Ethernet LAN Promiscuous Mode on Sun BGE Network Driver Drops VLAN-tagged Packets
Subject Author Date
Promiscuous Mode on Sun BGE Network Driver Drops VLAN-tagged Packets Packet411 04-20-05
Posted by Packet411 on April 20, 2005, 2:02 pm
I've got a switch mirroring packets into a Sun V20Z with a BGE
interface running in promiscuous mode (using snoop to test this right
now). Some of the packets coming in have VLAN tags, and some do not. I
am only seeing packets without VLAN tags. I know the problem is not the
switch because I see all packets when I perform this test using BSD or
Linux.
I've done some reading on the subject and it appears that one way
around this is to create logical network interfaces, one for each VLAN
tag. The problem is, I don't know what VLAN tags I'm going to be
receiving ahead of time and I don't want to have to listen to 4094
logical interfaces just to be able to see all ethernet traffic!
Under Linux/BSD, setting the interface to promiscuous mode is
sufficient to get the kernel driver to forward all packets to the
listener. I'd like to know how I can do this with Solaris (I'm using
Solaris 9 presently). I've looked at the man pages for ifconfig, bge,
and ndd, and I have been unable to find any option that will set the
desired behaviour.
Did I miss something, or do I need to write my own device driver to get
this capability?
Posted by Robert Lawhead on April 20, 2005, 2:16 pm
Perhaps using tcpdump (presumably what you are using on linux) rather
than snoop would help confirm your observation and eliminate questions
about whether the traffic is present but unreported by snoop.  tcpdump
can make use of a vlan filter...
      vlan [vlan_id]
             True if the packet is an IEEE  802.1Q  VLAN  packet.   If
             [vlan_id]  is  specified, only true is the packet has the
             specified vlan_id.  Note  that  the  first  vlan  keyword
             encountered  in  expression  changes the decoding offsets
             for the remainder of expression on  the  assumption  that
             the packet is a VLAN packet.
- Bob
Packet411 wrote:
Posted by Packet411 on April 20, 2005, 6:04 pm
Hi Bob,
Thanks for your reply.
Actually, I already tried both snoop and tcpdump under Solaris.  Their
behavior is identical leading me to believe that the default packet
driver behavior is to not forward VLAN-tagged packets. :(
I'm watching switch stats, and I see packets flowing to the bge device
while tcpdump is running.  I then kill tcpdump after a few hundred or
more packets have been delivered, and this is all I see:
0 packets captured
0 packets received by filter
0 packets dropped by kernel
This is with tcpdump version 3.8.3.  It does not have the vlan tagging
option you mention in your email.  Unfortunately, according to the
output from tcpdump above, this is not a factor anyway as the device
driver itself has not captured any devices.
As soon as I switch to non-VLAN-tagged packets, everything works
perfectly.
I'd like to get hold of the bge driver source code to get to the bottom
of this.
Richard
Robert Lawhead wrote:
questions
tcpdump
If
the
keyword
offsets
that
right
not. I
the
or
VLAN
using
bge,
the
get
Posted by Andrew Gabriel on April 21, 2005, 1:34 am
I don't have a bge interface to verify this with, but I think the
issue is that each VLAN is presented as a separate pseudo interface,
so you would have to snoop the VLAN you are interested in.
For VLAN id 1 on bge0, this would be snoop -d bge1000,
for VLAN id 2 on bge0, this would be snoop -d bge2000,
for VLAN id 6 on bge3, this would be snoop -d bge6003,
etc.
As I said, I can't actually check this out though -- just guessing.
Andrew Gabriel
Posted by Robert Lawhead on April 20, 2005, 7:11 pm
I think you nailed it Andrew...
I found a link that may also be helpful at:
    http://docs.sun.com/source/817-6337-05/install-apps.html#pgfId-1006448
- Bob
Andrew Gabriel wrote:
Similar ThreadsPosted
Promiscuous Mode on Sun BGE Network Driver Drops VLAN-tagged Packets April 20, 2005, 2:02 pm
Promiscuous mode ether on WinXP December 10, 2005, 8:47 pm
Fiber card in promiscuous mode under linux June 13, 2007, 5:26 am
Connection to Switch Drops Packets But Hub Works July 10, 2007, 1:36 am
arbitrary packets on an ethernet network January 19, 2007, 5:11 am
MS-Dos 6.22 Packet Driver for 3COM 3C2000 ? March 13, 2007, 10:53 am
hacking ethernet driver - advice needed September 18, 2005, 5:28 am
Does DD-WRT include a Client Mode? May 3, 2005, 8:44 pm
1000BaseSX and Single Mode Fibre April 8, 2005, 12:15 pm
Uplink drops intermittently... April 20, 2006, 3:46 am
Ethereal Decoding 802.11 WEP Packets December 8, 2004, 5:01 pm
ping corrupted packets February 21, 2005, 12:19 pm
DVMRP report packets September 24, 2006, 10:25 pm
Seeing Packets on an Ethernet Port That Should Not Be There October 4, 2007, 11:54 pm
Using Jumbo packets in gigabit ethernet July 19, 2004, 1:08 am
Latest PostsForumRSS
Re: 871W: Wi-fi to Wi-fi unreliable Wireless Networking
c3560 port configuration Cisco Systems
Comics Previews iPhone 5 [telecom] General Telecommunications Forum
Insteon and other X10 alternatives? General Home Automation
Telecom Hardware Cisco Certification
Selling Routes “India Bangladesh & Sri Lanka” Voice-Over-IP
USB _to_ RJ45 (not from) connection Ethernet LAN
FAQ: Maximizing cable modem or DSL speed Cable Modems
CASH FOR CISCO - I BUY USED AND NEW EQUIPMENT & LOTS MOR... Telecom Technical
FAQ: Maximizing cable modem or DSL speed Digital Subscriber Line
How to set up Meridian 1 to "provide clock" to a C... Nortel Networks
NFL Soccer Jersey, NBA NHL Sports Jersey From China LAN and Telecom Cabling
Control Hot Water Circ Pump With X10? Home Automation
Text file to automate restoring a dropped VPN connection. Virtual Private Networks
Home Theater Installation Home Theater
Re: The Turkic Languages in a Nutshell Fiber Optics
sip Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Click Here to learn more
