Ethernet LAN Mac address recovery
Subject Author Date
Mac address recovery SnaZZZ 12-17-04
Posted by SnaZZZ on December 17, 2004, 9:07 am
Guys I hope someone can help with this Query.
I have a need to interrogate 24,000 networked devices in an organisation.
The only piece of info I require from the device is its Mac address.
Now I know a Fluke Device which is rather expensive is able to do this, but
I would like to know if there is any other way.
1. Not all devices have an IP address they are on DHCP, so a ping command
will not work. Once cable is removed no IP is assigned thus no Mac address.
2. Its needs to be an inexpensive way to get the Mac address either using a
laptop with crossover or a PDA type device with the right adaptor
3.The recovery of the Mac address will be done by semi-skilled staff (uni
students with little or no technical skill), so it needs to be easy
Can anyone suggest a device or solution.
Thanks in advance
SnaZZZ
Posted by on December 17, 2004, 10:27 am
> Thanks in advance
> SnaZZZ
snmp to your networking grear, ask for the mac-addr-table, correlate
with port used.
Why on earth do you need mac-address table for ? It won't be stable
for many minutes ...
Peter Håkanson
IPSec Sverige ( At Gothenburg Riverside )
Sorry about my e-mail address, but i'm trying to keep spam out,
         remove "icke-reklam" if you feel for mailing me. Thanx.
Posted by Walter Roberson on December 17, 2004, 11:08 am
:I have a need to interrogate 24,000 networked devices in an organisation.
:The only piece of info I require from the device is its Mac address.
:Now I know a Fluke Device which is rather expensive is able to do this, but
:I would like to know if there is any other way.
It's pretty much impossible to do reliably.
:1. Not all devices have an IP address they are on DHCP, so a ping command
:will not work. Once cable is removed no IP is assigned thus no Mac address.
ARP tables time out after 3 minutes usually, so missing device
while it is talking is a very real possibility if you try to
proceed by way of SNMP probes of the routers and switches.
:2. Its needs to be an inexpensive way to get the Mac address either using a
:laptop with crossover or a PDA type device with the right adaptor
:3.The recovery of the Mac address will be done by semi-skilled staff (uni
:students with little or no technical skill), so it needs to be easy
Ummm, I just realized that your wording leaves open the possibility
that you are planning to have staff go around to each of the
devices and use the gizmo to probe the MAC address. Is that
correct? Or are you trying to do this in an automated way from
a management program?
If the idea is to go around to each device, then you have to be
aware that there is no way to provoke a device that is certain
to make it respond. Devices can do whatever they want when
they receive packets, including ignoring the packets.
The Fluke LanMeter and later decendants do not reliably discover
MAC addresses: they more or less just wait for the host to say
something.
Any given PC or Unix machine might be firewalled to not respond
to probes. Some systems will, though, ARP for their own IP
address as they come up (or as the interface is brought up),
so as to detect whether another machine is already using
that IP address. You can thus usually get a machine to say
-something- by rebooting it.
Inevitably, someone will flame me about this .signature.
Posted by SnaZZZ on December 17, 2004, 11:47 am
That is correct I will be getting people to walk the floors and visit the
device individually.
Most of the devices in question are Multifunction devices , ie photocopier
that is a fax and printer as well
Need a Mac address so that a third party billing audit application database
can be populated.
Snmp will them be used once the connection has been made. Bi-directional
information things like meter readings and consumable status etc.
SnaZZZ
but
address.
a
> something.
Posted by on December 17, 2004, 12:22 pm
>can be populated.
I'm not sure that's going to work like you think, but most MF devices
will give you their MAC address on their test page printout.
If the "third party billing audit application database" knows about
MAC addresses, why can't it be the one to find them?
Similar ThreadsPosted
Mac address recovery December 17, 2004, 9:07 am
Problems with synchronization and clock recovery cause errors like... January 8, 2006, 5:49 pm
3C35100 CoreBuilder 3500 Administer password recovery April 17, 2006, 6:42 am
How to test Ring such as EAPS or RSTP recovery time? December 15, 2008, 12:45 am
MAC address of an IPv6 address April 10, 2007, 4:42 pm
Change MAC address January 25, 2005, 8:53 am
Valid mac address February 7, 2006, 8:21 pm
Change MAC address June 20, 2007, 7:19 am
MAC destination address July 19, 2007, 12:06 am
Change IP and MAC address December 10, 2007, 4:59 am
Mac address and VLAns June 17, 2008, 1:27 am
Router MAC address November 26, 2008, 10:34 am
Re: Router MAC address November 28, 2008, 9:00 am
multicast address May 12, 2009, 5:14 am
"illegal" or reserved MAC address ? August 22, 2004, 10:03 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
