Ethernet LAN Multicast MAC and Unicast IP Address
Subject Author Date
Multicast MAC and Unicast IP Address Matthias Schaerer 08-18-05
Posted by Matthias Schaerer on August 18, 2005, 7:54 pm
Is it allowed to have a multicast MAC address linked to a unicast IP
address? If not what standard specifies this?
I know that this mechanism is used for clustering but that certain vendors
do not like it very much. I am interested in knowing what the rules are
because up to now everybody just told me that it is a strange way to use
multicast but some also said that it is illegal. Without proving it.
So let me know if you know about a standard specifying this.
Thanks.
Mat
Posted by Geert Jan de Groot on August 19, 2005, 2:43 pm
RFC1122, page 67:
When a host sends a datagram to a link-layer broadcast address,
the IP destination address MUST be a legal IP broadcast or IP
multicast address.
A host SHOULD silently discard a datagram that is received via
a link-layer broadcast (see Section 2.4) but does not specify
an IP multicast or broadcast destination address.
I can think of several stacks (including ones on which I've worked myself),
that would fail in the scenario you describe: they flag the packet
as broadcast (multicast = limited broadcast) and hence,
for instance TCP SYN packets are dropped on the floor in this case.
Geert Jan
Posted by Rich Seifert on August 19, 2005, 11:12 am
> RFC1122, page 67:
> multicast address.
The RFC discusses *broadcasts*; it is moot on the issue of *multicasts*.
A multicast is NOT a broadcast; the standards treat them as distinct
entities. I believe that the use of a multicast MAC address to send a
unicast IP packet to a group of devices (e.g., a cluster) is a perfectly
correct use of link-layer multicast, assuming that the cluster software
knows how to deal with the fact that multiple devices are receiving the
same IP datagram.
The reason for the wording of RFC1122 becomes clearer when one considers
that some link-layer technologies provide broadcast capability, but not
Ethernet-style multicast (e.g., ARCnet). The RFC simply says that
link-layer broadcast can be used to send IP broadcast or IP multicasts,
but not IP unicasts. The RFC says nothing about how one would use an
Ethernet-style multicast mechanism.
Rich Seifert Networks and Communications Consulting
21885 Bear Creek Way
(408) 395-5700 Los Gatos, CA 95033
(408) 228-0803 FAX
Send replies to: usenet at richseifert dot com
Posted by Matthias Schaerer on August 19, 2005, 8:20 pm
>>RFC1122, page 67:
>> multicast address.
> same IP datagram.
> (408) 228-0803 FAX
Hi Rich,
as I am no implementor or LAN HW I ask myself the question:
How if not by looking at the multicast bit does a switch decide to
multicast/broadcast a frame? I doubt that many implementors make a
distinction between broadcast and multicast by looking at more bits than
that one.
But you are right, it's not specified clear enough.
Thanks for your suggestion.
Mat
Matthias Schärer
Network Engineer, Instructor
Mob: +41 79 419 4557
http://www.anyweb.ch - All you want to know about taking care of
networks is here.
http://www.anyweb-osys.ch - All you want to know about networking
training is here.
(Don't be afraid to ask.)
In case of trouble with resending emails to me
mailto:matthias.schaerer@anyweb.ch
Posted by Rich Seifert on August 19, 2005, 12:31 pm
> that one.
The default action of a switch is the same for both multicasts and
broadcasts; the frame is forwarded onto all ports except the port on
which the frame arrived. Thus, for this simple case, the switch need
only look at the unicast/multicast bit, as you note.
The standards allow for more complex handling of multicast than this
simple default behavior, however. Automatic multicast pruning (e.g.,
using GMRP) can restrict the propagation of specific multicast addresses
onto specific ports. Manual configuration of the switch's forwarding
tables (by a network administrator) can also be used to control the
handling of specific multicast frames. In both of these cases, all 48
bits of the multicast must be examined in order to make the appropriate
forwarding decision. From the switch designer's perspective, it may be
easier to think of a multicast not as a "limited broadcast," but as a
unicast that may be forwarded onto more than one port. The entire
address is compared to the entries in a lookup table, which outputs the
set of ports onto which to forward the frame. The output for a unicast
will generally be only a single port; the output for a multicast will
generally be one or more ports. Thus, unicasts and multicasts are
processed identically.
(408) 228-0803 FAX
Similar ThreadsPosted
Multicast MAC and Unicast IP Address August 18, 2005, 7:54 pm
Picking an IP multicast address October 29, 2004, 1:03 pm
Multicast MAC in Source MAC Address Field August 30, 2005, 5:13 pm
Multicast test bed October 18, 2004, 8:51 am
multicast, MAC ending with 00:96 ? August 14, 2005, 12:55 am
ARP reply containing a multicast MAC OK? March 19, 2007, 4:50 pm
Multicast pruning July 2, 2008, 7:24 am
Multicast VLAN Id July 14, 2008, 7:41 am
Maximum MAC multicast filters? October 5, 2005, 8:48 am
Extreme Networks 300-48 Multicast issues January 11, 2005, 1:55 am
MAC address of an IPv6 address April 10, 2007, 4:42 pm
Mac address recovery December 17, 2004, 9:07 am
Change MAC address January 25, 2005, 8:53 am
Valid mac address February 7, 2006, 8:21 pm
Change MAC address June 20, 2007, 7:19 am
