Ethernet LAN Packet Engines PowerRail 1000
Subject Author Date
Packet Engines PowerRail 1000 Angler 04-26-05
Posted by Angler on April 26, 2005, 8:06 pm
A blast from the past to be sure...
Does anyone know what the default login ID and password is for these
switches? I have aquired one and have console access...
Version 2.0.0r22 - 2 Feb, 1999
Copyright(c) 1997-1998 Packet Engines, Inc.
Spokane, Washington, USA
All rights reserved.
System MAC Address: 00:xx:xx:xx:xx:xx
Current Time: Apr 25, 2005 14:02
Was able to boot with no config by powering up and typing any key...
# Date Time Vers Size Name
1 2003-02-07 09:03:27 2.0.0r22 3027 startup.config
Select a configuration file by number,
or enter "0" for none,
or ESC to return to the previous menu: 0
Enter one of the following options:
'C' to select the EMM configuration file [*none*]
'D' to start Xmodem download [-]
'I' to select an EMM image to run [PR1000.sys]
'S' to set option for the serial BAUD rate [9600]
'ESC' to continue startup
Your choice:
[Selected config file is "*none*"]
[Invoking EMM image "PR1000.sys" from Onboard flash]
gEMM_SEEPROM.flash_size = 0x0080
[EMM image started (boot: is Onboard flash)]
[EMM MAC address: 00-xx-xx-xx-xx-xx]
Thanks in advance... Angler
Posted by Brian W. Antoine on April 26, 2005, 6:49 pm
As best I recall, it was "admin" and a blank password.
Posted by Angler on April 29, 2005, 1:17 am
Yep, that was it. Thanks.
Similar ThreadsPosted
Packet Engines PowerRail 1000 April 26, 2005, 8:06 pm
1000 Base T September 23, 2004, 9:16 am
Auto nego on 1000-X September 4, 2004, 9:29 am
Advice on cheap corp 10/100/1000 switch please June 9, 2007, 6:51 pm
Versions of the Intel Pro/1000 MT Quad Port Card February 22, 2007, 2:59 am
I have 10/100/1000 Mbps ports one side and two switches connected to each port, one is 10Mbps and other one is 100Mbps does auto-negotians will automatic?. February 6, 2005, 10:08 pm
XGMII end of packet July 20, 2004, 4:19 am
Generate packet with bad CRC June 21, 2007, 9:15 am
Packet recorder August 8, 2007, 11:36 am
Packet capture November 28, 2007, 12:07 am
Creating a test packet October 13, 2005, 11:21 am
ethernet packet preamble May 4, 2006, 2:01 pm
determination of length of packet............ October 18, 2006, 1:41 am
Source MAC address per IP packet June 15, 2008, 3:02 pm
Packet Coming From Router Disappears June 24, 2006, 2:45 am
