Ethernet LAN Easily add 4 Gb/s Ethernet link to FPGA systems for control & data transfer
Subject Author Date
Easily add 4 Gb/s Ethernet link to FPGA systems for control & data transfer James Ma 06-07-06
Posted by James Ma on June 7, 2006, 11:54 am
Add 4 Gb/s Ethernet links to FPGA systems easily & at low cost.
High bandwidth, low latency control & data transfers.
Low gate count & low pin count.
Define your own protocol. No TCP/IP/UDP processing required.
Connection through standard switches or direct to PCs.
Simple & easy. No driver programming.
www.chipethernet.com
Similar ThreadsPosted
Easily add 4 Gb/s Ethernet link to FPGA systems for control & data transfer June 7, 2006, 11:54 am
Fastest way to transfer data from one computer to another September 17, 2004, 3:45 pm
Unidirectional Low-Level Data-Pattern On Ethernet Link May 26, 2007, 12:24 am
FPGA based Ethernet network analyzer - full wire speed, programmable February 10, 2006, 9:38 pm
Cisco Systems Equipment November 29, 2004, 5:38 pm
Systems can be 1-3 kms apart; 1 or multiple LANs? April 2, 2007, 7:16 am
Who can beat down Microsoft in the embedded systems market? October 8, 2004, 4:25 am
We Buy and Sell New, Used, Refurbished and New Open Box Cisco Systems, Extreme Networks, F5 Networks and Compaq equipment at up to 90% off list! October 18, 2006, 4:25 pm
Ethernet and Flow Control June 30, 2006, 4:34 pm
Problem with PAUSE frames ethernet flow control September 25, 2008, 7:09 am
Is Ethernet The Right Solution For Your Data Network? October 2, 2007, 7:48 pm
are flow control and half-duplex support mandatory for gigabit Ethernet? December 8, 2006, 10:29 am
Data width change in opencores Ethernet MAC October 13, 2005, 2:59 am
Ethernet requirement for Data rate:100 Mbps, Distance:2-3 km September 12, 2005, 5:54 am
file transfer speed in a network October 11, 2006, 4:45 am
