Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by L on October 1, 2004, 12:00 am
Please log in for more thread options We don't want to use Ethereal to capture millions of lines. Is there a way to limit the capturing buffer size of Ethereal so we can capture certain lines, say 2000? Thanks, T. -- | |||||||||||||
Posted by Arnold Nipper on October 1, 2004, 2:57 am
Please log in for more thread options Use the -c option of tethereal ... or if you use thw windoze version: click on "Capture" then "Start" and chose your limit. Either number of packets, megabytes or minutes. Arnold -- Arnold Nipper, AN45 | |||||||||||||
Posted by L on October 1, 2004, 6:01 pm
Please log in for more thread options Thanks. It works!
T. -- > On 30.09.2004 23:00 L wrote:
> > > Hi,
way
> > > > We don't want to use Ethereal to capture millions of lines. Is there a > > to limit the capturing buffer size of Ethereal so we can capture certain
> > lines, say 2000? > > >
> Use the -c option of tethereal ... or if you use thw windoze version: > click on "Capture" then "Start" and chose your limit. Either number of > packets, megabytes or minutes. > > > > Arnold > -- > Arnold Nipper, AN45 | |||||||||||||
Help - how to adjust capture buffer size of Ethereal?
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> lines, say 2000?
