Ethernet LAN Is there such a thing as an "SC Crossover" coupler or cable
Subject Author Date
Is there such a thing as an "SC Crossover" coupler or cable ohaya 09-24-04
Posted by ohaya on September 24, 2004, 9:07 pm
We need to connect two GigE fiber interfaces, but we're still waiting
for a switch to arrive.
Is there such a thing as a crossover cable, that will cross over the
transmit and receive, and with SC/female receptacles on both ends?
I've been googling, but so far no luck.
Also, I think these interfaces came with some straight-through couplers
which allow us to extend the cables. Can we just plug the cable from
one interface cable into the coupler, and do the same for the other
interface cable, but "backwards", thus forming a cross-over?
Sorry if these are dumb questions, but I haven't worked much with fiber
connections before.
Thanks in advance,
Jim
Posted by JD on September 24, 2004, 9:16 pm
A SC duplex cable (2 SC connectors on a "zip" pair of fiber) will
probably have the two SC connectors placed side-by-side with a plastic
housing that keeps them paired. Some housings simply have the SC snap
into them, others have a plate that you have to slide out of the way to
remove the connectors so you can swap them.
On the "zip" cable one of the fibers will have labling on it noting the
fiber type and length markers. We will put a wire tie on (barely snug)
that lead of a patch cable at both ends, it helps us identify a fiber of
the pair. One end with a wire tie will go into the xmit of the fiber
interface on device A, and the corresponding end goes to the rcv
interface on devicd B.
JD
ohaya wrote:
> Hi,
> connections before.
> Thanks in advance,
> Jim
Posted by ohaya on September 25, 2004, 11:15 am
JD,
I've seen some "SC-to-SC Patch" cables (vs. "SC-to-SC Duplex Patch"
cables), and they look similar, except that the "Duplex" cables have a
housing attaching the two SC connectors together.
But I noticed that some of the ones not labelled "Duplex" have black
tips, instead of white tips. For example, here's a non-Duplex labelled
cable:
http://www.microcenter.com/single_product_results.phtml?product_id=0163916
and here's one labelled "Duplex":
http://www.microcenter.com/single_product_results.phtml?product_id=0093906
Also, it might be just be me, but it looks like the black tips are
LONGER than the white tips?
I'm thinking that if I got one of the former cable, since the connectors
are not tied together, I could easily swap the ends to make my
"crossover"?
Jim
> JD
> ohaya wrote:
> > Hi,
> > connections before.
> > Thanks in advance,
> > Jim
Posted by ohaya on September 25, 2004, 11:16 am
Oh, I forgot one other question: If you look at the description on
those links, it says "100 Mbps". I thought we should be able to run
GigE over these fiber optics cables?
Jim
ohaya wrote:
> JD,
> cable:
> "crossover"?
> Jim
> > JD
> > ohaya wrote:
> > > Hi,
> > > connections before.
> > > Thanks in advance,
> > > Jim
Posted by ohaya on September 25, 2004, 5:57 pm
I went into the office this morning, and found that we had a bunch of
plastic "SC couplers". These are small plastic things and have female
receptacles on both ends. Their meant to allow you to extend the SC
cable by plugging in SC patch cables.
But, I also looked at some SC cables we have, and they have those small,
longer white tips. I would really like to try to do the crossover with
one of the cables that I linked below, probably the non-duplex one (so I
wouldn't have to split the connectors apart, with one of these SC
couplers on each end.
Can anyone confirm that the black and the white tips won't make a
difference, i.e., would work?
Thanks,
Jim
ohaya wrote:
> Hi,
> Jim
> ohaya wrote:
> > JD,
> > cable:
> > "crossover"?
> > Jim
> > > JD
> > > ohaya wrote:
> > > > Hi,
> > > > connections before.
> > > > Thanks in advance,
> > > > Jim
Similar ThreadsPosted
Is there such a thing as an "SC Crossover" coupler or cable September 24, 2004, 9:07 pm
Has anyone ever seen a crossover AUI cable? May 20, 2005, 6:39 am
Problem with Crossover Cable August 28, 2005, 2:18 pm
LF: Crossover Ethernet Cable 25 feet August 25, 2006, 3:27 pm
Supply Mini-Com Coupler Modules ,Mini-com Coupler Modules,Panduit Mini-com Coupler Module,Panduit Minicom Modules,Panduit Mini-Com Module,Panduit Mini-com Fiber Optic Adapter Modules April 23, 2006, 9:49 am
Crossover Vs. Patch Cables March 9, 2006, 11:15 am
Crossover function in the standard. June 23, 2008, 4:34 pm
802.3ad Link Aggregation between two hosts using crossover cables January 24, 2005, 11:23 am
D-Link DSL-500 Console Cable October 25, 2004, 2:19 am
Router Works With DSL, not Cable January 22, 2005, 1:41 pm
Extending cable range September 1, 2005, 8:58 am
makeing cable longer December 18, 2005, 2:16 pm
makeing cable longer December 18, 2005, 3:06 pm
Does Anyone Make a 1/2 U Cable Organizer? July 15, 2006, 3:27 pm
Running Cat5 cable outside March 10, 2007, 7:05 pm
