Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Al Dykes on May 13, 2005, 8:13 pm
Please log in for more thread options Is there a linksys or similar cheapo dsl home router that can use DHCP to assign static IPs based on requesting MAC address ? -- a d y k e s @ p a n i x . c o m Don't blame me. I voted for Gore. | |||||||||||||||||||||||||
Posted by Dana on May 13, 2005, 4:37 pm
Please log in for more thread options The only way to get a static address from a DSL provider is to request one from your provider. >
> -- > a d y k e s @ p a n i x . c o m > > Don't blame me. I voted for Gore. | |||||||||||||||||||||||||
Posted by Al Dykes on May 13, 2005, 8:23 pm
>> Is there a linksys or similar cheapo dsl home router that can use DHCP >> to assign static IPs based on requesting MAC address ? >
>The only way to get a static address from a DSL provider is to request one >from your provider. >>
>> -- >> a d y k e s @ p a n i x . c o m >> I'm asking the DHCP server in the SOHO router to assign addresses. ou're think of NAT. -- a d y k e s @ p a n i x . c o m Don't blame me. I voted for Gore. | |||||||||||||||||||||||||
Posted by Dr. Anton T. Squeegee on May 14, 2005, 9:03 am
> >> Is there a linksys or similar cheapo dsl home router that can use DHCP > >> to assign static IPs based on requesting MAC address ? > >
> >The only way to get a static address from a DSL provider is to request one > >from your provider. > >>
> >> -- > >> a d y k e s @ p a n i x . c o m > >> >
> I'm asking the DHCP server in the SOHO router to assign > addresses. ou're think of NAT. I've seen the feature to assign static IP's from the router's internal DHCP side, based on MAC address, in D-Link products. While I wouldn't (now) recommend D-Link to my worst enemy, I would not be at all surprised if better makes, such as Netgear, also have the capability. Suggestion: Many manufacturers make their equipment user manuals freely available for download, no matter if you already own the unit or not. You would probably do well to grab such, and check the setup instructions for the device's internal DHCP feature (if any -- some few don't have it). Happy hunting. -- Dr. Anton T. Squeegee, Director, Dutch Surrealist Plumbing Institute. (Known to some as Bruce Lane, ARS KC7GR, kyrrin (a/t) bluefeathertech[d=o=t]calm -- www.bluefeathertech.com "If Salvador Dali had owned a computer, would it have been equipped with surreal ports?" | |||||||||||||||||||||||||
Posted by on May 14, 2005, 11:33 pm
>internal DHCP side, based on MAC address, in D-Link products. > > While I wouldn't (now) recommend D-Link to my worst enemy, I would >not be at all surprised if better makes, such as Netgear, also have the >capability. I was going to say exactly that, Verizon's FIOS router is a D-Link DI-624 which has the Static DHCP feature, but I really hate D-Link, and I've added another for a firewall between me and them. Linksys routers don't seem that have that feature, but I'm having other Linksys problems and am about to try another vendor (probably Netgear). | |||||||||||||||||||||||||
| Similar Threads | Posted |
| Are there any home DSL routers that can allocate static IP numbers ? | May 13, 2005, 8:13 pm |
| Ethernet Braoadband connection to home, assigning static private IP addr? | May 21, 2005, 12:14 pm |
| Connecting two routers in home environment | January 21, 2007, 10:54 am |
| WAN static IPs to LAN static IPs routing question | April 2, 2006, 7:06 pm |
| Static route or NAT | January 9, 2008, 2:42 am |
| Comcast static IPs through router | January 15, 2007, 6:06 pm |
| Assign static IPs to port of a managed switch | June 24, 2005, 1:42 pm |
| static routing in addition to DHCP on my router. | January 25, 2006, 11:47 pm |
| Linksys Routers | April 4, 2005, 1:14 pm |
| uplinking routers | August 6, 2005, 1:29 pm |
| Routers - Need your opinion | March 14, 2006, 2:37 am |
| connecting two wireless routers | January 20, 2005, 10:53 am |
| SOHO routers with 10/100 WAN ports? | April 8, 2005, 11:21 am |
| Cascading Wireless/Wired Routers | September 15, 2005, 1:20 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
