Ethernet LAN Suggestion for an ethernet setup?
Subject Author Date
Suggestion for an ethernet setup? fellow 10-20-04
Posted by fellow on October 20, 2004, 1:05 am
At the moment, I've got 2 workgroups consisting of 5 computers connected via
CAT5 cable to a hub which is connected to another hub and the other group
via 10m of coax. The other group consists of 4 computers on a single coax.
Within this group, 2 computers connect to the internet via a USB connection
to an external ISDN modem with two ports, another computer connects to the
internet via a 56K modem. At the moment they are backing up data by a
portable PATA HD which means each machine has to be turned off and on . It
all seems a bit messy to me.
Roughly, how would you upgrade this setup and are there specific hubs,
routers that you would recommend?
Thanks for your expertise.
Fellow
Posted by T. Sean Weintz on October 20, 2004, 7:21 pm
> Fellow
get rid of the hubs, and get rid of the coax.
Replace any/all coax only ethernet cards in the computers with 100basetT
or 1000baset ethernet cards.
replace the hubs with a switch. if all the computers can be placed with
100 meters of the switch, just run 1 cat 5 cable from each computer to
the hub - coonect them all directly to the same hub.
If that cannot be done because some of the cables will be more than 100
meteres, then buy 2 hubs that support fiber - connect them together via
fiber and then plug the computers into the hubs.
get rid of the ISDN and dial up internet service. Get a DSL or cable
modem service and a good NAT firwall that does statefull packet inspection.
Get computer with a BIG hartd drive (or better yet, a raid array) and
back up all the computers to it via the ethernet. Or better yet, get a
real server (like HP ml530 with a sdlt tape drive in it perhaps) and
back up to that. You likely want some sort of automated backup software.
Arcserv(aka brightstor)by computer associates is an industry standard
and works well.
brand recommendations-
for network cards, I am partial to intel. Fast and inexpensive.
For switches, you don't need anything fancy or high end (no layer 3
switching, etc) but I do reccomend managed switches - i'd say get 1 or 2
Netgear FSM726s swicthes. Unless you want all 1000baseT - then get
netgear GSM712 swicthes.
for a firewall/nat box, i'd recommend a sonicwall tz170.
Posted by CJ on February 1, 2005, 12:07 am
>> via
>> coax.
>> connection
>> the
>> It
>> Fellow
> 100 meters of the switch, just run 1 cat 5 cable from each computer to the
> get rid of the ISDN and dial up internet service. Get a DSL or cable modem
> Get computer with a BIG hartd drive (or better yet, a raid array) and back
> up all the computers to it via the ethernet. Or better yet, get a real
> server (like HP ml530 with a sdlt tape drive in it perhaps) and back up to
> that. You likely want some sort of automated backup software. Arcserv(aka
> brightstor)by computer associates is an industry standard and works well.
> Netgear FSM726s swicthes. Unless you want all 1000baseT - then get netgear
> GSM712 swicthes.
Everything Sean said is right on the money.
If money is an issue, and it sounds like it is if you are still using hubs
and coax, that for the router, try the 3Com 3CR860-95. It lists for about
$160 and gets you stateful packet inspection, VPN capability, and more.
I like the Sonicwall stuff, but it can be pricey and they make you pay more
for so many connections required to the internet, whereas the 3Com does not.
Similar ThreadsPosted
Suggestion for an ethernet setup? October 20, 2004, 1:05 am
Suggestion for a 3port optical switch November 21, 2007, 5:38 am
Setup Metro ethernet (KPN EVPN) July 3, 2007, 9:49 am
Best HA switch setup? August 29, 2006, 8:58 pm
Hardware/Software setup March 28, 2007, 3:07 pm
Netgear router setup problem January 7, 2006, 6:56 pm
Simple (I think?) Managed Switch Setup August 15, 2006, 9:56 pm
USB Ethernet controllers that use the ASIX AX88772 or AX88172 USB-Ethernet bridge devices August 19, 2005, 7:04 pm
Wither simple ethernet-ethernet routers? October 18, 2004, 11:06 pm
ethernet frequency and power on ethernet October 25, 2004, 4:04 am
Difference between Ethernet 2 and 802.3 Frame per the Ethernet FAQ July 28, 2006, 9:02 am
Ethernet over T1 (Ethernet over WAN...) October 17, 2004, 4:15 am
Ethernet II November 15, 2004, 12:50 am
ethernet hub April 27, 2006, 2:44 am
