Ethernet LAN Connect cat 2950SX to Procurve 3400cl
Subject Author Date
Connect cat 2950SX to Procurve 3400cl teo 01-12-07
Posted by teo on January 12, 2007, 2:58 am
Hi
I have an Procurve 3400cl installed which has an option of 4 mini-gbics
ProCurve Gigabit-LH-LC Mini-GBIC (J4860B)
ProCurve Gigabit-LX-LC Mini-GBIC (J4859B)
ProCurve Gigabit-SX-LC Mini-GBIC (J4858B)
Recently I bought, from a promo, two cisco 2950SX, which have 2 fixed
1000Base-SX ports.
Can I connect these two switches to the procurve?
Cisco installation manual says that
"You can connect a 100BASE-FX or 1000BASE-SX port to an SC or ST port
on a target device by using one of the MT-RJ fiber-optic patch cables"
Thank you.
Teo
Posted by on January 15, 2007, 5:47 pm
The J4858B ProCurve SX LC mini GBIC will work on SX fibre using LC
connections up to 550m depending on cable used. Your 3400 will
communicate to the Cisco 2950SX through the above mentioned GBIC. if
the Cisco switch has SC connectors you will need SC - LC patch cables
to convert.
Hope this helps
Jez
teo wrote:
> Hi
> 1000Base-SX ports.
> Thank you.
> Teo
Similar ThreadsPosted
Connect cat 2950SX to Procurve 3400cl January 12, 2007, 2:58 am
Foundry vs HP Procurve July 5, 2005, 6:25 pm
HP Procurve switches July 28, 2004, 11:48 pm
Procurve and redundancy. February 22, 2006, 3:28 pm
Traffic filtering on HP Procurve November 22, 2007, 10:54 am
Bridging VLANs on an HP ProCurve 2626 August 31, 2005, 7:27 pm
procurve 2824 noise level June 17, 2006, 9:55 am
HP ProCurve Switch Gigabiit Stackiing Kit (J4116A) September 12, 2004, 4:24 pm
Procurve 2824 and 2650 with IBM Cabling system (ICS) November 17, 2004, 6:56 am
HP Procurve 2512 switch have multiple trunks? March 9, 2005, 5:12 pm
Help configuring VLANs on HP Procurve 2824 switch May 24, 2007, 3:06 pm
How to connect to a ftp server with a port of not 21? November 26, 2004, 11:53 pm
Connect 2 router linksys together February 14, 2005, 11:51 pm
connect to gigabit switches January 17, 2008, 11:44 am
Can you connect two gigabit fibre NICs together? August 6, 2006, 6:57 am
