Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on December 5, 2006, 2:58 am
Please log in for more thread options Is it feasible to setup a private LAN between 2-3 servers that are located across WAN? In my understanding, the private LAN is normally setup, when the servers are in local site. Also, we can setup a VLAN in this case, but it becomes a Public LAN. Am I right? | ||||||||||||||||
Posted by AM on December 5, 2006, 3:28 am
Please log in for more thread options qazmlp1209@rediffmail.com wrote: Are you looking for VPNs, perhaps? Or just enable cryptography in order to maintain the confidentiality of data among them. Alex. | ||||||||||||||||
Posted by rdymek on December 6, 2006, 2:29 am
You are looking for a VPN (Virtual PRIVATE Network). It is not a public LAN, it remains private to anyone who has credentials. You can even get more detailed by forcing remote VPN users to be part of a domain which would still control access to domain resources. A VLAN has nothing to do with what you are discussing. A VLAN segments your network locally and is layer 2 only (will not traverse a WAN). A VLAN is generally considered a separate subnet/network segment allowing multiple segments per switch. Without VLAN's, a separate switch would be required for each subnet. If you create a VPN it would accomplish what you are wanting to do but also requires cryptographic IOS or a PIX to be in the scenario. Ryan qazmlp1209@rediffmail.com wrote: > Is it feasible to setup a private LAN between 2-3 servers that are
> located across WAN? In my understanding, the private LAN is normally > setup, when the servers are in local site. Also, we can setup a VLAN in > this case, but it becomes a Public LAN. Am I right? | ||||||||||||||||
Posted by on December 6, 2006, 3:41 am
rdymek wrote: > You are looking for a VPN (Virtual PRIVATE Network). It is not a
Thanks for the information.
> public LAN, it remains private to anyone who has credentials. You can > even get more detailed by forcing remote VPN users to be part of a > domain which would still control access to domain resources. > A VLAN has nothing to do with what you are discussing. A VLAN segments
Now, (when VLAN cannot be used for it) I am curious to know about
> your network locally and is layer 2 only (will not traverse a WAN). A > VLAN is generally considered a separate subnet/network segment allowing > multiple segments per switch. Without VLAN's, a separate switch would > be required for each subnet. setting up a Public LAN with the 2-3 servers that are located across WAN. What are the options available to configure such a setup? | ||||||||||||||||
| Similar Threads | Posted |
| Private LAN across WAN?? | December 5, 2006, 2:58 am |
| private ethernet protocol number | March 19, 2008, 12:39 pm |
| Ethernet Braoadband connection to home, assigning static private IP addr? | May 21, 2005, 12:14 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
