Ethernet LAN Crossover function in the standard.
Subject Author Date
Crossover function in the standard. Trebor Mushroom 06-23-08
Posted by glen herrmannsfeldt on July 1, 2008, 8:17 am
Rich Seifert wrote:
(snip, I wrote)
>>and to absolutely positively guarantee that the signal
>>is balanced. Maybe you could do that with a ferrite ring,
>>but then that is somewhat related to a transformer.
> To the extent that you mean "the transformer takes out any common mode
> (e.g., DC offset) in the signal", then you are correct. However, if the
> signal has short-term imbalance (e.g., asymmetrical high/low times), the
> transformer will not correct the problem.
No common mode is what I meant. Some common mode signals will
be due to differences in the two drivers.
Do they also put electrostatic shielding on the transformer to
remove capacitive coupling between the windings?
-- glen
Posted by Rich Seifert on July 1, 2008, 10:29 am
> Rich Seifert wrote:
> (snip, I wrote)
Generally not in that type of transformer. The windings are
close-coupled (typically wound as a pair, and sometimes even a twisted
pair); capacitive coupling is not always a detriment in a signal
transformer application.
Rich Seifert Networks and Communications Consulting
21885 Bear Creek Way
(408) 395-5700 Los Gatos, CA 95033
(408) 228-0803 FAX
Send replies to: usenet at richseifert dot com
Similar ThreadsPosted
Crossover function in the standard. June 23, 2008, 4:34 pm
standard for auto-negotiation May 24, 2007, 12:57 pm
Can a standard NIC be triggered to send an electrical signal? August 30, 2005, 8:28 am
More Than One Fiber Optic 100 Megabit Ethernet Standard? June 30, 2007, 12:28 am
Has anyone ever seen a crossover AUI cable? May 20, 2005, 6:39 am
Is there anybody here having IEEE's DSRC/WAVE 1609 standard documents? February 20, 2008, 8:55 am
Problem with Crossover Cable August 28, 2005, 2:18 pm
Crossover Vs. Patch Cables March 9, 2006, 11:15 am
Is there such a thing as an "SC Crossover" coupler or cable September 24, 2004, 9:07 pm
LF: Crossover Ethernet Cable 25 feet August 25, 2006, 3:27 pm
802.3ad Link Aggregation between two hosts using crossover cables January 24, 2005, 11:23 am
