Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on August 3, 2006, 12:11 pm
Please log in for more thread options I had an odd experience the other day while building a Linux machine. I was installing Puppy Linux on an old computer, and set it up for DHCP. I have two main machines in my office connected to a 5 port Linksys 10/100 workgroup hub. one an XP Pro machine that is my main desktop, and the other a SUSE 10 Linux box acting as DHCP server and backup server. Once I had Puppy Linux installed and configured, I started to test connectivity, surf the web, use rdesktop, etc. When this happened I noticed my XP machine (only) got knocked offline. I shut off the Puppy Linux machine and I still had problems until I physically removed the ethernet cable from the Puppy's network card. I tried setting Puppy up for static IP, but ran into the same problem. I then installed Damn Small Linux with similar results. Again, in both cases, lost network conenctivity in XP until I pulled the network cable. SUSE Linux seemed to be fine during all this. The only thing I can think that might be a problem is both Puppy and DSL asked for a broadcast address which might be causing a problem wth the hub? Shere SWAG here. I'd like to hook the Puppy/DSL linux box up to a Linksys SD216 switch on a network with win2k and SUSE 10 machines and am wondering if I might experience the same problem. I can't afford to have machines go offline for whatever reason. Any thoughts? What am I not seeing or configuring properly? Thanks- Brian | ||||||||||||||||
Posted by Robert Redelmeier on August 3, 2006, 2:03 pm
Please log in for more thread options bpanders71@hotmail.com wrote in part: > Once I had Puppy Linux installed and configured, I started
> to test connectivity, surf the web, use rdesktop, etc. > When this happened I noticed my XP machine (only) got > knocked offline. I shut off the Puppy Linux machine and I > still had problems until I physically removed the ethernet > cable from the Puppy's network card. > I tried setting Puppy up for static IP, but ran into the
> same problem. I then installed Damn Small Linux with > similar results. Again, in both cases, lost network > conenctivity in XP until I pulled the network cable. > SUSE Linux seemed to be fine during all this. First, the stupid question: you aren't plugging the Puppy into a Xover port next to the XP machines cable? Some small switches/hubs have one more jack than their capabilities. That extra jack is an XOver for uplink. Otherwise, dump the arp and route tables from the Linux DHCP server. This seems more hardware than software. Try a different hub. -- Robert | ||||||||||||||||
Posted by on August 3, 2006, 2:40 pm
Robert Redelmeier wrote: > First, the stupid question: you aren't plugging the Puppy
> into a Xover port next to the XP machines cable? Some small > switches/hubs have one more jack than their capabilities. > That extra jack is an XOver for uplink. > > Otherwise, dump the arp and route tables from the Linux DHCP server. > This seems more hardware than software. Try a different hub. > > -- Robert No, I've got the port next to the Xover empty. I'll dig up another hub and give it a go. Thanks! Brian | ||||||||||||||||
Posted by Perkowski on August 4, 2006, 1:22 pm
Im not a network guru, but, could it be possible you dont have enough range for the IP addresses set correctly for your DHCP server? I know if a machine takes the same IP address from another that machine gets booted off the network???? Perkowski > Robert Redelmeier wrote:
> > into a Xover port next to the XP machines cable? Some small > > switches/hubs have one more jack than their capabilities. > > That extra jack is an XOver for uplink. > > > > Otherwise, dump the arp and route tables from the Linux DHCP server. > > This seems more hardware than software. Try a different hub. > > > > -- Robert >
> No, I've got the port next to the Xover empty. I'll dig up another hub > and give it a go. Thanks! > > Brian > | ||||||||||||||||
Posted by on August 4, 2006, 2:39 pm
Perkowski wrote: > Im not a network guru, but, could it be possible you dont have enough range
> for the IP addresses set correctly for your DHCP server? I know if a > machine takes the same IP address from another that machine gets booted off > the network???? > > Perkowski Interesting thought, but I have 95 IP addresses available for my DHCP server with only a half dozen DHCP enabled machines (including the XP machine in question), the rest are all static IP. The good news is this machine is destined for a remote office with only static IP, if this is indeed the case. Thanks for the idea- Brian | ||||||||||||||||
| Similar Threads | Posted |
| Going Offline with XP & Linux on same hub | August 3, 2006, 12:11 pm |
| IGMP for Linux | November 3, 2004, 3:09 pm |
| D-LINK DFE 530TX+ with LINUX | July 10, 2006, 10:50 am |
| Fiber card in promiscuous mode under linux | June 13, 2007, 5:26 am |
| Cisco 3700, SMC TigerSwitch, Linux and VLAN Problems | June 2, 2006, 12:44 am |
| VIA VT6102 Rhine-II + RealTek RTL8139C : file transfer hangs on Linux | July 1, 2005, 6:36 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> backup server.
