Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Matt on July 26, 2005, 10:15 am
Please log in for more thread options I'm having this question, what brand of full Gigabit core router/switch would you recommend for small local ISP ? It should comply with this requirements: + at least 2 Gigabit Ethernet ports + BGP4 (at least several ten thousands prefixes, at least 100 neighboroughs) + 802.1q vlans + remote access (ssh or telnet) and serial consoe, web management + at leasr snmp v2 + full rate gigabit routing with small packets What brand do you recommend ? Enterasys (f.e. Matrix E-1), Extreme Networks (f.e. Summit X450 or 5i), Huawei (NE08). Please list the one you have positive experience. Thanks, Matt | ||||||||||||||||
Posted by Michael Roberts on July 26, 2005, 3:11 pm
Please log in for more thread options Nortel's 8600 would work great for you. You can get six slot chassis that are redundant. You may also want to look into a Juniper M7i. -mike Matt wrote: | ||||||||||||||||
Posted by Wayne on July 27, 2005, 5:53 am
> would you recommend for small local ISP ? > It should comply with this requirements: > + at least 2 Gigabit Ethernet ports > + BGP4 (at least several ten thousands prefixes, at least 100 > neighboroughs) > + 802.1q vlans > + remote access (ssh or telnet) and serial consoe, web management > + at leasr snmp v2 > + full rate gigabit routing with small packets > > What brand do you recommend ? > Enterasys (f.e. Matrix E-1), Extreme Networks (f.e. Summit X450 or 5i), > Huawei (NE08). Please list the one you have positive experience. > > Thanks, > Matt > I think a Cisco Catalyst 3750 (or even a 3560, EMI either way) should actually do the trick. | ||||||||||||||||
Posted by Matt on July 27, 2005, 3:51 am
well it should be something as like Cisco 7301 or Juniper M7i, but cheaper. | ||||||||||||||||
| Similar Threads | Posted |
| Gigabit core router/switch | July 26, 2005, 10:15 am |
| Ethernet Switch With a PC at Core | April 19, 2005, 12:26 am |
| Relationship between Cable core diameter and current in CAT-5 | November 15, 2004, 5:47 am |
| gigabit and 1000baseT | October 23, 2004, 10:12 pm |
| gigabit pricing | December 6, 2004, 6:09 pm |
| Gigabit over bad wires? | February 28, 2006, 7:29 pm |
| Gigabit Ethernet PHY without NDA? | December 17, 2008, 5:11 am |
| gigabit switch chip | August 23, 2004, 5:23 am |
| Achieved ~Gigabit on tests - now what? | October 18, 2004, 11:02 pm |
| Non-PCI gigabit Ethernet controller | April 14, 2005, 6:54 pm |
| Gigabit Ethernet connector | June 13, 2005, 11:05 am |
| Gigabit Ethernet connector | June 13, 2005, 12:17 pm |
| Linksys SRW2016/24 gigabit? | September 8, 2005, 4:49 pm |
| Gigabit Ethernet addition to LAN | January 19, 2006, 12:23 pm |
| Does Server need new Gigabit adapter? | February 1, 2006, 1:07 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> neighboroughs)
> + 802.1q vlans
> + at leasr snmp v2
> Thanks,
> Matt
