Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Danny Stone on August 20, 2006, 4:09 am
Please log in for more thread options I am seeking a means of performing basic 10/100 bit error rate testing using a Win XP laptop w/ integrated NIC. Essentially I am looking for a software application to run on the laptiop that can generate and terminate fixed length (up to 1518 byte) packets of random data content. The purpose is simple 10/100 bit error rate testing. I don't need to manipulate the IP header, nor is higher level protocol testing required. However, it is necessary for the software tool to generate - as well as terminate - test traffic, so a receive-only sniffer/protocol analyzer won't work. The desired functionality is equivalent to a very stripped-down/poor man's version of a Spirent SmartBits with a SX-7410 card and SMartWindows software. Any leads? TIA, Danny | ||||||||||||||||
Posted by Gerard Bok on August 20, 2006, 7:31 am
Please log in for more thread options On Sun, 20 Aug 2006 08:09:26 GMT, Danny Stone First of all, if you read through this group's archive, you will find that there is no such thing as a 'NIC BERT'. But for what you want to do: most NIC chipset manufacturers supply a test utility that will pull this trick for you. (e.g. Realtek: REALDIAG.exe) -- Kind regards, Gerard Bok | ||||||||||||||||
Posted by on August 20, 2006, 8:26 pm
Gerard Bok wrote: > On Sun, 20 Aug 2006 08:09:26 GMT, Danny Stone
> >testing using a Win XP laptop w/ integrated NIC. Essentially I am > >looking for a software application to run on the laptiop that can > >generate and terminate fixed length (up to 1518 byte) packets of > >random data content. > > > >The purpose is simple 10/100 bit error rate testing. >
> First of all, if you read through this group's archive, you will > find that there is no such thing as a 'NIC BERT'. > > But for what you want to do: most NIC chipset manufacturers > supply a test utility that will pull this trick for you. > (e.g. Realtek: REALDIAG.exe) Above sounds a fine plan. If for some reason that does not suit you could as an alternative consider sending frames and seeing if they arrive correctly. Ethernet checks for bad frames so all you have to do is to send frames and count how many arrive. This clearly does not return the BER directly. I am also not sure what you expect to see. Here is a random port on a LAN. Well I know is was a busy one but no special selection was made regarding error rate. sw2#sh int gi 3/22 counters Port InBytes InUcastPkts InMcastPkts InBcastPkts Gi3/22 4419807352991 8817575501 206740 44197 Port OutBytes OutUcastPkts OutMcastPkts OutBcastPkts Gi3/22 1260741405328 4961991888 61575480 35987515 sw2#sh int gi 3/22 counters err Port CrcAlign-Err Dropped-Bad-Pkts Collisions Symbol-Err Gi3/22 0 0 0 0 Port Undersize Oversize Fragments Jabbers Gi3/22 0 0 0 0 Port Single-Col Multi-Col Late-Col Excess-Col Gi3/22 0 0 0 0 Port Deferred-Col False-Car Carri-Sen Sequence-Err Gi3/22 0 0 0 0 That's 40,000G bits with no errors of any kind!!! This is a copper GBE port running at 1000Mbps. Tools for sending a lot of packets and checking if they arrive are:- iperf this is like ttcp but a bit reworked ttcp fping.exe http://www.kwakkelflap.com - not too easy to find hence the reference. | ||||||||||||||||
| Similar Threads | Posted |
| Soft Ethernet BER Tester Tool | August 20, 2006, 4:09 am |
| Tool To Diagnose Network Configuration Errors | November 19, 2006, 12:22 am |
| Supply RJ45 Crimping Tools(Punch Down Tool) | November 1, 2005, 5:10 pm |
| Cat6 tool-less jacks for pair-bonded cable? | January 28, 2006, 12:27 am |
| NETWORK TESTER | April 18, 2007, 10:12 am |
| Basic link tester | December 15, 2005, 10:19 am |
| Newbie: cheap cable tester? | June 3, 2007, 6:30 pm |
| USB Ethernet controllers that use the ASIX AX88772 or AX88172 USB-Ethernet bridge devices | August 19, 2005, 7:04 pm |
| Wither simple ethernet-ethernet routers? | October 18, 2004, 11:06 pm |
| ethernet frequency and power on ethernet | October 25, 2004, 4:04 am |
| Difference between Ethernet 2 and 802.3 Frame per the Ethernet FAQ | July 28, 2006, 9:02 am |
| Ethernet over T1 (Ethernet over WAN...) | October 17, 2004, 4:15 am |
| Ethernet II | November 15, 2004, 12:50 am |
| ethernet hub | April 27, 2006, 2:44 am |
| WAN Ethernet | May 2, 2006, 4:20 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
