Ethernet LAN Switch / Server - speed / duplex
Subject Author Date
Switch / Server - speed / duplex Russ 02-28-07
Posted by Russ on February 28, 2007, 10:01 pm
I had a debate with some people at wok on the effects of setting the
speed / duplex at the switch, as opposed to auto negotiate. If for
example, the switch interface is set to 100Mb/Full Duplex that is the
only speed the the node/s connected on that port can connect at? Not
10mb/Half duplex, not 100mb/Half Duplex etc etc. Is this correct?
Also if someone could provide a link to where this is documented it
would be appreciated...
Thanks in Advance
R.
Posted by BernieM on March 1, 2007, 2:46 am
> Hi,
> Thanks in Advance
> R.
Speed settings must match for the link to come up but duplex mismatches will
cause collisions. Duplex mismatches can go unnoticed if the link is not
under much load but will make it impossible to get much throughput.
I'm a Cisco 'groupie' so I'll direct you to this explanation.
http://www.cisco.com/warp/public/473/46.html#auto_neg_valid
BernieM
Posted by Rick Jones on March 1, 2007, 1:34 pm
My boilerplate on how 100BT autonegotiation is supposed to work:
How 100Base-T Autoneg is supposed to work:
When both sides of the link are set to autoneg, they will "negotiate"
the duplex setting and select full-duplex if both sides can do
full-duplex.
If one side is hardcoded and not using autoneg, the autoneg process
will "fail" and the side trying to autoneg is required by spec to use
half-duplex mode.
If one side is using half-duplex, and the other is using full-duplex,
sorrow and woe is the usual result.
So, the following table shows what will happen given various settings
on each side:
Auto Half Full
Auto Happiness Lucky Sorrow
Half Lucky Happiness Sorrow
Full Sorrow Sorrow Happiness
Happiness means that there is a good shot of everything going well.
Lucky means that things will likely go well, but not because you did
anything correctly :) Sorrow means that there _will_ be a duplex
mis-match.
When there is a duplex mismatch, on the side running half-duplex you
will see various errors and probably a number of _LATE_ collisions
("normal" collisions don't count here). On the side running
full-duplex you will see things like FCS errors. Note that those
errors are not necessarily conclusive, they are simply indicators.
Further, it is important to keep in mind that a "clean" ping (or the
like - eg "linkloop" or default netperf TCP_RR) test result is
inconclusive here - a duplex mismatch causes lost traffic _only_ when
both sides of the link try to speak at the same time. A typical ping
test, being synchronous, one at a time request/response, never tries
to have both sides talking at the same time.
Finally, when/if you migrate to 1000Base-T, everything has to be set
to auto-neg anyway.
The computing industry isn't as much a game of "Follow The Leader" as
it is one of "Ring Around the Rosy" or perhaps "Duck Duck Goose."
- Rick Jones
these opinions are mine, all mine; HP might not want them anyway... :)
feel free to post, OR email to rick.jones2 in hp.com but NOT BOTH...
Similar ThreadsPosted
Switch / Server - speed / duplex February 28, 2007, 10:01 pm
10BaseT Half Duplex Switch? July 27, 2004, 5:11 pm
DNS Server min GHZ?? January 22, 2006, 8:17 pm
Print Server u/s? March 8, 2005, 1:49 pm
server using DG on a different Vlan. August 9, 2007, 1:11 am
installing software to a server July 11, 2004, 1:49 pm
How to connect to a ftp server with a port of not 21? November 26, 2004, 11:53 pm
Does Server need new Gigabit adapter? February 1, 2006, 1:07 pm
can not access my web server by my WAN IP by router RP614 January 27, 2006, 12:23 am
MangoSoft Medley99 Virtual File Server November 22, 2004, 11:29 am
Netgear PS101 print server stalling May 10, 2008, 9:50 pm
Who is DHCP server for my Router's WAN port connected to Cable modem? April 9, 2005, 4:21 pm
Problem Accessing a Yahoo Server with SMC2804WBRP-G Barricade G Router March 6, 2006, 9:46 pm
Diagnosing network slowness: server or network? June 24, 2005, 3:59 pm
baffling speed problem July 23, 2005, 5:52 am
