Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Rich Seifert on July 7, 2008, 11:40 am
Please log in for more thread options > wrote:
> > In article
> > > wrote:
> > > > In article > >
> > > > > > > What u say about inter-vlan communication is it possible ..... if
> > > > > yes plz tell how ???? > >
> > > > A VLAN is a *virtual LAN*, i.e., distinct VLANs appear to be physically
> > > > separate Local Area Networks. As with all separate networks, > > > > communication among them can be effected by using a router. > >
> > > And is inter- port based vlan communication is possible in l 2 switch
> > > or for this the switch controller register support is required > >
> > Please read my original response. Communications among VLANs (indeed, > > among *any* LANs) can be accomplished using a router. I am sorry if you > > do not understand this, or if this is not the answer you want. > > > > I have no idea what a "switch controller register" *is*, much less > > whether it may be required for inter-port based VLAN communication. > > > -----------------------------------------------------
> > Hello Sir > > I ve a query related to inter-vlan(port based) communication > so first please read my query which in my share web file > named as > > stp and vlan case.txt > > the link for my share web file is -- > > > http://vikrantpandey.diinoweb.com/files/ > > please read it and then please reply. > I read your file, and my answer is unchanged. You seem to believe that, because there are multiple ports physically connected to a single switch, that the switch *MUST* provide the mechanism for communicating among all of those ports. However, if you configure some of the switch ports to be in disjoint VLANs (as you have), then it is possible-- indeed, likely--that the switch will NOT provide such communication. By configuring separate VLANs as you have shown, you are, in essence, telling the switch NOT to allow communication directly among those VLANs. As I have said many times now, communications among VLANs can be accomplished using a router. In the diagram you have provided, you show no router, so there will be no communications among the separate VLANs. If you want communications among all of the ports, then don't configure them into separate VLANs. -- Rich Seifert Networks and Communications Consulting 21885 Bear Creek Way (408) 395-5700 Los Gatos, CA 95033 (408) 228-0803 FAX Send replies to: usenet at richseifert dot com | |||||||||||||||||||||||||||||||
Posted by vicky on July 10, 2008, 1:39 am
Please log in for more thread options > In article
> > > > > > > wrote:
> > > In article
> > > > wrote: > > > > > In article > > > > > <a528a823-0998-4b29-b21b-d6bd21262...@34g2000hsh.googlegroups.com= >,
> > > > > > > > What u say about =A0inter-vlan communication =A0 is it possible=
..... if
> > > > > A VLAN is a *virtual LAN*, i.e., distinct VLANs appear to be phys=
ically
> > > > And is inter- port based vlan communication is possible in l 2 swit=
ch
ou
> > > among *any* LANs) can be accomplished using a router. I am sorry if y= > > > do not understand this, or if this is not the answer you want.
> > Hello Sir
> > so first please read my query which =A0in my share web file > > named as >
> > the link for my share web file is =A0--
> > =A0 =A0 =A0 =A0 =A0 =A0http://vikrantpandey.diinoweb.com/files/
lting
> I read your file, and my answer is unchanged. You seem to believe that, > because there are multiple ports physically connected to a single > switch, that the switch *MUST* provide the mechanism for communicating > among all of those ports. However, if you configure some of the switch > ports to be in disjoint VLANs (as you have), then it is possible-- > indeed, likely--that the switch will NOT provide such communication. By > configuring separate VLANs as you have shown, you are, in essence, > telling the switch NOT to allow communication directly among those VLANs. > > As I have said many times now, communications among VLANs can be > accomplished using a router. In the diagram you have provided, you show > no router, so there will be no communications among the separate VLANs. > If you want communications among all of the ports, then don't configure > them into separate VLANs. > > -- > Rich Seifert =A0 =A0 =A0 =A0 =A0 =A0 =A0Networks and Communications Consu= > =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 21885 Bear Creek Way
> (408) 395-5700 =A0 =A0 =A0 =A0 =A0 =A0Los Gatos, CA 95033 > (408) 228-0803 FAX > > Send replies to: usenet at richseifert dot com- Hide quoted text - > > - Show quoted text - ------------------------------------------------------------------- Hello Sir I 've a stp_and_vlan.jpg file in my web file sharing http://vikrantpandey.diinoweb.com/files/ this wat i m asking is same of port vlan group query but please visit in my file Thanks VIkrant | |||||||||||||||||||||||||||||||
Posted by Rich Seifert on July 10, 2008, 11:46 am
Please log in for more thread options In article
> I 've a stp and vlan.jpg file in my web file sharing > > http://vikrantpandey.diinoweb.com/files/ > > this wat i m asking is same of port vlan group query but please visit > in my file > I looked at this file, and the statements in it, but I really do not understand what the question is, perhaps because of a language problem. I will try to explain what I *do* see. You have a switch (S3) with 8 ports, organized as seven distinct port-based VLANs. Looking at this switch *alone*, I can tell you that there will be no user frames forwarded between any ports other than ports 4 and 5, since only those two ports are in the same VLAN (VLAN 4). This behavior is completely independent from, and has nothing to do with the fact that some ports are designated and one is a root port. Spanning Tree connectivity is generally unrelated to the issue of frame forwarding within a VLAN. Is there some other question here that I am not seeing? -- Rich Seifert Networks and Communications Consulting 21885 Bear Creek Way (408) 395-5700 Los Gatos, CA 95033 (408) 228-0803 FAX Send replies to: usenet at richseifert dot com | |||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Query related to a stp and vlan case | June 26, 2008, 1:53 pm |
| Queries related to VLAN | May 24, 2008, 1:44 am |
| VLAN Query | November 4, 2004, 6:32 pm |
| VLAN-Aware switch query... | June 6, 2005, 10:28 am |
| Ethernet Vlan-aware switch query. | May 4, 2005, 7:40 am |
| STP-RSTP query | October 16, 2008, 3:29 am |
| igmp query and snooping | October 6, 2004, 6:13 am |
| query on port speed specification | January 5, 2008, 7:37 am |
| query on Port-mirroring on Marvell Board | January 4, 2007, 4:32 am |
| Placement of Layer 3 3COM switch query | May 31, 2005, 12:56 am |
| Query on MSTP(Force port state) | July 15, 2007, 12:58 am |
| What is VLAN, how it is used?. I have 4 PC's on one LAN connectd to router, how can I apply VLAN concept here?. | February 4, 2005, 1:16 am |
| Which router for vlan - vlan to internet | September 7, 2004, 2:37 pm |
| Vlan Add and Vlan Strip | August 30, 2004, 2:39 am |
| VLAN Help (for a Vlan newbie) | November 6, 2006, 12:09 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
