Ethernet LAN Query related to a stp and vlan case
Subject Author Date
Query related to a stp and vlan case vicky 06-26-08
Posted by Walter Roberson on July 5, 2008, 6:03 pm
>VLANs share physical media with other traffic but the packets
>are at least tagged (often by port number) and usually
>encrypted to prevent traffic mixing on a logical level.
I gather that you are referring to some kind of app to app
level encryption? I'm not -aware- of any switch / router
that does encryption at the point where an untagged VLAN enters
the network, and decryption at the point where the untagged
VLAN exits the network (possibly a number of hops away), all
transparently to the hosts. Or rather, to the extent that I
have heard of such things, I would probably call them
Virtual Private Networks (VPNs) rather than encrypted VLANs -- especially
as VPNs can carry VLAN-tagged packets within them.
Posted by Robert Redelmeier on July 6, 2008, 2:15 am
> I gather that you are referring to some kind of app to app level
> encryption? I'm not -aware- of any switch / router that does
> encryption at the point where an untagged VLAN enters the network,
> and decryption at the point where the untagged VLAN exits the
> network (possibly a number of hops away), all transparently to
> the hosts. Or rather, to the extent that I have heard of such
> things, I would probably call them Virtual Private Networks
> (VPNs) rather than encrypted VLANs -- especially as VPNs can
Correct. I was not referring to 802.1Q tagging (layer 2)
but rather more to plain vanilla IP (layer 3) which is
probably best described as VPN.
-- Robert
Posted by vicky on July 5, 2008, 11:27 pm
wrote:
> In article
> > What u say about =A0inter-vlan communication =A0 is it possible ..... i=
f
> > yes plz tell how ????
> A VLAN is a *virtual LAN*, i.e., distinct VLANs appear to be physically
> separate Local Area Networks. As with all separate networks,
> communication among them can be effected by using a router.
> Rich Seifert =A0 =A0 =A0 =A0 =A0 =A0 =A0Networks and Communications Consu=
lting
> =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 21885 Bear Creek Way
> (408) 395-5700 =A0 =A0 =A0 =A0 =A0 =A0Los Gatos, CA 95033
> (408) 228-0803 FAX
> Send replies to: usenet at richseifert dot com
And is inter- port based vlan communication is possible in l 2 switch
or for this the switch controller register support is required
Thanks
Vikrant
Posted by Rich Seifert on July 6, 2008, 12:39 pm
In article
> wrote:
> > In article
> > > What u say about  inter-vlan communication   is it possible ..... if
Please read my original response. Communications among VLANs (indeed,
among *any* LANs) can be accomplished using a router. I am sorry if you
do not understand this, or if this is not the answer you want.
I have no idea what a "switch controller register" *is*, much less
whether it may be required for inter-port based VLAN communication.
Rich Seifert Networks and Communications Consulting
(408) 395-5700 Los Gatos, CA 95033
(408) 228-0803 FAX
Posted by vicky on July 7, 2008, 2:24 am
wrote:
> In article
> > wrote:
> > > In article
> > > > What u say about =A0inter-vlan communication =A0 is it possible ...=
.. if
> > > A VLAN is a *virtual LAN*, i.e., distinct VLANs appear to be physical=
ly
lting
> (408) 228-0803 FAX
> Send replies to: usenet at richseifert dot com- Hide quoted text -
> - Show quoted text -
Hello Sir
I ve a query related to inter-vlan(port based) communication
so first please read my query which in my share web file
named as
stp and vlan case.txt
the link for my share web file is --
http://vikrantpandey.diinoweb.com/files/
please read it and then please reply.
Thanks
Vikrant
Similar ThreadsPosted
Query related to a stp and vlan case June 26, 2008, 1:53 pm
Queries related to VLAN May 24, 2008, 1:44 am
VLAN Query November 4, 2004, 6:32 pm
VLAN-Aware switch query... June 6, 2005, 10:28 am
Ethernet Vlan-aware switch query. May 4, 2005, 7:40 am
STP-RSTP query October 16, 2008, 3:29 am
igmp query and snooping October 6, 2004, 6:13 am
query on port speed specification January 5, 2008, 7:37 am
query on Port-mirroring on Marvell Board January 4, 2007, 4:32 am
Placement of Layer 3 3COM switch query May 31, 2005, 12:56 am
Query on MSTP(Force port state) July 15, 2007, 12:58 am
What is VLAN, how it is used?. I have 4 PC's on one LAN connectd to router, how can I apply VLAN concept here?. February 4, 2005, 1:16 am
Which router for vlan - vlan to internet September 7, 2004, 2:37 pm
Vlan Add and Vlan Strip August 30, 2004, 2:39 am
VLAN Help (for a Vlan newbie) November 6, 2006, 12:09 pm
