Ethernet LAN Rapid Spanning Tree question
Subject Author Date
Rapid Spanning Tree question bspdan 03-15-07
Posted by bspdan on March 15, 2007, 9:09 am
After an RSTP topology change, does a device necessarily have to flush
both unicast and multicast address tables? I'm running into an issue
where my multicast GDAs (which are dynamic) are being flushed, and not
being relearned until the next IGMP report comes in, which can be at
best several seconds or up to a minute. This is too long. Is there a
hard and fast rule that says you *must* flush multicast, or is it only
a best practices type suggestion?
Thanks,
Dan
Posted by anoop on March 15, 2007, 10:04 pm
The standard doesn't seem to say anything specific to multicast.
It does say that you have to flush entries associated with a port
in certain scenarios (in certain scenarios you can optionally
just transfer the entries to a different port). So, in the case of
multicast,
perhaps all the entries that have the port as one of the outputs get
flushed.
I'm curious though...what's the problem? I assume it must be
flooding the traffic for the period of time between flushing and
relearning in order to keep things working.
Anoop
Posted by bspdan on March 28, 2007, 8:08 am
> multicast,
> flushed.
> Anoop
Hi Anoop,
Thanks for the reply. Our apps run in automation lines where there is
a fairly constant stream of small traffic closely spaced together.
Think multicast packet every 100 ms containing sensor data. The
problem is that the GDAs get flushed, but because multicast source
detection is running on the switch, a GDA is immediately created
containing the port that received the multicast packet and the port
which has been receiving IGMP queries. This causes the switch to
ignore the real receiving port (which got flushed with the GDA) until
it gets an IGMP report, which can be a second or two, up to the query
interval + 10s. This is too long for our environment.
Thanks,
Dan
Similar ThreadsPosted
Rapid Spanning Tree question March 15, 2007, 9:09 am
Spanning Tree question September 27, 2006, 5:23 am
Any expert on Spanning Tree Here?Come in please. November 20, 2004, 4:18 am
Spanning Tree Protocol June 5, 2008, 6:38 am
Spanning Tree Port Priority August 31, 2005, 11:05 am
How to test spanning tree protocol July 28, 2006, 1:03 am
Extreme Networks Spanning Tree Protocol (STP) August 8, 2005, 3:54 am
Spanning Tree and Routing gets killed by Desktop switch November 11, 2004, 8:42 pm
Help needed about Implementation of "Spanning Tree Protocol" for switch September 16, 2005, 6:54 pm
STP question October 29, 2004, 1:59 pm
a question about STP 802.1d December 7, 2004, 3:03 pm
NAT question... January 21, 2005, 5:07 am
Question regarding 802.1x March 2, 2005, 7:32 pm
Re: A question for the NG December 11, 2006, 1:44 pm
Re: A question for the NG December 11, 2006, 5:58 pm
