Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by ps56k on May 12, 2008, 4:25 pm
Please log in for more thread options Lloyd E. Sponenburgh wrote: wow - I'm surprised they didn't work better for you http://www.netgear.com/Products/PowerlineNetworking/PowerlineEthernetAdapters.aspx wonder if the 85rmbps units would work better... years ago we used some Netgear telephone wiring bridges from the office to the loading dock, and they worked great..... but don't see anything like that listed anymore --- > Going to Amazon to check buyer's comments on this product you can see
> why I've been recommending that people go with the netgear 102 or 103 > (104 is same) and NOT with 101s. There are good reviews, but the bad > ones are telling in this case: > > Quote: > > I attempted to upgrade my electric wiring based network from Netgear > XE104's (rated at 85Mbps) to the Netgear HDX101's (rated at 200Mbps). > The performance of the HDX101 network was substantially slower and > less reliable than the XE104 network with exactly the same devices > attached to the XE104's and the HDX101's. I did not have both networks > operating at the same time even though a HDX101 network supposedly can > co-exist with a XE104 network. I highly recommend the Netgear XE104, > but was very disappointed in the HDX101. I would not even recommend > the HDX101 for use on the same electrical circuit in the same room. > The HDX101 also becomes very warm in operation. > ___________________________ > > Quote: > Beware: HDX[B]101 doesn't follow the HomePlug-AV standard..... > It follows a demonstrably inferior, European-brewed standard. Netgear > simply jumped the gun and didn't wait for HomePlug-AV chipsets to > become available. This HDX[B]101 product is a dead end, because > HomePlug-AV will win the standards war. > > If you truly need higher speed than is attainable from HomePlug-Turbo > products such as Netgear's XE104 (85Mbits/s best-case raw channel > bitrate), then wait a little while for HomePlug-AV-compliant ("200Mb/ > s") products to hit the market in the USA.... > _____________________________ > > Comment: that's an old post - HomePlug-AV is now availible, I believe. > > Here's an comment that may actually help with what you now have: > > Quote: > One thing that we noticed though was the transfer speeds still weren't > that great. After some playing, a friend we stick a switch between the > router (linksys) and the powerline ethernet adapter, and that did it - > transfer speeds went through the roof (at the advertised > speeds)............ I recommend buying a cheap switch (got mine for > $10) and inserting that between the router and the "main" powerline > adapter and you'll be pleased. > > ________________________________________________ > > > Steve | ||||||||||
| Similar Threads | Posted |
| Re: Netgear powerline extenders | May 12, 2008, 4:25 pm |
| LAN extenders as alternative to Fiber | February 1, 2006, 5:17 am |
| Re: Wireless Vs Ethernet Extenders - 800m | June 12, 2008, 3:25 pm |
| Netgear FS526T | January 25, 2005, 8:48 pm |
| NetGear WGU624 | March 16, 2006, 6:37 pm |
| Netgear WGT624 V2 Router | July 7, 2004, 2:28 pm |
| Voyager 205 and Netgear FS605 | May 6, 2005, 6:00 pm |
| Dead Netgear PE-102s | March 29, 2006, 6:09 pm |
| Netgear and Cisco Trunk | May 3, 2007, 4:04 am |
| Netgear GSM72224 VLAN config | November 8, 2004, 12:49 pm |
| Netgear router setup problem | January 7, 2006, 6:56 pm |
| Allied Telesyn vs Cisco vs netgear | March 24, 2006, 4:02 pm |
| Intra-switch VLANs Netgear | September 6, 2006, 1:46 pm |
| Third Party SFPs in Netgear Switches | September 24, 2006, 2:27 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> with the idea that we'd network our new T&A clock to the office
> computers without having to trench.
> The total wire distance from the clock to the breaker, then from the
> breaker to the office is 70'. Both outlets on the same leg of single-
> phase 110. No carrier detected.
> So I brought them both into the office. If the two are connected on
> the same branch, and are less than 20' apart, we get carrier. If
> they're on different branches of the same leg, no carrier.
> So I plugged them both into the same outlet, and did some tests.
> 1) they're rated at 200mb/s but have only 10/100 ports... HUH?
> 2) they averaged under 8mb/s throughput when on the same outlet.
> Ok... maybe they're swamping... Move them to two outlets eight feet
> apart on the same branch.... 7mb/s.
> I'd say this is not the way to stream video... no?
> LLoyd
