the cable, this reflection appears as asynchronous "noise," i.e., a signal that interferes with the desired signal. The situation to be avoided is where all of the transceiver taps are spaced such that the reflections from each of them add up in phase, thus combining *algebraically* (i.e., simple summation). The small reflection from 99 transceivers added up could create enough interference to cause bit errors. Ideally, one would want the transceivers to be *randomly* spaced along the cable; this would ensure that the reflections added not algebraically, but on a root-mean-squared basis, yielding much less reflected energy. In fact, my original proposal was to do exactly that; I even had a patent application prepared for a method of manufacturing cables with randomly-distributed markings for this purpose! As it turns out, random markings were neither practical (installers didn't like the idea, and neither did the cable manufacturers) nor necessary. I did extensive simulations of the resulting reflections from transceivers at various spacings, and empirically determined that 2.5 m was "good enough." It was relatively easy to mark the cables with a uniform 2.5 m marking; as the cable comes flying out of the extruder, it passes across a roller with a 2.5 m circumference, which places a mark at every rotation. The idea is not just a *minimum* 2.5 m spacing; it is that transceivers are only placed at the 2.5 m markings. However, as another poster noted, it's not all that critical; if a few transceivers are offset, or even lumped together, it is unlikely to cause a noticeable problem. I was just trying to design for the worst-case, figuring that it would surely show up *somewhere*, and that one installer would have no idea what the problem was. By the way, that cable-spacing work, along with the work that defined the proper lengths to use for concatenating short coaxial cables into long runs, constituted a major part of my EE master's thesis some 25 years ago. -- Rich Seifert Networks and Communications Consulting 21885 Bear Creek Way (408) 395-5700 Los Gatos, CA 95033 (408) 228-0803 FAX Send replies to: usenet at richseifert dot com | ||
Posted by glen herrmannsfeldt on September 12, 2005, 3:25 pm
Please log in for more thread options Rich Seifert wrote: (snip) I am not sure how accurate the velocity factor is, but... Constructive interference would result from a half wavelength spacing, so 11.75m. A 500m cable could have 43 taps with that spacing, which could be significant. If you put 44 taps equally distributed over the same distance they will pretty much cancel each other out. If you put 43 taps spaced at 11.75m and the velocity factor is off by 2% they also pretty much cancel out. The first odd multiple of 11.75m that is close to a multiple of 2.5m seems to be 82.25m. It seems to me very unlikely that, unless someone intentionally spaced them at 11.75m that they would cause problems, but it is nice to have a rule with a known effect. -- glen | ||
| Similar Threads | Posted |
| Why is there a minimum spacing? | September 12, 2005, 10:27 am |
| WiMAX for the Minimum | August 17, 2006, 5:41 am |
| About the minimum Eth. frame length determination | October 30, 2007, 6:19 am |
| why ethernet paload minimum size is 46 bytes? | March 29, 2007, 7:55 am |
| 120 Hosts Running GigE at Wire Speed Minimum Cost | February 26, 2005, 2:07 am |
| Latest Posts | Forum | RSS |
| NEWS: Samsung takes on the Apple iPad with the 7 inch Galaxy... | Wireless Networking | |
| c3560 port configuration | Cisco Systems | |
| Broadband 2010: A Big Slowdown [telecom] | General Telecommunications Forum | |
| Control Hot Water Circ Pump With X10? | General Home Automation | |
| Official Course CCNP TSHOOT 642-832 / Foundation Learning Gu... | Cisco Certification | |
| Speedflow Communications Honored for Innovation | Voice-Over-IP | |
| USB _to_ RJ45 (not from) connection | Ethernet LAN | |
| FAQ: Maximizing cable modem or DSL speed | Cable Modems | |
| CASH FOR CISCO - I BUY USED AND NEW EQUIPMENT & LOTS MOR... | Telecom Technical | |
| FAQ: Maximizing cable modem or DSL speed | Digital Subscriber Line | |
| How to set up Meridian 1 to "provide clock" to a C... | Nortel Networks | |
| New Discovery about WDM | LAN and Telecom Cabling | |
| Control Hot Water Circ Pump With X10? | Home Automation | |
| Text file to automate restoring a dropped VPN connection. | Virtual Private Networks | |
| Home Theater Installation | Home Theater | |
| Re: The Turkic Languages in a Nutshell | Fiber Optics | |
| sip | Video Conferencing |
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language! Click Here to learn more |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
