Ethernet LAN ADSL Router connected to another router problem
Subject Author Date
ADSL Router connected to another router problem tommylux 09-28-06
Posted by tommylux on September 28, 2006, 3:34 am
I have brought a new ADSL ethernet router which has 4 ethernet ports.
When computers are connected directly to one of these ports, it works
without any problems.
When I use one of these ports to connect to another router (to host 5
computers), the computers on this router cannot connect to the
Internet, but can access the ADSL Router at 192.168.1.1
When you access 192.168.1.1, you can see all the computers from the
router under LAN settings
Any Ideas?
Thanks
Posted by tommylux on September 28, 2006, 11:19 am
any ideas guys?
> Any Ideas?
> Thanks
Posted by DLR on September 28, 2006, 1:33 pm
tommylux wrote:
> any ideas guys?
>> Any Ideas?
>> Thanks
Unless you understand what you're doing you should really only have 1
router and put a switch on one of the LAN ports to allow extra computers
/ devices to connect.
Stacking routers requires some special understanding and a router that
doesn't assume that 192.168.x.x will never need to get to the WAN port.
Posted by glen herrmannsfeldt on September 28, 2006, 1:53 pm
(snip)
Well, it shouldn't be that hard, but the usual instructions assume
192.168.1.x, which you can't use for both of them.
I do know that the Linksys WRT54G will run 10.x.y.z out its WAN
port. I have one between my home wireless net and home wired net.
Probably for the OP, though, stacking routers isn't needed.
Unless you really want separate subnets, you probably don't
want to do it.
-- glen
Posted by John Gray on September 28, 2006, 8:14 pm
> (snip)
>> 1 router and put a switch on one of the LAN ports to allow extra
>> computers / devices to connect.
>> that doesn't assume that 192.168.x.x will never need to get to the
>> WAN port.
> want to do it.
> -- glen
The WRT54G also has a setting on the Advanced Routing of Setup that may
help. Operating Mode is set to Gateway if it is attached to the
Internet(WAN) directly. If it is behind another router, set it to
Router Mode. I believe that way it will be on the same subnet, no
double NAT and everything on the LAN is available as well as access to
the Internet. I have no means to test this, but I do remember something
vaguely that it would work that way, and the help implies that. HTH
Similar ThreadsPosted
ADSL Router connected to another router problem September 28, 2006, 3:34 am
Sparkcom Adsl Router Driven Me Insane Help!!!!! November 18, 2004, 7:46 pm
Router connected to a switch. How does it work? December 3, 2004, 6:18 am
I have Netgear WLAN Router, how can I can howmany laptops can be connected simultaneously? December 14, 2004, 9:29 pm
Problem with 2 NAT boxes behind a router February 10, 2006, 12:23 pm
Netgear router setup problem January 7, 2006, 6:56 pm
STP, VLANs redundant router problem January 8, 2006, 8:13 am
Problem: 2 ISP, 1 router, 1 modem, 1 modem/router September 20, 2006, 10:14 am
Problem Accessing a Yahoo Server with SMC2804WBRP-G Barricade G Router March 6, 2006, 9:46 pm
I have PC->Router->DSL Modem->ISP, Does ISP Router learn the PC MAC address? April 25, 2005, 9:33 am
connecting Cisco router to Juniper router via e1 September 24, 2007, 6:18 am
is a NAT device/'home router' - a router? September 27, 2005, 8:10 pm
Cannot run behind router December 11, 2007, 11:54 pm
Router knows it all? January 14, 2008, 10:32 am
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
