Ethernet LAN Ethernet PCS question.
Subject Author Date
Ethernet PCS question. Pranay 06-04-08
Posted by Pranay on June 4, 2008, 5:45 am
I designing an Elastic buffer for Ethernet, I would like to insert/
delete I1 and I2 characters.
I1 = K28.5 & D5.6,
I2 = K28.5 & D16.2
I would like to know if I can delete/insert a part of the I1/I2
character? For example, can I just insert/delete
K28.5 character or should I insert/delete k28.5 and D character as
well?
Normal sequence would be KDKDKDKDKD
After insertion it would be KDKDKKDKDK
After deletion it would be KDKDDKDKDK
is this OK?
My second question is
The 8B/10B encoder would encode the 8B data to either a +ve or a -ve
disparity 10B data.
So is it OK to transmit only I1 or only I2 all the time irrespective
of the current running disparity?
Because the current running disparity would be corrected by the 8B/10B
encoder.
Thanks,
-Pranay.
Posted by Marris on June 7, 2008, 3:29 pm
If you are intending to transmit the data stream over the physical layer
then you need to maintain the kdkdkd pattern. Normally though elastic
buffers are implemented in the PHY receiver and the symbols are converted to
GMII idle before being sent to the MAC. In this case you can insert or
delete a single byte.
Regarding you second question, I do not have the spec in front of me but it
clearly specifies which idle pattern should be sent. One is used to correct
disparity at the end of frame and the other is then sent continuosly.
> Hi,
> I1 = K28.5 & D5.6,
> I2 = K28.5 & D16.2
> well?
> is this OK?
> disparity 10B data.
> encoder.
> Thanks,
> -Pranay.
Similar ThreadsPosted
Ethernet PCS question. June 4, 2008, 5:45 am
Very Basic Ethernet Question January 1, 2007, 12:35 pm
question on Ethernet Devicedriver January 3, 2008, 1:12 am
STP question October 29, 2004, 1:59 pm
a question about STP 802.1d December 7, 2004, 3:03 pm
NAT question... January 21, 2005, 5:07 am
Question regarding 802.1x March 2, 2005, 7:32 pm
Re: A question for the NG December 11, 2006, 1:44 pm
Re: A question for the NG December 11, 2006, 5:58 pm
Monitoring question! July 30, 2004, 5:50 pm
a question about igmp September 15, 2004, 1:36 am
eternet question October 15, 2004, 6:52 pm
A question about 802.1d based CoS October 20, 2004, 1:04 am
simple question October 28, 2004, 4:58 pm
CSMA\CD Question November 15, 2004, 10:37 am
