Ethernet LAN Lan to Lan to internet routing problem
Subject Author Date
Lan to Lan to internet routing problem Zein 10-07-04
Posted by Zein on October 7, 2004, 8:48 am
Hi All,
I have two lans, the first one (Lan1) is connected to the second
(Lan2) by a leased line, utilizing 2 DLink 1500G SHDSL routers and
PPPoA.
The second lan (Lan2) is connected to the internet with a satellite
2-way connection using US Robotics 8000-2 broadband router.
My requirements are:
1- make Lan2 able to access Lan1 and the internet.
2 - make Lan1 able to access Lan2 and the internet through Lan2's
satellite connection
3 - Make Lan1's computers (or some of them) accessible from the
internet.
I was only able to do the first one.
The ip addresses on lan1 are 10.0.0.0/255.0.0.0
and the ip range on lan2 is 192.168.0.0 / 255..255.255.0
The ip address of Lan1's SDSL router is :10.0.0.101
The ip address of Lan2's SDSL router is :192.168.0.1
The ip address of Lan2's satellite router is :192.168.0.250
I configured the default route on Lan1's SDSL router to direct all
traffic through the leased line connection,
I then configured the default route on Lan2's SDSL router to the
satellite router :
0.0.0.0 mask 0.0.0.0 gateway 192.168.0.250
, and added the static route on Lan2's SDSL router :
10.0.0.0 mask 255.0.0.0 gateway 192.168.0.1
The default gateway on Lan1 is :10.0.0.101
The default gateway on Lan2 is :192.168.0.1
I was able to access Lan2 from Lan1 , and access Lan2 from Lan1.
I was also able to access the internet from Lan2.
However , I can't access the internet from Lan1, although I am able to
ping the satellite router (192.168.0.250)
The SDSL router on Lan2 is routing the requests of both lans to
192.168.0.250, but only Lan2's pings are successful, while Lan1's
pings fails.
Can anyone help me with this?
Thanks in advance
Posted by Alexey G. Khramkov on October 8, 2004, 1:15 am
i.basheer@gmail.com (Zein) writes:
> Hi All,
Hello.
> PPPoA.
> internet.
OK
> satellite router :
OK
May be overkill. If this SDSL has interface with 10.x.x.x address it will
route by default. But it's not mistake.
Perfect.
Wrong.
the default would be 192.168.0.250.
if the 250 <-> 1 channel is wide, it would be OK (good) without adding
routing table for 10.x.x.x (lan1) on each workstation (WS) in the lan2.
I suggest static routing tables on all lan2 WSes. It will be OK (perfect)
lan2 configuration.
I sure your browser "freezes" on some seconds when you establish
new connection to Internet. It's happen because payload of your
lan2 is 33% on this stage. Reason: bad choice of default router.
Nothing unusual.
> pings fails.
Again, nothing unusual. Lan2 SDSL is fake router for Internet.
Frankly, it's not a router for Internet at all.
Your main mistake is missing routing for 10.x net on 250 _real_
router. If you add something like:
250# route add -net 10.0.0.0 mask 255.0.0.0 gateway 192.168.0.1
you will solve your Internet trouble for lan1. But I can't call
lan2 configuration OK (not good, not perfect). It will "just work".
> Thanks in advance
HTH,
agkhram
status = rule("RFC1855"); /* avoid flame wars */
Posted by Zein on October 8, 2004, 4:06 am
Thanks a lot.
I had to configure and assign the SDSL router on lan2 (192.168.0.1 )
as the default router because the usr8000 (the internet router) does
not seem to have static routing nor RIP( although it's mentioned in
the manual that it does!) .
Do you think there is a solution without using static routing or RIP
on the usr8000?
Thanks again
> > Hi All,
> Hello.
> > PPPoA.
> > internet.
> OK
> > satellite router :
> OK
> Perfect.
> Wrong.
> lan2 configuration.
> Nothing unusual.
> > pings fails.
> > Thanks in advance
> HTH,
> agkhram
Posted by Alexey G. Khramkov on October 14, 2004, 12:22 am
> Thanks a lot.
> on the usr8000?
No. Router can transfer packet to hosts in own local net (interface
with assigned address). Thus usr8000 can transfer packets only to
192.168.0.0/24 hosts. Other hosts are redirected to Internet or
will be dropped.
Workaround requirements: outgoing packets must have 192.168.0.x
addresses. So the solution is NAT. If SDSLs can make NAT it will be
perfect. Otherwise you have to install new host with NAT/proxy
services.
> Thanks again
HTH,
agkhram
Similar ThreadsPosted
Lan to Lan to internet routing problem October 7, 2004, 8:48 am
Routing problem December 12, 2005, 9:48 pm
Need a metaphor for routing March 30, 2006, 9:01 am
VLAN Routing June 21, 2007, 6:28 pm
VLAN Routing June 21, 2007, 6:32 pm
IGMP routing startup October 19, 2004, 2:14 pm
Inter VLAN Routing July 28, 2005, 3:18 am
Inter VLAN routing October 13, 2006, 12:36 pm
Desktop switch kills routing November 30, 2004, 1:19 pm
Routing between VLANs using a Layer 3 Switch March 24, 2005, 11:39 am
How-to Print w/inter-vlan routing? February 8, 2006, 2:40 pm
Help: Low-Cost Switch with VLAN routing / LAN Segmentation? October 17, 2005, 3:04 pm
static routing in addition to DHCP on my router. January 25, 2006, 11:47 pm
3Com Superstack 4500 VLAN routing December 18, 2006, 10:33 am
