Ethernet LAN Scrambling in 1000Base-T
Subject Author Date
Scrambling in 1000Base-T Michelot 03-07-08
Posted by Michelot on March 7, 2008, 6:12 am
Bonjour,
In 1000Base-T Ethernet, the scrambling at the master side is different
from the scrambling at the slave side. Is someone knows the reason?
At the master side, the polynomonial is: 1 + X13 + X33, whereas
at the slave side, the polynomial is: 1 + X20 + X33.
Is it a question of energy spreading?
Thanks for your advice,
Michelot
Posted by Michelot on March 8, 2008, 4:59 pm
Hi Michelot,
I think no. The separare scramblers makes the two opposite streams
more uncorrelated, which helps symbol recovery at the receiving end.
Let's try an example, if it is correct!
The length of the pseudocode is 2v33 = (2v10)v3.3 bits, around 10v10
bits, that's make 10v4 seconds at 1 Gbit/s, that is around 3 hours.
Suppose a transmitting of IDLE. If the scramblers were same, the both
end will transmit the same signal after a period of 3 hours. In this
case, with the echo and crosstalk cancellations, perhaps it should be
difficult to detect a start of MAC frame.
Is it your advice?
Mchelot
Similar ThreadsPosted
Scrambling in 1000Base-T March 7, 2008, 6:12 am
gigabit and 1000baseT October 23, 2004, 10:12 pm
Patch cables for 1000BaseT Cat? October 26, 2004, 2:48 pm
