Ethernet LAN Switch to switch causing traffic problems?
Subject Author Date
Switch to switch causing traffic problems? AnthonyL 04-19-05
Posted by AnthonyL on April 19, 2005, 2:46 pm
The arrangement is
Office 1 - approx 12 PC's
         Switch 1 - router- internet
            ~ 50 metres
         Switch 2
Office 2 - approx 30 PC's plus
    2 x Windows servers + 1 Novell 3.12 server (IPX)
All Cat5e structured cabling.
Virtually all traffic is from PC to one or other of the servers in
Office 2.  There are some networked printers in the system.
Traffic load should be relatively low.  One central database on SQL
server on one server, Word Processing and Exchange on the other and a
small DOS application serving 4 users in Office 1 on the Novell
server.  Some but not heavy internet access via Switch 1.
Office 1 staff experience regular delays of sometimes up to a couple
of minutes opening files or running an application.
The link between the switches is 100mbit (as is the rest of the
network except the 10mbit cards in the Novell server).
There is a second cable running from Office 1 to Office 2 but that has
not been connected and I'm not sure whether it is good practice to
have a parallel run.
One company has recommended to upgrade the link to a gigabit line but
I find the logic hard to follow since the servers will still have
100mbit cards.
Any helpful views welcomed.
AnthonyL
Posted by Al Dykes on April 19, 2005, 11:03 am
Did the switches cost less than $99 ?
Do they run the latest software ?
Is this a windows ActiveDirectry system ? If so, I think you have the
wrong DNS entry in the PC that see long delays.
You use the word "switch" and I suspect they are really routers. Are
they all on the same subnet ?
I imagine there could be other  DNS/WINS problems.
Does office 1 access the NW server ?
I've seen problems when inexpensive equipment intended for
cookie-cutter configurations get used in ways that are not shown in
the manufacturer's glossy literature, as you are.
I've been burned connecting a cheapo switch to a Big Name switch
(Cisco in my case) and the Most Senior network engineer I know has
taught me that doing switch-to-switch connections on the cheap is a
No-No. He insists the the cheap end be a hub.   FWIW.
a d y k e s @ p a n i x . c o m
Don't blame me. I voted for Gore.
Posted by AnthonyL on April 20, 2005, 3:17 pm
On 19 Apr 2005 08:03:30 -0400, adykes@panix.com (Al Dykes) wrote:
24 PORT 10/100MBPS Unmanaged switches
PLANET SWITCH    FNSW2400S
2 x 24 PORT 10/100MBPS Unmanaged switches
Allied Telesyn    AT-FS724I-30
AFAIK there are no updates available
Yes
Entries appear correct
I think they are called switches.  All on same subnet.
Yes and in fact only office 1 accesses the NW server.  No problems
with this.
I don't understand I'm afraid what I am doing so wrong.  Are you
saying switch to switch is the wrong way to bridge the offices?
So I should replace the Planet switch with a hub?
AnthonyL
Posted by J. Clarke on April 19, 2005, 11:19 am
AnthonyL wrote:
The question is where the bottleneck lies.
Cheap things to check.
First, run virus, adware, and spyware scans on _everything_ for which you
have a utility available.  If you've got malware of some sort broadcasting
tons of traffic on your LAN then nothing's going to work right until you
fix that.
  Ping each computer from each other computer and see if there is unusual
latency in either direction.  Download a copy of qcheck
<http://www.ixiacom.com/products/qcheck/> , install it on a Windows box,
read the readme, and download the appropriate endpoints from the link in
the readme, then see what speed you're really getting between machines and
if you're getting the same speed both ways--if you're not then find out
why--most common cause would be a configuration error--either speed or a
duplex mismatch.
Windows server includes a tool called "network monitor".  Go into the
Windows Server help and search on that and install it on your servers and
then watch the traffic going to and from them and see if you're seeing
anything coming in or going out that doesn't get a response.  The free
version only monitors traffic to and from the server on which it is
installed, which is a significant limitation, but it's still a useful tool.
There's a tool called "Ethereal" <http://www.ethereal.com/>  which is a
general-purpose network analyzer similar in purpose to "network
monitor"--ethereal is a free download--install it on one of your machines
that is experiencing the slowdown and watch the traffic and see if it's
sending anything for which it is not getting a response or receiving
anything to which it should be responding and isn't.
With those tools and some time you should be able to identify most network
problems--the trouble is that they're complex tools and it takes time to
learn to use them--there's a book, "Ethereal Packet Sniffing"
<(Amazon.com product link shortened)
which may help.  While you're about it, if you haven't already read them
try "Ethernet the Definitive Guide" by Charles Spurgeon
and "TCP/IP Illustrated"
<(Amazon.com product link shortened).
If you don't already have managed switches (and if you did and knew how to
use them you'd already know whether the link between them was the
problem--they'll tell you statistics on it) you might want to consider
picking up a couple of them off of ebay--Catalyst 2924s go for under $200
and sometimes under $100.  I see Procurve 4000s, which for your use are
serious overkill but a bit noisy, for about the same.
--John
to email, dial "usenet" and validate
(was jclarke at eye bee em dot net)
Posted by Al Dykes on April 19, 2005, 1:20 pm
If the OP has two switches then using a traffic monitor will be
impossible unless the switches have management. If the switches have
management then you'll get counters, which might show something
interesting.
Assuming dumb switches I think the blinkenlights are as useful.  If
the lights are not blinking he's got a problem with a timeout, not a
high traffic problem. DNS problems would show up as the former.  If
you do have lots of blinking lights then the traffic monitor on a
Windows box may tell you something but because you have a switch it
can only see it's own traffic.  ISTR that MS Monitor had software that
could be installed at other points in the network and feed data back
to the server for aggregation and analysis.  That would solve the switch
limitation.
You can use perfmon.exe on any Windows box (except 98/me/dos) to
analysis in great detail what it's doing.
If your server (CPU and disk as shown by permon) is idle and the
lights are not blinking then you do';t have a capacity problem,
you've got a network design problem. IMO probably DNS.
You can put ethereal on each and every box (except NW) and analysis
the traffic and protocols.
Agreed.  Procurve boxes have a lifetime warranty so you can't go
wrong.  As for my issue with cheap/noname switch-to-switch
connections, If you match brands, HP or Cisco you should be OK.
Similar ThreadsPosted
Switch to switch causing traffic problems? April 19, 2005, 2:46 pm
switch problems July 7, 2006, 4:31 pm
College ethernet switch problems October 3, 2005, 1:01 am
Switch performance with many-to-one port traffic October 1, 2006, 10:21 pm
VLAN - switch -> trunk -> switch - priority queuing ? August 19, 2006, 2:31 pm
Dialup problems November 3, 2004, 9:14 am
AT-WCP200G wireless problems February 13, 2006, 12:46 pm
DHCP traffic Blocking May 17, 2006, 2:05 pm
ethernet inactivy traffic December 13, 2006, 6:47 am
Backup-Route + Traffic June 11, 2007, 6:09 am
Monitor traffic through router? October 13, 2007, 1:46 pm
Traffic filtering on HP Procurve November 22, 2007, 10:54 am
Ethernet Intermittent Connectivity Problems November 15, 2005, 5:10 pm
Latency and broadcast problems on ethernet lan January 8, 2006, 10:16 am
Monitoring switches for performance & problems October 19, 2007, 2:54 am
Latest PostsForumRSS
NEWS: Google Voice App Developer Taking Another Shot at iPho... Wireless Networking
Billing with X.25 over TCP Cisco Systems
In the pursuit of new customers, wireless companies forget t... General Telecommunications Forum
Re: Motion Sensor Light for Front Entrance General Home Automation
Telecom Hardware Cisco Certification
Selling Routes Bangladesh CLI (White) Voice-Over-IP
Re: RFC 2665 error on intel Ethernet LAN
FAQ: Maximizing cable modem or DSL speed Cable Modems
CASH FOR CISCO - I BUY USED AND NEW EQUIPMENT & LOTS MOR... Telecom Technical
FAQ: Maximizing cable modem or DSL speed Digital Subscriber Line
How to set up Meridian 1 to "provide clock" to a C... Nortel Networks
NFL Soccer Jersey, NBA NHL Sports Jersey From China LAN and Telecom Cabling
Control Hot Water Circ Pump With X10? Home Automation
Text file to automate restoring a dropped VPN connection. Virtual Private Networks
Home Theater Installation Home Theater
Re: The Turkic Languages in a Nutshell Fiber Optics
sip Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Click Here to learn more
