Ethernet LAN VLAN unaware bridge
Subject Author Date
VLAN unaware bridge Kamaraj 05-05-08
---> Re: VLAN unaware bridge glen herrmannsf...05-05-08
Posted by Kamaraj on May 5, 2008, 1:56 am
Hello,
Would like to know whehter L2switch is not VLAN aware bridge will
forward VLAN tagged packets to VLAN unaware hosts.
How L2Bridge will act if its receives VLAN tagged packets.
Thanks in Advance.
-Kamaraj
Posted by glen herrmannsfeldt on May 5, 2008, 4:32 am
As I understand it, there is some possibility that full length
packets, which are four bytes longer than the standard, will be
discarded. I haven't heard that any do that, though.
Pass them through in the same way as any other packet.
-- glen
Posted by Kamaraj on May 5, 2008, 4:36 am
> discarded. =A0I haven't heard that any do that, though.
> -- glen
How it will work if the end station is a host not an L2Bridge device.
I mean the end station also VLAN unaware device.
Thanks In Advance
Posted by Arnold Nipper on May 5, 2008, 6:10 am
>> -- glen
It works the same way. Though why would you want to connect a vlan
unaware device to a 802.1q/tagged port?
Arnold Nipper
Arnold
Posted by glen herrmannsfeldt on May 5, 2008, 2:40 pm
Kamaraj wrote:
(snip)
(snip)
You have to consider VLAN as part of the network design,
and not connect VLAN unaware devices to ports with VLAN
tags on them destined for that device.
Though these days, there is likely VLAN software for most
operating systems.
-- glen
Similar ThreadsPosted
VLAN unaware bridge May 5, 2008, 1:56 am
802.11 to 802.15.4 bridge March 20, 2005, 8:10 pm
What would be a non-transparent bridge? December 15, 2004, 10:44 am
Good wireless bridge? April 29, 2005, 5:52 pm
"Wireless Ethernet Bridge" and security ? April 9, 2005, 9:31 pm
FDDI to Fast Ethernet "Bridge" Available? October 1, 2008, 11:38 pm
FDDI to Fast Ethernet "Bridge"? October 1, 2008, 11:42 pm
Does someone have IGMP snooping source code for Bridge?? May 30, 2006, 9:06 am
Difference between bridge and wireless access point?? October 9, 2007, 6:57 pm
difference between Repeater,hub,bridge, switch,router, gateway November 26, 2008, 5:01 am
How to findout which a device (switch/hub/Router) is based on bridge implementtaion? September 18, 2005, 8:50 am
What is VLAN, how it is used?. I have 4 PC's on one LAN connectd to router, how can I apply VLAN concept here?. February 4, 2005, 1:16 am
Which router for vlan - vlan to internet September 7, 2004, 2:37 pm
USB Ethernet controllers that use the ASIX AX88772 or AX88172 USB-Ethernet bridge devices August 19, 2005, 7:04 pm
Vlan Add and Vlan Strip August 30, 2004, 2:39 am
