Ethernet LAN Packet recorder
Subject Author Date
Packet recorder Tom D 08-08-07
|--> Re: Packet recorder Matthias Gruber08-08-07
Posted by Tom D on August 8, 2007, 11:36 am
I am looking for a packet recorder that supports Gigabit Ethernet
(1000BASE-T). This recorder will be used on an IP network.
The Solera Networks DS4500 with 5Gbps capture rate and 16 TB of storage is
roughly what I am looking for. However, it's not usually a good idea to
stop at the first product you happen upon.
I would like the unit to be 19" rack mount, but that is not a strict
requirement. RAID is preferable. Upgradeable is preferable.
This is for a data acquistion system. Therefore, storage space is
proportional to recording time.
Any pointers (URLs) to companies making something like this is helpful.
Thanks!
Posted by Matthias Gruber on August 8, 2007, 12:22 pm
http://www.wildpackets.com/products/omnipliance/overview
Posted by Patrick Klos on August 8, 2007, 2:27 pm
Our PacketView Pro product is designed to run on standard off-the-shelf
hardware under Windows 2000 or Windows XP. We have done a lot of work
to crank up the capture rate for "standard" hardware. I can't say for sure
what our maximum capture rate is (of course that depends largely on the
processor, memory and NIC adapter/driver), but I've never run across issues
where it has been unable to keep up with the packets on a gigabit network.
Feel free to contact me directly if you'd like to discuss details? If you're
local to southern New Hampshire (or eastern Massachusetts), I'll even bring
in a machine to test the capture on your network if you like?
Patrick
========= For LAN/WAN Protocol Analysis, check out PacketView Pro! =========
Patrick Klos Email: patrick@klos.com
Klos Technologies, Inc. Web: http://www.klos.com/
Similar ThreadsPosted
Packet recorder August 8, 2007, 11:36 am
XGMII end of packet July 20, 2004, 4:19 am
Generate packet with bad CRC June 21, 2007, 9:15 am
Packet capture November 28, 2007, 12:07 am
Creating a test packet October 13, 2005, 11:21 am
ethernet packet preamble May 4, 2006, 2:01 pm
determination of length of packet............ October 18, 2006, 1:41 am
Source MAC address per IP packet June 15, 2008, 3:02 pm
Packet Engines PowerRail 1000 April 26, 2005, 8:06 pm
Packet Coming From Router Disappears June 24, 2006, 2:45 am
MS-Dos 6.22 Packet Driver for 3COM 3C2000 ? March 13, 2007, 10:53 am
performance parameters of Ethrnet packet std IEEE 802.3 July 9, 2004, 2:23 am
Extract data from packet dump (pcap) January 12, 2005, 2:31 pm
slow smtp issue/packet capture December 18, 2006, 10:24 am
Does wireshark have the ability to edit and send packet?? Any other software have??? December 5, 2006, 3:03 am
