Ethernet LAN Strange problem with Ethernet switch
Subject Author Date
Strange problem with Ethernet switch ohaya 09-07-04
Posted by ohaya on September 7, 2004, 12:57 pm
I've been wondering for awhile about a problem that I'm having with an
Ethernet switch, so I hope that someone here can offer an explanation.
The switch is a Gigafast EE500-S. It's a 5-port 10/100 switch.
In my network, I have a Netgear router with a 4-port 10/100 switch,
built-in to the router, that connects to my cablemodem provider. I have
a cable going from one of the ports on the Netgear to the wall in one of
the rooms in my house.
If I plug a cable directly from the wall to the uplink port of the
Gigafast switch, I can ping my router and external destinations from any
PC that's connected directly to the Gigafast, but I get about 50%
timeouts.
If I ping any other computers directly connected to the Gigafast from
another computer on the Gigafast, everything is ok.
This is regardless of how I configure the NICs on the PCs connected to
the Gigafast (10 HDX or FDX, 100 HDX or FDX).
I kind of puzzled over this for awhile, but then, instead of connecting
the Gigafast uplink directly to the wall, I tried connecting an old
10Base-T hub between the Gigafast and the wall (i.e., Gigafast uplink
port to hub port via crossover cable, and then hub port to the wall),
and lo and behold, when I ping from any PCs connected to the Gigafast to
either my router or external destinations, no more timeouts.
I would love to eliminate the need for this "in-between" hub, but I
can't figure out why it's needed to get from the Gigafast to the router.
Can anyone here explain this?? Also, is there any way to allow me to
connect directly from the Gigafast to the wall, to the router?
Thanks,
Jim
Posted by J. Clarke on September 7, 2004, 1:47 pm
ohaya wrote:
> Hi,
> timeouts.
Sounds like a duplex mismatch between the Gigafast and the Netgear. Try
shutting _everything_ down then connecting the two, then power them up,
then power up the rest of your system. If that doesn't work, it could be a
bad cable that will carry 10 Mb/sec but not 100. Try running a known-good
cable directly between the two and see if the problem recurs. If so, then
before I wasted any more time troubleshooting it I'd replace the
Gigafast switch with a Netgear and see if it was an incompatibility.
> Thanks,
> Jim
--John
Reply to jclarke at ae tee tee global dot net
(was jclarke at eye bee em dot net)
Posted by ohaya on September 7, 2004, 9:57 pm
John,
Thanks. I'll give that (powering the router and switch up first by
themselves), but it is the cable not being able to carry 100 Mbps,
shouldn't the switches (both the one inside the Netgear and the
standalone) be able to negotiate that? Both of these switches are
*suppose* to be "10/100" switches...
Jim
Posted by J. Clarke on September 7, 2004, 11:03 pm
>> a
>> known-good
>> then before I wasted any more time troubleshooting it I'd replace the
> John,
The quick answer is no. Fast Ethernet devices communicate with each other
at 10 Mb/sec to negotiate the capabilities of the devices at each end of
the cable and then switch to the highest performance level that both
support. All the negotiation though occurs at 10 Mb/sec. They do no
testing of the cable, and they have no fallback modes. If both devices
support 100 full duplex then that is what they set themselves for and if
the cable isn't up to it then communication is impaired in one manner or
another and to a greater or lesser degree depending on what's wrong with
the cable.
> Jim
--John
Posted by M.C. van den Bovenkamp on September 8, 2004, 5:02 am
No. Autonegotiation does not check for cable quality. It just checks
what the capabilities of the other end are, and will negotiate the best
combination. Whether the cable can actually support that is something
else entirely.
I agree with the previous poster that a duplex mismatch is the most
likely problem, with a split pair somewhere in the path a close second.
                Regards,
                        Marco.
Similar ThreadsPosted
Strange problem with Ethernet switch September 7, 2004, 12:57 pm
strange ethernet electric problem June 22, 2007, 5:39 am
Strange switch behaviour in VLAN network July 6, 2005, 12:53 pm
3Com 4900 Switch Table Problem November 8, 2004, 11:02 am
Problem with PAUSE frames ethernet flow control September 25, 2008, 7:09 am
Strange MAC Addresses July 29, 2004, 7:32 pm
Strange results from a tcpdump, can anyone help? March 29, 2006, 2:51 pm
Strange ethrenet frame October 4, 2006, 10:54 am
Routing problem December 12, 2005, 9:48 pm
Problem with WAP and LAN connection September 4, 2006, 7:21 am
Problem: UTP only works at 10 MHz July 27, 2007, 8:02 pm
problem on LAN or firewall November 22, 2007, 7:21 am
Problem with DFE-855 link locking up July 9, 2004, 12:50 am
Lan to Lan to internet routing problem October 7, 2004, 8:48 am
Problem with Gig Link not coming up October 8, 2004, 10:38 am
