Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by olafsnackjp on November 8, 2004, 10:32 am
Please log in for more thread options Ethernet. Q: In Ethernet bus transmission, sender needs to monitor the line for collision signal after sending message. If the length of backbone is 500 meters and the transmission speed is 250 meters per second, how many seconds must the sender monitor the line for collision signal? Why? Urgent help needed & deeply appreciated. Thks! :lol: *-----------------------* Posted at: www.GroupSrv.com *-----------------------* | |||||||||||||||||||
Posted by James Knott on November 8, 2004, 1:29 pm
Please log in for more thread options Someone looking for help with homework? The answer is contained in your text book, among many other sources. Also, that must be real crappy cable, if it's propogation rate is only 250 M/s. Perhaps they're using two cans and a string. ;-) | |||||||||||||||||||
Posted by Robert Redelmeier on November 8, 2004, 4:46 pm
Please log in for more thread options > Q: In Ethernet bus transmission, sender needs to monitor
> the line for collision signal after sending message. If > the length of backbone is 500 meters and the transmission > speed is 250 meters per second, how many seconds must the > sender monitor the line for collision signal? Why? LOL! Sounds like homework. Small clue -- propagation speed is closer to 2e8 m/s . Think about it for yourself a bit. That's what homework is designed to do. -- Robert | |||||||||||||||||||
Posted by J. Clarke on November 9, 2004, 8:51 am
Please log in for more thread options olafsnackjp wrote:
> Hi newbie here. Would like to seek help on this question regding
> Ethernet. > > Q: In Ethernet bus transmission, sender needs to monitor the line for > collision signal after sending message. If the length of backbone is > 500 meters and the transmission speed is 250 meters per second, how > many seconds must the sender monitor the line for collision signal? > Why? > > Urgent help needed & deeply appreciated. I've seen several answers posted to your earlier post of this same question. Nagging people will just get you flamed. > Thks!
> :lol: > *-----------------------* > Posted at: > www.GroupSrv.com > *-----------------------* -- --John Reply to jclarke at ae tee tee global dot net (was jclarke at eye bee em dot net) | |||||||||||||||||||
| Similar Threads | Posted |
| Ethernet bus transmission (urgent!) | November 8, 2004, 10:32 am |
| [URGENT]: Cal. Buffer Size based on User i/p Bandwidth In 1Gbps 802.3 | June 30, 2008, 1:05 am |
| Long Range Ethernet transmission over twisted-pair cable | April 12, 2006, 6:14 am |
| Pause Frame transmission | May 19, 2006, 7:05 pm |
| USB Ethernet controllers that use the ASIX AX88772 or AX88172 USB-Ethernet bridge devices | August 19, 2005, 7:04 pm |
| Wither simple ethernet-ethernet routers? | October 18, 2004, 11:06 pm |
| ethernet frequency and power on ethernet | October 25, 2004, 4:04 am |
| Difference between Ethernet 2 and 802.3 Frame per the Ethernet FAQ | July 28, 2006, 9:02 am |
| Ethernet over T1 (Ethernet over WAN...) | October 17, 2004, 4:15 am |
| Ethernet II | November 15, 2004, 12:50 am |
| ethernet hub | April 27, 2006, 2:44 am |
| WAN Ethernet | May 2, 2006, 4:20 pm |
| Ethernet TAP | July 30, 2007, 12:28 am |
| RS232 over Ethernet | July 20, 2004, 7:28 pm |
| Ethernet / ethereal ? | September 25, 2004, 11:48 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Ethernet.
