Ethernet LAN Ethernet Switch -- Managed versus Unmanaged
Subject Author Date
Ethernet Switch -- Managed versus Unmanaged gigiwk 01-25-07
Posted by on January 25, 2007, 3:33 pm
I'm designing an Ethernet Switch and one of the requirements is that
the IP address of the device be fixed to a port, i.e port 1 would
always have IP XYZ, can this be done with an unmanaged ethernet switch?
Thanks for the help.
GC
Posted by Walter Roberson on January 25, 2007, 4:46 pm
If you are designing the switch, you can put in whatever restriction
you want. That point would seem obvious enough that I feel I must
be misunderstanding the question.
Layer 2 ethernet switches don't -need- IP addresses at all.
There have, historically, been quite a few layer 2 switches that
had no controls, or were controlled via a serial port.
For network management purposes, it is -convenient- to be able to
ping a layer 2 switch as part of probing network health, but it isn't
a necessity. There are a lot of other -convenient- controls that
one can also provide; people have tried a large number of such
controls and the core set of what is "really nice to have" on a layer 2
switch is a set of facilities commonly known as a "managed switch".
It is by no means unknown for a layer 2 switch to offer some level
of configuration control only through a dedicated access method,
such as restricted to a certain ethernet port. On the whole, though,
most of the time these days there just isn't any point on putting
in such a restriction. The modern version of the restriction is perhaps
to allow a VLAN to be designated as the "management VLAN", and then
to allow whatever convenient ports to be part of that particular VLAN.
A layer 2 switch does not need to send its IP address out for any
layer 2 function such as Spanning Tree.
Posted by Rick Jones on January 25, 2007, 5:23 pm
> switch?
if the switch is unmanaged, there is no reason to be able to contact
the switch itself. that suggests it is not possible to assign an IP
to any port on the switch.
similarly, if you meant to ask that only a system with IP XYZ could be
connected to a specific port, an unmanaged switch would not have any
means onboard to verify/configure such a thing.
rick jones
oxymoron n, Hummer H2 with California Save Our Coasts and Oceans plates
these opinions are mine, all mine; HP might not want them anyway... :)
feel free to post, OR email to rick.jones2 in hp.com but NOT BOTH...
Posted by developers@thuk.co.uk on January 29, 2007, 5:29 am
On Jan 25, 8:33 pm, gig...@gmail.com wrote:
> Hi,
No
By defination an unmanged switch wont do that
Similar ThreadsPosted
Ethernet Switch -- Managed versus Unmanaged January 25, 2007, 3:33 pm
Ethernet Switch -- Managed versus Unmanaged January 28, 2007, 1:43 pm
16 port unmanaged switch April 15, 2007, 4:22 pm
Managed Ethernet Field Switch Provides Support for Tarrifed Wireless and Fiber-to-Premises Applications June 21, 2005, 3:06 pm
Managed Switch: help me understand October 11, 2004, 4:55 pm
small managed switch HW recommendations? February 10, 2005, 3:40 pm
Partition network (managed switch?) December 17, 2005, 12:46 pm
Simple (I think?) Managed Switch Setup August 15, 2006, 9:56 pm
help me decide wich managed switch to buy... January 17, 2007, 7:37 am
Managed gigabit switch as router..? August 6, 2007, 7:43 am
Assign static IPs to port of a managed switch June 24, 2005, 1:42 pm
Managed Gigabit Switch with MAC address filtering July 15, 2005, 2:29 am
Cisco vs. Netgear: 24 port gigabit managed switch February 10, 2006, 4:44 pm
Gigabit Flexibility with Magnum 6K32T Managed Switch from GarrettCom, Inc. August 30, 2005, 3:21 pm
cascading unmanaged switches August 7, 2004, 12:04 pm
