Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Emtech on September 7, 2005, 9:15 pm
Please log in for more thread options Hi Has anybody run Ethernet (10-100 Mega Bit) through any other connector, other than the standard RJ45? Thanks. | ||||||||||||||||||||||||||||||||||||||||
Posted by William P. N. Smith on September 7, 2005, 11:30 am
Please log in for more thread options Well, you can run it on anything that meets the Cat-5 specs (and some things that aren't, cf. the barbed wire discussion that comes up frequently), but then it isn't Ethernet, is it? What problem are you trying to solve? What's wrong with RJ45 in your application? There are (for instance) weathertight RJ45 connectors... | ||||||||||||||||||||||||||||||||||||||||
Posted by James Knott on September 7, 2005, 12:14 pm
"Emtech" <noaddress> wrote:
> Hi
> > Has anybody run Ethernet (10-100 Mega Bit) through any other connector, > other than the standard RJ45? Many PCMCIA ethernet cards use non-standard connectors, to connect the cable to the card. | ||||||||||||||||||||||||||||||||||||||||
Posted by sqrfolkdnc on September 7, 2005, 4:57 pm
Well, if you were doing a lot of wiring, and wanted to save money, I don't see why you couldn't use telephone type connectors. Just make sure you are consistant and get the polarity correct. You might want to avoid the center two contacts in case soembody plugged in a single line phone. And make the next two contacts be the inbound signal. I had thought of that so that I could wire my home with jacks, but then decided I didn't care if I just had wires coming out of holes in the walls. The official RJ45 wall jacks are a lot more expensive than phone jacks. | ||||||||||||||||||||||||||||||||||||||||
Posted by glen herrmannsfeldt on September 7, 2005, 8:42 pm
sqrfolkdnc wrote: > Well, if you were doing a lot of wiring, and wanted to save money, I
> don't see why you couldn't use telephone type connectors. Just make > sure you are consistant and get the polarity correct. You might want > to avoid the center two contacts in case soembody plugged in a single > line phone. And make the next two contacts be the inbound signal. I > had thought of that so that I could wire my home with jacks, but then > decided I didn't care if I just had wires coming out of holes in the > walls. The official RJ45 wall jacks are a lot more expensive than > phone jacks. If you really want to save money use four line phone jacks. That is, ones that aren't Cat 5 certified but will probably work fine for 10baseT, and if you are a little careful in wiring them at 100baseTX. -- glen | ||||||||||||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Alternative Ethernet Connector | September 7, 2005, 9:15 pm |
| Gigabit Ethernet connector | June 13, 2005, 11:05 am |
| Gigabit Ethernet connector | June 13, 2005, 12:17 pm |
| LAN extenders as alternative to Fiber | February 1, 2006, 5:17 am |
| USB Ethernet controllers that use the ASIX AX88772 or AX88172 USB-Ethernet bridge devices | August 19, 2005, 7:04 pm |
| Wither simple ethernet-ethernet routers? | October 18, 2004, 11:06 pm |
| ethernet frequency and power on ethernet | October 25, 2004, 4:04 am |
| Difference between Ethernet 2 and 802.3 Frame per the Ethernet FAQ | July 28, 2006, 9:02 am |
| Ethernet over T1 (Ethernet over WAN...) | October 17, 2004, 4:15 am |
| Ethernet II | November 15, 2004, 12:50 am |
| ethernet hub | April 27, 2006, 2:44 am |
| WAN Ethernet | May 2, 2006, 4:20 pm |
| Ethernet TAP | July 30, 2007, 12:28 am |
| RS232 over Ethernet | July 20, 2004, 7:28 pm |
| Ethernet / ethereal ? | September 25, 2004, 11:48 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
