Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by James Harris on September 9, 2008, 4:55 pm
Please log in for more thread options Could someone check my calculations? I'm looking for the shortest time an Ethernet frame will occupy the wire. I make it about 5uS on 100Mbit as follows. Minimum frame size in bytes is 46 payload + 14 header + 4 FCS = 64. Preamble (still needed on full duplex) of 8 octet times Total of 72 octets * 8 bits = 576 bits. Each bit time is 1/100,000,000 seconds. (IIRC the signalling rate is 125,000,000 bits with a 4B/5B encoding so we do get 100,000,000 data bits in a second.) Finally 576 * 1/100,000,000 = 5.76uS On 10Mbit I make the figure ten times as much 57.6uS On Gbit I think they kept the basic timing budget from 100Mbit so make it's smallest-frame time about the same as for 100Mbit. Corrections welcome. Does the above look about right? -- James | ||||||||||||||||||||||||||||||||||||||||||||||
Posted by Bob F. on September 9, 2008, 5:10 pm
Please log in for more thread options At one point on the cable or over the legal length of cable? -- Regards, Bob F. | ||||||||||||||||||||||||||||||||||||||||||||||
Posted by James Harris on September 9, 2008, 5:48 pm
> > an Ethernet frame will occupy the wire. I make it about 5uS on 100Mbit > > as follows. >
> > Preamble (still needed on full duplex) of 8 octet times > > Total of 72 octets * 8 bits = 576 bits. > > Each bit time is 1/100,000,000 seconds. (IIRC the signalling rate is > > 125,000,000 bits with a 4B/5B encoding so we do get 100,000,000 data > > bits in a second.) >
> > On Gbit I think they kept the basic timing budget from 100Mbit so make > > it's smallest-frame time about the same as for 100Mbit. >
> > James >
> At one point on the cable or over the legal length of cable? Umm, well if the speed of signal propagation over copper cable is about 0.7 times the speed of light (not sure of the exact figure but that's about right, isn't it?) we have the speed as 0.7 * 300,000,000 metres per second = 210,000,000 If that's right then in 1uS the signal would propagate 210 metres so I think the length of the cable becomes almost insignificant - up to a standard length of 100m anyway. Maybe it would add 0.5uS to the total, over that length. Incidentally I think the old co-ax thinnet relied on reflected wave signalling so signals had to go to a terminator and bounce back for each bit - so the whole cable became energised for that bit long before the next bit was put on the wire. Just some more comments that people may be able to shoot down... Still I don't mind being the clay pigeon. It would be good to get some of these ideas confirmed ... or denied. -- James | ||||||||||||||||||||||||||||||||||||||||||||||
Posted by Bob F. on September 9, 2008, 6:18 pm
>> > an Ethernet frame will occupy the wire. I make it about 5uS on 100Mbit >> > as follows. >>
>> > Preamble (still needed on full duplex) of 8 octet times >> > Total of 72 octets * 8 bits = 576 bits. >> > Each bit time is 1/100,000,000 seconds. (IIRC the signalling rate is >> > 125,000,000 bits with a 4B/5B encoding so we do get 100,000,000 data >> > bits in a second.) >>
>> > On Gbit I think they kept the basic timing budget from 100Mbit so make >> > it's smallest-frame time about the same as for 100Mbit. >>
>> > James >>
>> At one point on the cable or over the legal length of cable? >
> Umm, well if the speed of signal propagation over copper cable is > about 0.7 times the speed of light (not sure of the exact figure but > that's about right, isn't it?) we have the speed as > > 0.7 * 300,000,000 metres per second = 210,000,000 > > If that's right then in 1uS the signal would propagate 210 metres so I > think the length of the cable becomes almost insignificant - up to a > standard length of 100m anyway. Maybe it would add 0.5uS to the total, > over that length. > > Incidentally I think the old co-ax thinnet relied on reflected wave > signalling so signals had to go to a terminator and bounce back for > each bit - so the whole cable became energised for that bit long > before the next bit was put on the wire. > > Just some more comments that people may be able to shoot down... Still > I don't mind being the clay pigeon. It would be good to get some of > these ideas confirmed ... or denied. > > -- > James "insignificant" depends on what's behind the question. Can you tell us what you are trying to do, or what's concerning you so the question can be answered more appropritely. -- Regards, Bob F. | ||||||||||||||||||||||||||||||||||||||||||||||
Posted by James Harris on September 9, 2008, 7:16 pm
> >> > an Ethernet frame will occupy the wire. I make it about 5uS on 100Mbit > >> > as follows. >
> >> > Preamble (still needed on full duplex) of 8 octet times > >> > Total of 72 octets * 8 bits = 576 bits. > >> > Each bit time is 1/100,000,000 seconds. (IIRC the signalling rate is > >> > 125,000,000 bits with a 4B/5B encoding so we do get 100,000,000 data > >> > bits in a second.) >
> >> > On Gbit I think they kept the basic timing budget from 100Mbit so make > >> > it's smallest-frame time about the same as for 100Mbit. >
> >> > James >
> > about 0.7 times the speed of light (not sure of the exact figure but > > that's about right, isn't it?) we have the speed as >
> > think the length of the cable becomes almost insignificant - up to a > > standard length of 100m anyway. Maybe it would add 0.5uS to the total, > > over that length. >
> > signalling so signals had to go to a terminator and bounce back for > > each bit - so the whole cable became energised for that bit long > > before the next bit was put on the wire. >
> > I don't mind being the clay pigeon. It would be good to get some of > > these ideas confirmed ... or denied. >
> > James >
> "insignificant" depends on what's behind the question. Can you tell us what > you are trying to do, or what's concerning you so the question can be > answered more appropritely. I mean the signal propagation delay (absolute maximum 0.5uS) appears to be "almost insignificant" compared with the minimum frame time of 5.76uS. There's no application relevant. I just wanted to check my figures. Of course the resulting thread may be useful for someone to refer back to. -- James | ||||||||||||||||||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Shortest ethernet frame time = 5.76uS? | September 9, 2008, 4:55 pm |
| Ethernet auto-negotiate time | September 11, 2004, 10:19 pm |
| Use of ethernet frame without TCP/IP | March 17, 2008, 5:48 am |
| Maximum Auto-Negotiation Time on Twisted-Pair Gigabit Ethernet | June 19, 2008, 8:21 am |
| Ethernet Frame size | January 17, 2005, 8:01 pm |
| Maximum size of Ethernet frame | November 11, 2004, 9:40 am |
| detecting end/length of Ethernet II frame? | April 28, 2005, 2:03 pm |
| min size for VLAN tagged ethernet frame | November 2, 2006, 4:45 am |
| Difference between Ethernet 2 and 802.3 Frame per the Ethernet FAQ | July 28, 2006, 9:02 am |
| Link Up Time | March 14, 2006, 12:24 pm |
| Network Time (Newbie Q) | October 19, 2004, 10:45 am |
| LAN cabling : The right time for beginning | February 1, 2006, 5:24 am |
| Why 96 bits of silent time? | November 21, 2006, 8:21 am |
| STP and RSTP congergence time | May 9, 2008, 12:10 pm |
| Why CSMA/CD is not suitable for real time applications?? | January 18, 2005, 4:06 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> as follows.
> bits in a second.)
> James
