Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by vicky on June 26, 2008, 4:00 am
Please log in for more thread options > > wrote:
onsulting
> > > Rich Seifert =A0 =A0 =A0 =A0 =A0 =A0 =A0Networks and Communications C= > > > =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 21885 Bear Creek =
Way
> > > (408) 395-5700 =A0 =A0 =A0 =A0 =A0 =A0Los Gatos, CA 95033
> > > (408) 228-0803 FAX >
> > > Send replies to: usenet at richseifert dot com
----=AD---
> > Hello Mr. Rich Seifert
> > I want to discuss some of my queries with u as some are not totally
> > asked by text so these also requires figures. > > but here its not possible to draw figure > > So can u give me u'r mail id =A0so that i send the queries in files to > > U.... >
lting
> Did you consider reading the signature on my posting? > > -- > Rich Seifert =A0 =A0 =A0 =A0 =A0 =A0 =A0Networks and Communications Consu= > =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 21885 Bear Creek Way
oted text -
> (408) 395-5700 =A0 =A0 =A0 =A0 =A0 =A0Los Gatos, CA 95033 > (408) 228-0803 FAX > > Send replies to: usenet at richseifert dot com > =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0*****************************- Hide qu= >
> - Show quoted text - -------------------------------------------------------------------- Hello Can u plz tell me about the DA (Destination Mac Address) and SA (Source mac Address) of a frame which contains multicast data (or multicast member ship requist or leave requist) is at this case is DA =3D=3D SA or SA contain a unique mac address of either router or host. Please tell me Thanks in advance Vikrant | ||||||||||||||||||||||||||||||||||||||||
Posted by Rich Seifert on June 26, 2008, 11:47 am
> Can u plz tell me about the DA (Destination Mac Address) and SA > (Source mac Address) > > of a frame which contains multicast data (or multicast member ship > requist or leave requist) > > is at this case is DA == SA > or SA contain a unique mac address of either router or host. > You really should read the relevant standards (IEEE 802.3, IEEE 802.1D/Q) and then ask your questions, rather that looking to this group to provide a tutorial on every aspect of your design. That said, a source MAC address is never a multicast; it is always a unique identifier of the station sending the frame, whether an end station or router. -- Rich Seifert Networks and Communications Consulting 21885 Bear Creek Way (408) 395-5700 Los Gatos, CA 95033 (408) 228-0803 FAX Send replies to: usenet at richseifert dot com | ||||||||||||||||||||||||||||||||||||||||
Posted by Walter Roberson on June 27, 2008, 12:53 am
>unique identifier of the station sending the frame, whether an end >station or router. It's been several years since I last looked at the relevant documentation, and memory certainly fades with disuse. Are there exceptions to the above statement that have to do with virtual redundancy protocols? I have this idea poking out of corner of my mind that the active master for VRRP (or perhaps it was a related protocol) assumes as the source MAC the multicast address for the redundancy group ? | ||||||||||||||||||||||||||||||||||||||||
Posted by on August 21, 2008, 2:13 pm
On Jun 26, 11:53=A0pm, rober...@hushmail.com (Walter Roberson) wrote: >
> >unique identifier of the station sending the frame, whether an end > >station or router. > It's been several years since I last looked at the relevant
> documentation, and memory certainly fades with disuse. > Are there exceptions to the above statement that have to do with > virtual redundancy protocols? FYI, what was going through my mind at the time was RFC 3768 Section 8.2 When a host sends an ARP request for one of the virtual router IP addresses, the Master virtual router MUST respond to the ARP request with the virtual MAC address for the virtual router. The Master virtual router MUST NOT respond with its physical MAC address. This allows the client to always use the same MAC address regardless of the current Master router. Section 8.3 If Proxy ARP is to be used on a VRRP router, then the VRRP router must advertise the Virtual Router MAC address in the Proxy ARP message. Doing otherwise could cause hosts to learn the real MAC address of the VRRP router. 7.3. Virtual Router MAC Address The virtual router MAC address associated with a virtual router is an IEEE 802 MAC Address in the following format: 00-00-5E-00-01- (in hex in internet standard bit-order) This is *not* in the multicast MAC range. Section 9.2 talks about use with Token Ring and indicates that MACs from 03-00-00-00-00-80 to 03-00-02-00-00-00 are used for this. The low order bit is set in this but because the next higher bit is set as well, this is Token Ring, not a broadcast or multicast address. But then, 5.2.2. Destination Address The IP multicast address as assigned by the IANA for VRRP is: 224.0.0.18 This is a link local scope multicast address. Routers MUST NOT forward a datagram with this destination address regardless of its TTL. So... we are into some fine distinctions in this discussion. In the case I was thinking of, VRRP, source -MAC- addresses will not be multicast, but the -IP- addresses are in the multicast range. But the VRRP does twist the second half of Rich's sentence, that >> it is always a
> >unique identifier of the station sending the frame, whether an end > >station or router. as VRRP uses a constant identifier (per instance) regardless of which system is master at the moment: it is "unique" in the sense that *only* the VRRP master is allowed to sendout such frames, but it is -not- "unique" in the sense that the same MAC could be from any of the configured VRRP servers, dependent on which one is in control at the time. | ||||||||||||||||||||||||||||||||||||||||
Posted by vicky on June 27, 2008, 1:01 am
Please log in for more thread options wrote:
> In article
> > > > Can u plz tell me about the DA (Destination Mac Address) =A0 and =A0 SA
> > is at this case =A0is =A0DA =3D=3D SA
lting
> You really should read the relevant standards (IEEE 802.3, IEEE > 802.1D/Q) and then ask your questions, rather that looking to this group > to provide a tutorial on every aspect of your design. > > That said, a source MAC address is never a multicast; it is always a > unique identifier of the station sending the frame, whether an end > station or router. > > -- > Rich Seifert =A0 =A0 =A0 =A0 =A0 =A0 =A0Networks and Communications Consu= > =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 21885 Bear Creek Way
> (408) 395-5700 =A0 =A0 =A0 =A0 =A0 =A0Los Gatos, CA 95033 > (408) 228-0803 FAX > > Send replies to: usenet at richseifert dot com ---------------------------------------------------------------------- Hi, please go to that link below to see my query stored in a file which is accessable as my query need some graphics along with it http://vikrantpandey.diinoweb.com/files/ and please answer me Thanks in advance Vikrant | ||||||||||||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Mac address and VLAns | June 17, 2008, 1:27 am |
| subclassed IP address ranges using 802.1Q VLANs | January 19, 2005, 3:25 pm |
| MAC address of an IPv6 address | April 10, 2007, 4:42 pm |
| 802.1q vlans trunking | June 13, 2005, 5:09 am |
| An interface on many VLANs | November 24, 2005, 8:05 pm |
| Two different VLANs on the same port | December 15, 2006, 8:02 am |
| VLANS and subnetting | September 30, 2007, 5:44 pm |
| VLANs on a 3COM Superstack III | July 21, 2004, 12:28 pm |
| 3Com untagged vs. 802.1Q VLANs | February 22, 2005, 1:44 pm |
| Multiple VLANs on Single NIC | January 19, 2006, 8:06 am |
| VLANs and VoIP phones | July 27, 2006, 8:07 am |
| Port Based VLANs | September 10, 2006, 2:28 pm |
| VPC or VMWare and Vlans an intersting one. | May 31, 2007, 2:29 pm |
| Use VLANs to limit Multicasting | March 14, 2008, 12:22 pm |
| Security of multiple VLANs and WiFi | March 3, 2005, 5:53 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
