Ethernet LAN VLAN operation in Transparent bridging
please rate
this thread
Posted by on July 25, 2005, 2:50 am
Hi
If a bridge is configured in "Transparent Bridging" mode then the bride
protocol entities Viz. STP, GVRP, GMRP are disabled and the bridge
forwards frames based on learned MAC information. Is the behaviour same
for both untagged and tagged (VLAN) frames ? Or does it drops VLAN
tagged frame ?
Thanks in advance
Pritam
Posted by anoop on July 25, 2005, 11:03 am
pritamganguly@gmail.com wrote:
If by "Transparent Bridging", you mean 802.1D operation (as opposed
to 802.1Q), then the bridge becomes agnostic to VLAN tags.  However,
such bridges are still expected to run STP and, optionally, GMRP.
Anoop
Posted by on July 26, 2005, 1:28 am
Hi
By transparent bridging I meant only "bridge forwarding" behaviour
without any bridge to bridge protocol executing.
 http://www.cisco.com/univercd/cc/td/doc/cisintwk/ito_doc/transbdg.htm
In this case the bridge should forward all frames received according to
the learned MAC addresses. My question was will this bridge forward
VLAN tagged frames too or drop them?
Another question will a VLAN unaware bridge forward VLAN tagged frames?
Regards
Pritam
Posted by Patrick Schaaf on July 26, 2005, 9:31 am
pritamganguly@gmail.com writes:
And the answer was "it will forward them". VLAN tagged frames look
to non-VLAN-aware bridges like any other frame. VLAN tagging is
done by using a special ethertype encoding. Ethertypes are NOT
looked at by normal (non-VLAN-aware) bridges.
This is not another question. Yes, it will.
You seem to think that running "bridge protocols" like STP, somehow
influences VLAN function. It doesn't. Those concept are independant,
to the best of my knowledge.
best regards
  Patrick
Posted by stephen on July 26, 2005, 10:59 am
Except that a maximum length ethernet frame with a tag added is effectively
oversize by 4 bytes.
So a VLAN unaware bridge may well drop the frame size oversize is an error.
Regards
Stephen Hope - return address needs fewer xxs
This Thread Bookmark this page:  YahooMyWeb Yahoo!  Google Google  Windows Live Favorites Windows Live  del.icio.us del.icio.us  digg digg  Add to Netscape Netscape
Subject Author Date
VLAN operation in Transparent bridging pritamganguly 07-25-05
Related PostsForumDate
MPLS & transparent bridging Cisco Systems 2005-08-19
Bridging NetBEUI over a GRE link Cisco Systems 2007-02-11
Unable to configure VLAN on Cisco 2516 Cisco Systems 2006-07-03
Transparent Bridging Cisco Systems 2005-10-27
cisco 2600 as bridging firewll ? Cisco Systems 2006-01-27
External Transparent Bridge between two VLANs Cisco Systems 2005-08-10
Log Login attempts :) Cisco Systems 2005-04-12
VLAN help Cisco Systems 2006-03-21
Is this doable? Bridging using NICs. Cisco Systems 2012-02-29
Mac to VLAN mapping on Cisco switches Cisco Systems 2012-05-12
Content filters configured as transparent bridges and spanni... Cisco Systems 2011-06-24
Cisco 3550 and ACL on VLAN Cisco Systems 2012-05-02
Connectionless mode Ethernet LAN 2010-09-20
Revealed: Operation Shady RAT [telecom] General Telecommunications Forum 2011-08-04
Latest PostsForumRSS
Can an intruder remotely reset a Linksys WRT54G v5 router to... Wireless Networking
Bob L. ( Message forwarded) CCTV, Alarms and other Physical Security
Sality virus help how to get rid of w32 Sality.a e malware... Networking Firewalls
Verizon in $63 Billion Faceoff With AT&T Over Family Pla... General Telecommunications Forum
Question about SmartHome 1132CU programming General Home Automation
Toronto Free Cisco Seminar CCNA CCNP CCIE & BBQ Cisco Certification
SIP Proxy Server on Windows Vista?‏ Voice-Over-IP
WE ARE BUYING NETWORKING - TELECOM USED AND NEW EQUIPMENT CI... Ethernet LAN
Satellite or cable service for local TV broadcasts? Cable Modems
Modular UPS Telecom Technical
Verizon's DSL or not in my upcoming home area? Digital Subscriber Line
Water Damage & Fire Damage Sterling Heights Michigan Nortel Networks
About the Cat 7 cable LAN and Telecom Cabling
Fire Damage Clean Up & Smoke Damage Restoration Home Automation
VPN Soft Reset? Virtual Private Networks
FA: Joe Kane's VIDEO ESSENTIALS laserdisc Home Theater
Fiber Optics in Access Network_CFP Fiber Optics
Which Forum is best for professionals in the alarm business Electronic Security in UK
SIP SDK 3.6 Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Order Now for Instant Download
