Ethernet LAN Good wireless bridge?
Subject Author Date
Good wireless bridge? DaveC 04-29-05
Posted by James Knott on April 30, 2005, 4:58 pm
Airhead wrote:
>> So a router can be used in Client mode? It can talk to APs?
> Only if it supports AP Client Mode otherwise a wireless router AP
> wont talk to another wireless router AP. The other issue is how many
> MACs will an AP client pass.. 1 for sure, note the word client and not
> clients. AP client mode is really acting as a wireless adapter
> converting
> a non-wireless device to wireless. Allot of devices such as myWAP54G
> use WDS and has AP, Bridge, Repeater and Client mode.
> Repeater mode and Client mode will talk to an AP, Bridge mode
> talks to another bridge.
FWIW, there are some Linksys models than run on Linux and can be configured
to do things far beyond what the designers intended. There is even one
package available, that's essentially a "hot spot in a box", for use in a
coffee shop etc.
Posted by DaveC on April 30, 2005, 5:47 pm
On Sat, 30 Apr 2005 05:25:03 -0700, Airhead wrote
> Repeater mode and Client mode will talk to an AP, Bridge mode talks to
> another bridge.
Thanks for that. Now that I've got the terminology down, I'm looking for a
device (regardless of what it's called) that can operate in client mode.
Since I the existing remote AP cannot be changed, bridge mode it out of the
question.
I like a lot of the D-Link devices, many of which operate in client mode.
Thanks again,
Please, no "Go Google this" replies. I wouldn't
ask a question here if I hadn't done that already.
DaveC
me@privacy.net
This is an invalid return address
Please reply in the news group
Posted by James Knott on April 30, 2005, 4:56 pm
Philip J. Koenig wrote:
> A WiFi access point is simply an ethernet to WiFi bridge, so I
> assume what the OP wants is just a recommendation for a WiFi AP?
> Since WiFi AP's these days tend to be more expensive than WiFi
> routers, and because (according to Jeff Liebermann) most WiFi
> routers have an undocumented "AP" mode which can be used simply
> by plugging an ethernet cable into the LAN side and leaving the
> WAN side unconnected, you may want to consider that direction
> if price is an issue.
What I did, was connect a Wifi router to a 3rd NIC on my Linux firewall.
This way, Wifi is outside my firewall and the only way in, is via ssh or
VPN. I also have WEP enabled.
Posted by John R Pierce on May 2, 2005, 9:22 pm
On Fri, 29 Apr 2005 17:17:14 -0700, Philip J. Koenig
Most routers do NOT support client mode, however, which is needed for the
far end of a bridge, at least not without doing custom linux firmware
hacking or whatever.
Posted by Walter Roberson on April 29, 2005, 6:47 pm
:I want a wireless bridge (is that redundant?)
No, most WiFi equipment these days does not have a briding mode
[at least not in the shipped versions.] Some of the more stable and
reliable bridges that have been on the market for years are quite
restricted as to which systems they will connect to -- sometimes
only to the exact same model, sometimes only to devices by the same
manufacturer.
Wireless bridges that follow a standard and so should interoperate
[in theory] use 'WDS', "Wireless Distribution Standard". If a device
you are examining does not advertise WDS, then it isn't the right one
for you [short of replacing the firmware]; if the devices you want to
connect to are not WDS, then you might not be able to connect to them
from anything other than a device made by the same manufacturer.
:to act as an ethernet
:converter, connecting to different brand APs (one at a time, of course).
:Would like to buy only 1 bridge and have it work with other brands of APs. An
:external antenna connector would be a plus.
:I hear good things about D-Link's DWL-900AP+, rev C.
I have no particular models to suggest at the moment, just general
comments:
1) Read the reviews in places like pcmag and tomsnetworking and amazon .
When I was last looking around a few weeks ago, it was quite
discouraging: the top-rated consumer-level 802.11g devices were
at 6 out of 10 or less in customer satisfaction. Mass sales is no
guarantee of quality.
2) Read the reviews again, and read the informal reports in places
like alt.internet.wireless and dslreports.com, this time with a view
to what customers are saying about their support experiences with the
companies. -My- quick summary, looking at those reports, would be
"If one of the devices works for you in -your- circumstances, then
Great! -- but that doesn't mean it will work for everyone. If you
are having a problem with it, and it is from any of the well-known
commodity WiFi manufacturers, chances are that you will be
disenchanted by the support organization, with a significant chance
that you will end up swearingly up and down that you will never
EVER buy from that manufacturer again."
Or to put things another way: If it works for you, then it works
for you; if it doesn't work for you, then be prepared to throw it
out (or sell it on eBay). You seldom get serious support attention
from a WiFi manufacturer unless you have paid several times the
going commodity-device price.
History is a pile of debris -- Laurie Anderson
Similar ThreadsPosted
Good wireless bridge? April 29, 2005, 5:52 pm
"Wireless Ethernet Bridge" and security ? April 9, 2005, 9:31 pm
Difference between bridge and wireless access point?? October 9, 2007, 6:57 pm
Well it seemed like a good idea... April 26, 2006, 11:05 am
802.11 to 802.15.4 bridge March 20, 2005, 8:10 pm
What would be a non-transparent bridge? December 15, 2004, 10:44 am
Looking for a good article on "Metro Ethernet" September 3, 2006, 1:33 pm
To compute number of Good symbols September 22, 2006, 7:08 am
What's a good place to buy networking gear? February 20, 2008, 6:51 pm
VLAN unaware bridge May 5, 2008, 1:56 am
FDDI to Fast Ethernet "Bridge" Available? October 1, 2008, 11:38 pm
FDDI to Fast Ethernet "Bridge"? October 1, 2008, 11:42 pm
Does someone have IGMP snooping source code for Bridge?? May 30, 2006, 9:06 am
Is Gigabit Ethernet (GigE) A Good Choice For Business Bandwidth? April 24, 2007, 8:03 pm
Is Gigabit Ethernet (GigE) A Good Choice For Business Bandwidth? April 24, 2007, 8:44 pm
