Ethernet LAN I have Netgear WLAN Router, how can I can howmany laptops can be connected simultaneously?
Subject Author Date
I have Netgear WLAN Router, how can I can howmany laptops can be connected simultaneously? santa19992000 12-14-04
Posted by on December 14, 2004, 9:29 pm
I have Netgear WLAN Router (connected to Broadband through DSL), how
can I know howmany laptops can be connected simultaneously to the
Router?. How I will know?.
Also I can see "Data Rate/Channels: 1-54MBps / 14 channels)". What is
the Channels meaning here?. is it Maximum of 14 laptops can be
connected simultaneously?.
Thanks in advance.
Posted by Walter Roberson on December 15, 2004, 8:35 am
:Also I can see "Data Rate/Channels: 1-54MBps / 14 channels)". What is
:the Channels meaning here?. is it Maximum of 14 laptops can be
:connected simultaneously?.
No, there are 14 frequency bands allocated, with different subsets
of those being legal to use in different parts of the world. My
probably incorrect recollection is that channel 14 is
only authorized in France (which doesn't allow some of the
lower-numbered bands.)
When the radio is transmitting on a particular "channel", then
the peak energy is going to frequencies near the official channel.
However, with 802.11b there is also significant energy transmitted
in the two frequency ranges on other side of the centre. This causes
some degree of interference with transmissions on those other channels --
for example, if there is a nearby device transmitting on channel 8
then the energy it transmits in the range allocated to the centre
of channel 6 might turn out to overwhelm the energy from a more
distant device which is transmitting its peak energy in channel 6.
Because of this overlap and potential for interference, you will
often hear the guideline that that if you have multiple devices
in an area, you should set them to be 5 channels apart, such as
using channels 1, 6, and 11. That should be understood as a guideline
and not a hard rule, though: it depends on your antennae and the
signal strength from the overlapping chanels -- and there is a lot
of redundancy in the transmitted data. Someone did an analysis of
the energy patterns and determined that in all but the worst cases
(device very close to each other), you could safely use channels
that are only 3 apart, thus getting 4 effectively non-overlapping
channels in the range of 11 that are permitted in USA/Canada.
802.11g works on similar principles, but is defined in such a way
as to effectively "hard-code" the 1/6/11 guideline -- you only
have a choice of 3 channels for 802.11g.
802.11a does NOT work on the same principles, and all of its channels
can be used without interference.
:I have Netgear WLAN Router (connected to Broadband through DSL), how
:can I know howmany laptops can be connected simultaneously to the
:Router?. How I will know?.
It depends on -which- Netgear device you have. The reference to 54
megabits per second and to channel 14 lead me to suspect you have one
of the 802.11g routers such as Netgear's WGR614. It is often quite
difficult to find information about how many devices an AP/router
supports. What you are looking for is the "size of the MAC table" or
"number of entries in the ARP table".
I happen to have researched this figure a couple of weeks ago for the
Linksys WAP54G. Linksys apparently told someone the limit was 5000. One
highly respected wireless expert over in alt.internet.wireless (the
place I suggest you post nearly all your wireless questions to) tested
the Linksys WAP54G and found it can handle 253 clients.
I'm going to hazard a guess that your Netgear might be the
WGR614v4. If so, then if you look in the reference manual in the
Key Features of the Router section, you will find:
Parents and network administrators can establish restricted access
policies based on time-of-day, web site addresses and address
keywords, and share high-speed cable/DSL Internet access for up to
253 personal computers.
253 is the same number given in the v1 and v5 reference manual;
I'm not going to bother looking at the v2 and v3 reference manual
for completeness ;-)
IMT made the sky
Fall.
Posted by stephen on December 15, 2004, 11:14 am
just be aware that there is likely to be a much lower limit on the number of
simultaneous wireless devices (as opposed to devices connected via ethernet)
alt.internet.wireless is a good place to ask, but i would be surprised if
the Netgear can handle more than 15 or so wireless devices.
> IMT made the sky
> Fall.
Regards
Stephen Hope - return address needs fewer xxs
Posted by jpd on December 16, 2004, 2:56 am
[other good points snipped for brevity]
Japan, actually. They started out with _just_ 14, but now they also (or
instead?) allow 1..13. France also had some weirdness. It involved only
allowing channels from say 10 to 13 or something like that. I can't seem
to find it so I'm tempted to think they've conformed to the ETSI range
of 1..13. Canada allows 1..11 like the usa and apparently the rest of
the americas (give or take things like the mexican quirk that you can't
use 1..8 outdoors).
This is all about the 2.4GHz band for 802.11b (and, mostly, g), and that
makes 11 channels available. The other three simply aren't legal to use.
But wait! Add channels 36, 40, and 44 in the 5GHz band for 802.11a, for
north america, presumably including canada, and you get 14 channels
total. Isn't marketing great?
I've taken this from appendix a of a cisco aironet ios config guide.
A bit of googling suggests this is the working version but there may
be some more quirks hidden in laws and regulations around the world.
[snip!]
I think the thing can do at least two out of three, at least one of
which is `a', or maybe all three, since no other combination has a
`14' popping up anywhere in north america.
j p d (at) d s b (dot) t u d e l f t (dot) n l .
Posted by James Knott on December 16, 2004, 1:23 am
So, what else is new? ;-)
> use 1..8 outdoors)
People with amateur radio licences can use other channels as well as much
more power.
Similar ThreadsPosted
I have Netgear WLAN Router, how can I can howmany laptops can be connected simultaneously? December 14, 2004, 9:29 pm
ADSL Router connected to another router problem September 28, 2006, 3:34 am
Router connected to a switch. How does it work? December 3, 2004, 6:18 am
Netgear WGT624 V2 Router July 7, 2004, 2:28 pm
Netgear router setup problem January 7, 2006, 6:56 pm
Link connected question January 30, 2007, 8:05 pm
Max number of switches connected (cascading) ? July 18, 2005, 3:05 am
PoE powered device connected to the not PoE switch August 23, 2005, 4:25 am
Network switch crashes when at least 3 computers connected July 29, 2005, 3:53 pm
Who is DHCP server for my Router's WAN port connected to Cable modem? April 9, 2005, 4:21 pm
I have 10/100/1000 Mbps ports one side and two switches connected to each port, one is 10Mbps and other one is 100Mbps does auto-negotians will automatic?. February 6, 2005, 10:08 pm
Netgear FS526T January 25, 2005, 8:48 pm
NetGear WGU624 March 16, 2006, 6:37 pm
Voyager 205 and Netgear FS605 May 6, 2005, 6:00 pm
