Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by MEOW on July 25, 2006, 11:07 am
Please log in for more thread options Is it true that one can only use 3 channels in 802.11b even though the advertisement said you have 11 (FCC)? How would you like to get only 2 toppings with your Pizza even though you ordered 3? Oh and you pay for 3 as well. ;) Have a nice day! | |||||||||||||||||||||||||||||||
Posted by Walter Roberson on July 25, 2006, 1:16 pm
Please log in for more thread options Pretty much by definition, wireless is not a Local Area Network, so comp.dcom.lans.ethernet is not really the appropriate newsgroup for this matter. alt.internet.wireless would be a better newsgroup; I have added that newsgroup into the header. In any case, the answer is NO, that is not true. What is true is that each channel transmits on a frequency range centered around a base frequency, and that the frequency drop-off around the defined band is not required to be sharp. There is a power drop off in the channel on either side, more of a drop off for the channels beside those, more yet for the ones beside those. This leak of signal into the next channel does not make those other channels unusable: it adds noise to those other channels, making them -less- usable than if there were no overlap. The drop-off is defined such that by the third channel over, the interference is negligable. This situation leads to the following typical allocations, in increasing frequency: [band 1] - [detectable leak of channel 1] [band 2] - [noticable leak of channel 1] band 3 - [peak of channel 1] [band 4] - [noticable leak of channel 1] [band 5] - [detectable leak of channel 1] [band 6] - [detectable leak of channel 6] [band 7] - [noticable leak of channel 6] band 8 - [peak of channel 6] [band 9] - [noticable leak of channel 6] [band 10] - [detectable leak of channel 6] [band 11] - [detectable leak of channel 11] [band 12] - [noticable leak of channel 11] band 13 - [peak of channel 11] [band 14] - [noticable leak of channel 11] [band 15] - [detectable leak of channel 11] Someone did a study and found that this allocation was not -necessary- in order to get very good performance. Instead, they found that 4 transmitting channels could be used: [band 1] - [detectable leak of channel 1] [band 2] - [noticable leak of channel 1] band 3 - [peak of channel 1] [band 4] - [noticable leak of channel 1] + [detectable leak of channel 4] [band 5] - [detectable leak of channel 1] + [noticable leak of channel 4] band 6 - [peak of channel 4] [band 7] - [noticable leak of channel 4] [band 8] - [detectable leak of channel 8] [band 9] - [noticable leak of channel 8] band 10 - [peak of channel 8] [band 11] - [noticable leak of channel 8] + [detectable leak of channel 11] [band 12] - [detectable leak of channel 8] + [noticable leak of channel 11] band 13 - [peak of channel 11] [band 14] - [noticable leak of channel 11] [band 15] - [detectable leak of channel 11] You could shift the channel 8 activity down to channel 7 and shift the channel 11 activity down to channel 9, and still get very good performance, but there isn't any reason to do this unless you can transmit on channel 12 -- which *is* allowed in some areas of the world. In those areas, you can fit 5 useful channels in 12 allocated channels. > How would you like to get only 2
> toppings with your Pizza even though you ordered 3? Oh and you pay for 3 > as well. ;) It's more like, "You've asked for your tomato to be put on only 1/11th of the pizza, but we can't slice our tomato that small: we can put the bulk of it on 1/11th of the pizza, but some of it is going to end up on the next 1/11th, and a bit of it will even end up on the part after that. If you insist that none of your toppings overlap, then we can fit in 3 toppings, but if you are comfortable with a tiny bit of topping overlap, hardly even enough to taste, then we can fit in 4 toppings. And if you don't mind topping overlap, we can give you up to 11 different toppings. | |||||||||||||||||||||||||||||||
Posted by Mike on July 25, 2006, 1:26 pm
Walter Roberson wrote: <snip>
>> toppings with your Pizza even though you ordered 3? Oh and you pay for 3 >> as well. ;) >
> It's more like, "You've asked for your tomato to be put on only > 1/11th of the pizza, but we can't slice our tomato that small: we can > put the bulk of it on 1/11th of the pizza, but some of it is going to > end up on the next 1/11th, and a bit of it will even end up on the > part after that. If you insist that none of your toppings overlap, > then we can fit in 3 toppings, but if you are comfortable with a tiny > bit of topping overlap, hardly even enough to taste, then we can fit in > 4 toppings. And if you don't mind topping overlap, we can give you up > to 11 different toppings. I have 13 channels on my linksys WRT54GS (after a firmware update) , does this mean I will get 2 free toppings when I order pizza via domino's website? Mike | |||||||||||||||||||||||||||||||
Posted by Bill Kearney on July 25, 2006, 1:55 pm
> does this mean I will get 2 free toppings when I order pizza via > domino's website? Yeah, but they'd only be from the countries that let you use those frequencies... | |||||||||||||||||||||||||||||||
Posted by Jeff Liebermann on July 25, 2006, 2:28 pm
roberson@hushmail.com (Walter Roberson) hath wroth: >>Is it true that one can only use 3 channels in 802.11b even though the
>>advertisement said you have 11 (FCC)? >Pretty much by definition, wireless is not a Local Area Network, so
>comp.dcom.lans.ethernet is not really the appropriate newsgroup >for this matter. alt.internet.wireless would be a better newsgroup; >I have added that newsgroup into the header. > >In any case, the answer is NO, that is not true. He left off one important word. There are only 3 _non-overlapping_ channels. These are 1, 6, and 11. Channels in between tend to overlap these channels. DSSS (direct sequence spread spectrum) spectra is about 22Mhz wide. Each FCC channel is 5MHz wide, which means that wi-fi spectra occupies approximately 5 channels. Intel Wireless Hotspot Deployment Guide ftp://download.intel.com/business/bss/infrastructure/wireless/deployment/hotspot.pdf See Fig 6 and Fig 7 on Page 40. -- Jeff Liebermann jeffl@comix.santa-cruz.ca.us 150 Felker St #D http://www.LearnByDestroying.com Santa Cruz CA 95060 http://802.11junk.com Skype: JeffLiebermann AE6KS 831-336-2558 | |||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| 11 Channels | July 25, 2006, 11:07 am |
11 Channels
Yahoo!
Windows Live
del.icio.us
digg
Netscape
