For reasons I have never understood, Cisco implements CLEI codes for telecom products using its TAN numbers (e.g., 800-08702-01). But customers end up buying cards using marketing part numbers like 15454-OC481LR1550. Occasionally you get a Cisco technical note that cross references these two types of numbering systems, but rarely are such notes comprehensive. Is there a place that Cisco publishes the relationships in a more comprehensive fashion than just technical notes?
For a specific case, I'm trying to determine which Cisco marketing part numbers are associated with these TANs:
800-08702-01 101601 SNTUDCWBAA CISCO SYSTEMS INC TRANSCEIVER TRANSCEIVER OC-48 LR 800-08702-02 101605 SNTUDCWBAB CISCO SYSTEMS INC TRANSCEIVER TRANSCEIVER OC-48 LR 800-08702-03 101606 SNTUDCXBAA CISCO SYSTEMS INC TRANSCEIVER TRANSCEIVER OC-48 LR 800-08702-04 107740 SNTUDCXBAB CISCO SYSTEMS INC TRANSCEIVER TRANSCEIVER OC-48 LR 800-08702-01* 264438 SNTUFCMBAA CISCO SYSTEMS INC TRANSCEIVER =101601 SNTUDCWBAA OTH 800-08702-02* 290457 SNTUFCMBAB CISCO SYSTEMS INC TRANSCEIVER =101605 SNTUDCWBAB DXDPossible candidates include:
15454-OC48LR1550A 15454-OC481LR1550A 15454-OC481LR1550 15454-OC48LR1550 15454-OC48LR1550WSome technical notes suggest that some of these TANs are shared across different marketing numbers, which only serves to grow my confusion on the issue, and to increase the need for a comprehensive cross reference.
