Ethernet LAN What is JUMBO frame?
Subject Author Date
What is JUMBO frame? zatheesh2k7@gmail.com 12-28-08
Posted by zatheesh2k7@gmail.com on December 28, 2008, 11:34 am
What is actually a JUMBO frame? Does it standardised? How a L2 switch
accept JUMBO frame, when an ethernet frame size (maximum) can never
exceed 1522 as per IEEE 802.Q ?
Posted by Albert Manfredi on December 28, 2008, 4:50 pm
That's because jumbo frames are not standard.
However, if you use the "type" format, there's no reason in principle
why the frame size can't grow beyond 1522 bytes. Of course, all
switches in the path must be aware of the possibility of these jumbo
frames.
Bert
Posted by PranavT on January 3, 2009, 1:00 am
Jumbo frames are Ethernet frames with more than 1,500 bytes of
payload. Conventionally, jumbo frames can carry up to 9,000 bytes of
payload. Why 9000? because ethernet uses a 32 bit CRC that loses its
effectiveness above about 12000 bytes.
Many Gigabit Ethernet switches and Gigabit Ethernet network interface
cards support jumbo frames. You can partition a logical network in
which systems can exchange Jumbo Frames and mark them with IEEE 802.1Q
virtual LAN tags. The extended frames will be transparent to the rest
of the network.
Adapters that implement IEEE 802.1Q can support different Ethernet
frame sizes for different logical network interfaces. For example, a
server could communicate with another server using Jumbo Frames while
communicating with clients sitting on another VLAN or IP subnet using
standard Ethernet frames - all via the same physical connection.
pranav tailor
Posted by Rick Jones on January 6, 2009, 4:42 pm
> switch accept JUMBO frame, when an ethernet frame size (maximum) can
> never exceed 1522 as per IEEE 802.Q ?
There is no "de jure" standard for the size of a "jumbo frame" as the
IEEE has not seen fit to create one. One can argue though that the
"de facto" standard for the jumbo frame is such that it results in an
IPv4 MTU of 9000 bytes or more based on that being what Alteon used in
their GbE NICs which IIRC were among if not the first to have a "jumbo
frame" in the Ethernet space.
rick jones
(At least they were the first place I can recall seeing jumbo frames
in an Ethernet interface)
firebug n, the idiot who tosses a lit cigarette out his car window
these opinions are mine, all mine; HP might not want them anyway... :)
feel free to post, OR email to rick.jones2 in hp.com but NOT BOTH...
Posted by Stephen on January 7, 2009, 7:11 pm
On Tue, 6 Jan 2009 21:42:42 +0000 (UTC), Rick Jones
Agreed, although i have seen "jumbo" on 100 Mbps as well, although
cannot remember where, and it has spread to 10G as well.
A Cisco Cat 6500 could even have more than 1 different jumbo limits,
just on different blades if you had various vintages of equipment.
and the telecomms suppliers do not agree about 9000 bytes:
- some Marconi SDH kit calls 4000+ bytes "jumbo".
- and DWDM kit often works happily at 64 Kbytes since they dont even
worry about packet boundaries.
and then there is "baby jumbo" which is more than standard 1514 /
1518, but usually less than 1600 or 2000 bytes.......
>rick jones
Regards
stephen_hope@xyzworld.com - replace xyz with ntl
Similar ThreadsPosted
What is JUMBO frame? December 28, 2008, 11:34 am
Netgear switch and jumbo frame support ? April 8, 2005, 1:47 pm
802.1q frame with tag November 28, 2004, 8:38 am
under sized frame February 2, 2007, 9:37 am
Use of ethernet frame without TCP/IP March 17, 2008, 5:48 am
Jumbo frames? September 28, 2004, 8:18 pm
IEEE 802.3 PAUSE frame January 5, 2005, 6:24 pm
Ethernet Frame size January 17, 2005, 8:01 pm
Pause Frame transmission May 19, 2006, 7:05 pm
Strange ethrenet frame October 4, 2006, 10:54 am
concerns about jumbo frames November 22, 2004, 12:30 am
Jumbo Ethernet Frames November 8, 2005, 12:44 pm
Jumbo frames practicalities? December 16, 2005, 6:56 pm
Another jumbo frames question March 20, 2007, 2:15 pm
Maximum size of Ethernet frame November 11, 2004, 9:40 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
