Ethernet LAN Re: Autonegotiation @ 100 / 1000BASE-T - why in another sublayer of PHY
Subject Author Date
Re: Autonegotiation @ 100 / 1000BASE-T - why in another sublayer of PHY Rick Jones 03-15-07
Posted by Rick Jones on March 15, 2007, 5:23 pm
> little question, that does not find it's answer in google (no matter
> of what angle I strike it) - in 100BASE-TX, autonegotiation function
> is placed just before the RJ-45 (MDI), under the PMD (physical
> medium dependent - at the bottom of PHY), and then - in 1000BASE-T
> it is defined as a functional block of PCS (physical coding sublayer
> - at the top of PHY).
> Simple q: W H Y ? ? ?
I'm not sure it is an/the answer, but autoneg in 100BT was (at least
initially) optional. I don't think it was ever optional in 1000BT.
Perhaps that has something to do with where it is placed? I suspect
the folks over in comp.dcom.lans.ethernet would know.
rick jones
Wisdom Teeth are impacted, people are affected by the effects of events.
these opinions are mine, all mine; HP might not want them anyway... :)
feel free to post, OR email to rick.jones2 in hp.com but NOT BOTH...
Posted by banan on March 15, 2007, 6:13 pm
Thanks, will go there and check out.
bio
Posted by glen herrmannsfeldt on March 15, 2007, 8:05 pm
I don't believe that it existed at the beginning of 100baseTX.
I used to have a 3C250 (bought cheap on eBay), one of the original
100baseTX repeaters. No 10baseT mode, but it does make a good
door stop.
-- glen
Similar ThreadsPosted
Re: Autonegotiation @ 100 / 1000BASE-T - why in another sublayer of PHY March 15, 2007, 5:23 pm
autonegotiation and media converters August 23, 2005, 5:26 pm
gigabit and 1000baseT October 23, 2004, 10:12 pm
Patch cables for 1000BaseT Cat? October 26, 2004, 2:48 pm
Which Layer 2 sublayer participates in encapsulation, and framing October 24, 2007, 10:23 pm
