For 100BASE-TX, the scrambler is defined with 18 lines of Verilog code. One could use some different circuit as long as it acts exactly the same as this. That code I include below. If you will refer to the part about 2/3 down in that defines the operation of the flipflops in the LFSR... oh, WTH let's quote it right here:
always @(posedge txclk) if (!txen) ds[10:0] = #1 11'h0; // reset key stream else if ( ds == 11'h0 ) ds[10:0] = #1 11'h1; // initialize key stream else ds[10:0] = #1 s[10:0]; // save current key stream
You will notice that when TXEN is deasserted, ie. between frames, the LFSR is forced to all zeros (11 bits of value 0 expressed in hex notation). When TXEN is reasserted, ie. a new frame starts, the LFSR will be forced to state 00000000001 by that all zeros detector on the line beginning "else if". After that it will step thru all of its 2047 normal states in sequence, repeating ad infinitum - until the end of frame when it will be forced to all zeros again by TXEN going away.
This means that between frames, the scrambler outputs a stream of all zeros. That means that the IDLE states issued by the 4b5b encoder between frames will go out on the twisted pair. That means that the cable will broadcast on a sharp tight 31.25 MHz, which means that the FCC will be all upset. But this thing was designed not to do that.
Where's the detail I'm missing here? How can this scrambler issue anything but all zeros between frames?
Wood
_______________________________________________________
Verilog code
IEEE 802.3 Clause 25 refers us to ANSI X3.263-1995. The ANSI standard was simply annexed to serve as Clause 25, with a very few adaptations in terminology. The ANSI standard gives us this Verilog code in Annex G:
G.2 Stream Cipher Scrambler Example // // STREAM CIPHER SCRAMBLER // // for bit serial data path with parallel key stream load // // txclk: transmit bit clock // txen: transmit enable (disables scrambler) // tnrzdin: unscrambled input NRZ data stream (plaintext) // tnrzdout:scrambled output NRZ data stream (ciphertext) // module scrambler (txclk, txen, tnrzdin, tnrzdout); input txclk, txen, tnrzdin; output tnrzdout; wire [11:0]s; // descrambler key stream reg [10:0]ds; // key stream register reg tnrzdout; // ciphertext output bit // // KEY STREAM // assign s[11:1] = ds[10:0]; // shift previous bits assign s[0] = s[11] ^ s[9]; // generate newest bit always @(posedge txclk) if (!txen) ds[10:0] = #1 11'h0; // reset key stream else if ( ds == 11'h0 ) ds[10:0] = #1 11'h1; // initialize key stream else ds[10:0] = #1 s[10:0]; // save current key stream // // CIPHERTEXT STREAM // always @(posedge txclk) tnrzdout = #1 s[0] ^ tnrzdin; // scramble NRZ data bit endmodule _______________________________________________________
