Ethernet LAN Cisco 3700, SMC TigerSwitch, Linux and VLAN Problems
Subject Author Date
Cisco 3700, SMC TigerSwitch, Linux and VLAN Problems rayvd 06-02-06
Posted by on June 2, 2006, 12:44 am
| FastEth0/0 (WAN)
| Cisco 3700 |
FastEth0/1 | | SMC TigerSwitch |
FastEth0/1.1 Port 1 | Port 23
dot1Q 1 native |
192.168.100.1/24 +-------+
FastEth0/1.2 |
dot1Q 2 | eth1
192.168.75.17/30 +-------+ 192.168.75.18/30
| Linux |
I'm trying to get VLAN tagging set up with a Cisco 3700 router, an SMC
TigerSwitch 6724AL2 and a Linux box. The layout is as above.
I have my VLAN configuration configured as follows on the TigerSwitch:
(This is an 802.11Q configuration)
vlan database
vlan 1 name DefaultVlan media ethernet state active
vlan 2 name RayVlan media ethernet state active
interface ethernet 1/1
switchport native vlan 1
switchport mode trunk
switchport allowed vlan add 1-2 tagged
interface ethernet 1/23
switchport allowed vlan add 1-2 untagged
switchport native vlan 2
interface vlan 1
ip address 192.168.100.2 255.255.255.0
>From what I understand packets leaving the Cisco destined for
192.168.75.18 should be tagged for VLAN 2. The SMC switch should send
the packet out Port 23 and remove the VLAN tagging since the port is
configured as untagged.
Packets coming in from the Linux box into Port 23 and destined for
192.168.75.17 should be tagged with VLAN 2 because of the "native vlan
2"
configuration option on the port (basically any untagged packets are
tagged for VLAN 2). The switch should send this packet through Port 1
and the Cisco sends it to the correct subinterface because of the VLAN
tag.
However, traffic is not passing as I expect it go. If I run a ping
from
the Cisco to 192.168.75.18 while running a tcpdump on the Linux box's
eth1, I don't see the ICMP packets nor do I even see any ARP requests.
Can anyone see anything obviously wrong with my setup? Maybe I have
something conceptually wrong.
Thanks,
Ray
Similar ThreadsPosted
Cisco 3700, SMC TigerSwitch, Linux and VLAN Problems June 2, 2006, 12:44 am
HP/Cisco Vlan fun January 9, 2008, 10:45 am
IGMP for Linux November 3, 2004, 3:09 pm
Going Offline with XP & Linux on same hub August 3, 2006, 12:11 pm
D-LINK DFE 530TX+ with LINUX July 10, 2006, 10:50 am
Fiber card in promiscuous mode under linux June 13, 2007, 5:26 am
VIA VT6102 Rhine-II + RealTek RTL8139C : file transfer hangs on Linux July 1, 2005, 6:36 pm
Dialup problems November 3, 2004, 9:14 am
switch problems July 7, 2006, 4:31 pm
AT-WCP200G wireless problems February 13, 2006, 12:46 pm
College ethernet switch problems October 3, 2005, 1:01 am
Ethernet Intermittent Connectivity Problems November 15, 2005, 5:10 pm
Latency and broadcast problems on ethernet lan January 8, 2006, 10:16 am
Monitoring switches for performance & problems October 19, 2007, 2:54 am
Problems with synchronization and clock recovery cause errors like... January 8, 2006, 5:49 pm
