Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Larry Martell on January 19, 2005, 5:43 pm
Please log in for more thread options point connection at 33Mbps. Other then LVDS what comm protocal supports these speeds? (I know USB does, but I have not found a USB host<-->host bridge that supports those speeds.) I know
ethernet does, but I've never seen it used in this manner. Is it
possible to directly connect 2 machines with a 100baseT cable and just talk to each other without TCP/IP? Is there software that supports such a beast? Thanks! -larry | ||||||||||||||||||||||
Posted by Walter Roberson on January 20, 2005, 3:12 am
Please log in for more thread options :point connection at 33Mbps. :Is it :possible to directly connect 2 machines with a 100baseT cable :and just talk to each other without TCP/IP? Yes. :Is there software that supports such a beast? Is there a particular need for it to not be TCP based? If so is there also a requirement that it not be IP based? 33 megabits per second of payload is well within the capabilities of any modern TCP or IP stack. In any case, you can write out raw ethernet packets, and the other end can read raw ethernet packets. You'll have a little bit of difficulty in getting the receiver's NIC to accept the packets. I suggest that you look at 'libpcap' which is well able to do the appropriate setup for capturing arbitrary packets. -- Cottleston, Cottleston, Cottleston pie. A bird can't whistle and neither can I. -- Pooh | ||||||||||||||||||||||
Posted by Dale Farmer on January 20, 2005, 10:01 am
Larry Martell wrote: > I have a requirment to communicate between 2 PC's over a point to
> point connection at 33Mbps. Other then LVDS what comm protocal > supports these speeds? (I know USB does, but I have not found > a USB host<-->host bridge that supports those speeds.) I know > ethernet does, but I've never seen it used in this manner. Is it > possible to directly connect 2 machines with a 100baseT cable > and just talk to each other without TCP/IP? Is there software > that supports such a beast? > > Thanks! > -larry Sure, just use a crossover cable instead of a straight through cable. What distance do you need to do this at? If you are talking more than the hundred meter limit of UTP without a repeater, then you start to hit a bunch of issues that make it way more expensive. You do need a good set of NICs, preferably matching ones to reduce finger pointing from vendors blaming the other guy rather than solving problems. --Dale | ||||||||||||||||||||||
Posted by Thomas Decker on January 22, 2005, 2:45 pm
Please log in for more thread options >
> Larry Martell wrote: > > > I have a requirment to communicate between 2 PC's over a point to
> > point connection at 33Mbps. Other then LVDS what comm protocal > > supports these speeds? (I know USB does, but I have not found > > a USB host<-->host bridge that supports those speeds.) I know > > ethernet does, but I've never seen it used in this manner. Is it > > possible to directly connect 2 machines with a 100baseT cable > > and just talk to each other without TCP/IP? Is there software > > that supports such a beast? > > > > Thanks! > > -larry >
> Sure, just use a crossover cable instead of a straight through > cable. > What distance do you need to do this at? If you are talking more than > the hundred meter limit of UTP without a repeater, then you start to > hit a bunch of issues that make it way more expensive. You do need > a good set of NICs, preferably matching ones to reduce finger pointing > from vendors blaming the other guy rather than solving problems. > > --Dale If you're talking more than 100 meter, you can either go to fiber-based Ethernet solutions (100BASE-FX/LX10/BX10), or to 10PASS-TS. 10PASS-TS will give you (more than) 33 Mbps over several hundred meters of voice-grade twisted pair. It is part of the recently approved "Ethernet in the First Mile" standard (IEEE Std 802.3ah-2004) and is based on VDSL. There are proprietary (pre-standard) solutions available on the market as well. Michael (remove "filter" from email address) http://www.ethernetinthefirstmile.com | ||||||||||||||||||||||
Posted by Tomi Holger Engdahl on January 20, 2005, 5:43 pm
> point connection at 33Mbps. Other then LVDS what comm protocal > supports these speeds? 100 Mbit/s comes to my mind first. > (I know USB does, but I have not found
> a USB host<-->host bridge that supports those speeds.) I know > ethernet does, but I've never seen it used in this manner. Is it > possible to directly connect 2 machines with a 100baseT cable > and just talk to each other Sure, just use a crossover cable instead of a straight through cable. With a crossover cable you can connect two PCs directly to each other. I have done this many times. > without TCP/IP? Is there software that supports such a beast?
Ethernet and TCP/IP usually come together. But there is no need to use TCP/IP protocol with Ethernet. Ethernet can support many different protocols, and with suitable software you can just send and receive "raw" Ethernet packets. -- Tomi Engdahl (http://www.iki.fi/then/) Take a look at my electronics web links and documents at http://www.epanorama.net/ | ||||||||||||||||||||||
| Similar Threads | Posted |
| Point to point communications over 100baseT | January 19, 2005, 5:43 pm |
| ethernet point to point wiring | October 28, 2005, 1:30 pm |
| MAC address of wireless access point | July 15, 2004, 12:53 pm |
| MAC addresses in router vs Access Point | May 1, 2008, 5:19 am |
| Windows PC As IEEE 802.11 Access Point | June 25, 2008, 4:43 pm |
| Difference between bridge and wireless access point?? | October 9, 2007, 6:57 pm |
| May I use a Linksys WRT54G router as secondary wireless access point? | January 25, 2006, 10:28 pm |
| Need Advice Regarding Communications / Networking Problem | September 24, 2004, 11:20 am |
| 10/100BaseT Impedance Mismatch | July 30, 2005, 10:17 am |
| 10BaseT links with 100BaseT | September 23, 2008, 6:20 pm |
| Historical Significant Internet Communications Technology:PSTN quality NextGen TCP/IP | February 6, 2005, 8:18 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
