Ethernet LAN Full Duplex and Hub
Subject Author Date
Full Duplex and Hub Benjamin M. Stocks 04-13-06
|--> Re: Full Duplex and Hub glen herrmannsf...04-13-06
---> Re: Full Duplex and Hub Robert Redelmei...04-14-06
| ---> Re: Full Duplex and Hub q_q_anonymous@y...04-23-06
| | `--> Re: Full Duplex and Hub Robert Redelmei...04-23-06
| | ---> Re: Full Duplex and Hub Robert Redelmei...04-23-06
| `--> Re: Full Duplex and Hub glen herrmannsf...04-23-06
Posted by Benjamin M. Stocks on April 13, 2006, 5:53 pm
Greetings all,
I've searched the archive but did not find the answer to this question:
if I have exactly 2 stations on a hub, is there any reason they cannot
use full duplex? If I understand logically how the hub works for
exactly 2 stations it should be the same as a cross over cable, right?
This is not for some real issue, more an intellectual curiosity that
came to me.
Thanks,
Ben
Posted by glen herrmannsfeldt on April 13, 2006, 7:41 pm
> Greetings all,
While 'hub' is often used in place of 'repeater', in the more general
sense, and often as found for sale, it includes switches.
In normal operation a repeater will detect collisions on any
port and properly signal that collision on all ports. There
is usually only one datapath in the internal logic, and only
enough buffer for a small number of bits.
A repeater will always run half duplex, even when only two stations
are active.
A switch will normally negotiate half or full and operate in
that mode the whole time.
-- glen
Posted by Stuart Robinson on April 14, 2006, 3:01 am
> came to me.
Regardless of the confusion that often occurs between hub and switch, I
think I see the point your making.
If you assuming that 2 stations connected as if they were on a swap over
cable, will not experience collisions, then you would be wrong.
Stuart.
Posted by Robert Redelmeier on April 14, 2006, 10:00 am
No. A hub has only one channel, like coax. So cannot do full duplex.
A crossover cable has two channels.
-- Robert
Posted by q_q_anonymous@yahoo.co.uk on April 23, 2006, 9:10 am
> -- Robert
Agreed.
There are some wrong answers here, but I think you and albert have it.
I guess that if a comp tries to send while it's receiving(i..e. acts
full duplex) , then it'll prob cause a collision in the hub, propagated
to all comps, but undetected by comps 'cos they're running full duplex.
Similar ThreadsPosted
10M full forced port connected to 100M full Duplex port March 25, 2006, 1:49 am
Full Duplex and Hub April 13, 2006, 5:53 pm
hub in full duplex May 26, 2006, 4:45 am
Full and half duplex. August 9, 2004, 12:34 am
No. of Full Duplex Links ? November 18, 2004, 5:35 am
collisions on a 100% full duplex May 18, 2006, 5:34 am
100 mb Full duplex on fiber connection August 2, 2005, 3:12 pm
how switches work - collision-free / full-duplex March 23, 2007, 9:33 am
Cut through and Half duplex November 20, 2007, 4:10 pm
Switch behavior when MAC table full March 11, 2005, 5:12 am
10BaseT Half Duplex Switch? July 27, 2004, 5:11 pm
10Gbit Ethernet Half-Duplex February 11, 2005, 1:39 pm
Switch / Server - speed / duplex February 28, 2007, 10:01 pm
Looking for half duplex simulation algorithm June 7, 2007, 8:27 am
A GbE device not able to forward full-rate odd-byte frames November 2, 2005, 6:47 pm
