Ethernet LAN VLAN Aggregation
Subject Author Date
VLAN Aggregation vicky 07-04-08
---> Re: VLAN Aggregation Albert Manfredi07-04-08
Posted by vicky on July 5, 2008, 5:54 am
> > Hello
> > I 've a query related on the topic VLAN Aggregation is in my
> > shared web file folder
> > named as : VLAN Aggregator.txt
> > I m giving u my web shared file link
> > http://vikrantpandey.diinoweb.com/files/
> > please give some of your time for watching my query and
> > plz reply .
> In RFC 3069, Table 2, followed by Section 6, are what really matters.
> It's obvious that you can aggregate IP addressed among LANs. You do
> this anytime you connect two Ethernet hosts to an Ethernet layer 2
> switch (i.e. bridge), and assign those two to the same IP subnet. So
> it should be clear that the same can be done between VLANs.
> RFC 3069 says that implementation details are not considered in the
> RFC. Seems to me, you can create a single spanning tree, then use IP
> addresses to determine who the various members are in each VLAN. This
> is a valid way to create VLANs.
> Also, pay attention to this text in Section 6:
> "That is, when an address or range of addresses is allocated to a
> given sub-VLAN, reception of IP or ARP packets on a sub-VLAN with a
> source IP address that isn't allocated to the sub-VLAN should be
> discarded, ..."
> So, the way I'd set this up, a single broadcast domain, and only IP
> addresses used to differentiate between VLANs.
> Bert
Hello Sir
i 've one more question related to promiscuous port
as i know the defination of this promiscuous port .. it can talk to
all other types of ports
But my question is how we make a port promiscuous
means becaming a port promiscuous is only done by when the switch
controller gives the capability for promiscuous
or making a port promiscuous is done by something else
please clearify this .....
Thanks in advance
Vikrant
Posted by Walter Roberson on July 5, 2008, 10:52 am
Whether a port is promiscuous or not is controlled on the switch.
That control may be by switch software or by switch hardware.
Making a port promiscuous is *not* done by the contents of any
data packet. You cannot, for example, set a particular bit in the
layer 2 headers to signal to the switch that it needs to switch
into promiscuous mode.
There is no requirement that any switch (of any Layer of operation)
support promiscuous ports.
Posted by vicky on July 6, 2008, 11:40 am
On Jul 5, 7:52=A0pm, rober...@hushmail.com (Walter Roberson) wrote:
> In article <8ffa1849-f3a7-47bb-8fd0-ec53c52fc...@j22g2000hsf.googlegroups=
.com>,
> >means becaming a port promiscuous is only done by =A0when the switch
Ok Sir,
I m thinking some about a promiscuous port .... i m writing it you
please tell me is it correct or not
I think when we set some ports or any one port to primary vlan
(default vlan 1) and allocate a l3 device to this port then this port
or ports are termed as promiscuous port....
Is it correct................
regards
Vikrant
Posted by Albert Manfredi on July 6, 2008, 7:20 pm
> (default vlan 1) and allocate a l3 device to this port =A0then this port
> or ports =A0are termed as promiscuous port....
What are you asking?
Are you asking what a promiscuous port is, or are you asking how the
existence of VLANs in a given L2 network affects the definition of
promiscuous port?
Bert
Posted by Albert Manfredi on July 6, 2008, 7:34 pm
> =A0I m thinking some about a promiscuous port .... i m writing it =A0you
I just did a quick search under "promiscuous port," as opposed to the
more general "promiscuous mode," and came up with this definition:
http://www.examguides.com/ccnp-switching-7.htm
39.0 The following are true about PVLANs:
1. There are three types of private VLAN ports: promiscuous, isolated,
and community.
1.1 Promiscuous port: A promiscuous port communicates with all other
PVLAN ports, and is the port typically used to communicate with
external routers, servers, administrative workstations, etc.
4. In a PVLAN, promiscuous ports are called the primary VLAN, while
community and isolated ports are called secondary VLANs.
5. A PVLAN will only have one primary VLAN, but may have several
secondary VLANS.
Bert
Similar ThreadsPosted
VLAN Aggregation July 4, 2008, 8:21 am
Efficiency of link aggregation August 1, 2008, 8:13 pm
question about link aggregation between switches. September 29, 2004, 9:43 pm
Testing Link aggregation without LACP January 25, 2007, 3:45 am
802.3ad Link Aggregation between two hosts using crossover cables January 24, 2005, 11:23 am
Port trunking / link aggregation problem October 8, 2006, 9:11 am
What is VLAN, how it is used?. I have 4 PC's on one LAN connectd to router, how can I apply VLAN concept here?. February 4, 2005, 1:16 am
Which router for vlan - vlan to internet September 7, 2004, 2:37 pm
Vlan Add and Vlan Strip August 30, 2004, 2:39 am
VLAN Help (for a Vlan newbie) November 6, 2006, 12:09 pm
port-based vlan and tag-based vlan October 21, 2008, 2:03 pm
VLAN December 13, 2005, 4:23 pm
VLAN and VPN January 17, 2007, 1:05 pm
VPN Vs VLAN December 21, 2007, 3:54 pm
