Cisco Systems what does this mean ? (inside,outside)
Subject Author Date
what does this mean ? (inside,outside) henrikcj 10-02-06
Posted by on October 2, 2006, 1:06 pm
Hey all.
Just have a quick question.
What is (inside,outside) in a command line like this?
static (inside,outside) tcp interface ...... ??
Regards Henrik
Posted by Walter Roberson on October 2, 2006, 2:17 pm
Those are interface names as given by nameif commands.
The meaning is that if a packet arrives at the interface named
first, going to the interface named second, and the packet matches
the specification given on the *end* of the line (not the middle!),
then the -source- IP address and port should be translated and the
destination IP and port should be left alone; and if a packet arrives
at the second interface named, headed for the first interface named,
and the packet matches the specification given in the *middle* of the
line, then the -destination- IP address and port should be translated
and the source IP and port should be left alone.
Posted by on October 2, 2006, 2:32 pm
But i still don't understand it. Why are there thies ( ) around
inside,outside) ?
So inside, outside in this will mean ..?
static (inside,outisde) tcp interface 3389 inside ip 3389 netmask
255.255.255.255
sorry i'm really trying to understand it :)
Posted by Walter Roberson on October 2, 2006, 2:52 pm
>inside,outside) ?
Why not? :) Cisco can invent any syntax it likes.
But in answer to the question: the interface pair is optional
in the syntax. The documentation is not clear, but the default
is probably (inside,outside) . The () tells the parser that the
interface pair was included.
255.255.255.255
That "inside ip" should be replaced with a single internal IP address
such as,
static (inside,outisde) tcp interface 3389 192.168.111.222 3389 netmask
255.255.255.255
The word 'interface' is a special keyword and means "the IP address of
the interface we are talking about".
Tne above means "If a packet arrives on the outside interface with
a destination IP which is the same as the PIX's outside IP, and the
packet is a TCP packet and the destination port is 3389, then the
packet should be rewritten so that the destination is port 3389
on address 192.168.111.222 of the inside interface.". It also means
(at the same time), "If a packet arrives on the inside interface
with a source IP of 192.168.111.222 and a source port of 3389
then the packet should be rewritten so that the source port is 3389
and the source IP is the IP of the PIX's outside interface."
The confusing part of this is that the first part after the )
corresponds to the specification for the -second- interface listed,
and the -second- part after the ) corresponds to the specification
for the -first- interface listed:
static (FIRST,SECOND) SECOND FIRST
Posted by on October 2, 2006, 4:02 pm
Thnaks for the answer :)
So can you help me with my next problem ?
I would like to setup af port forwording for my vnc. How do i do that ?
I got a pix 501
> >inside,outside) ?
255.255.255.255
> such as,
255.255.255.255
Similar ThreadsPosted
Configuring an inside nat group on inside interface April 10, 2006, 4:38 pm
Cisco 837 - how to set up Inside to Inside NAT for DNS resolution? May 23, 2006, 2:00 pm
PIX DMZ to the Inside. February 10, 2005, 6:33 pm
DNS inside DMZ September 30, 2005, 5:01 am
what does this mean ? (inside,outside) October 2, 2006, 1:06 pm
PIX 7.0 ACL inside/outside help ! December 22, 2006, 5:54 am
Inside to Inside NAT April 11, 2007, 5:08 pm
help with pix inside->outside + dmz->outside + inside->outside->dmz September 18, 2007, 9:57 pm
DNS inside the DMZ on an 877 January 1, 2008, 3:25 am
NAT INSIDE January 22, 2008, 7:50 pm
Ip NAT inside ... extendable. September 6, 2005, 5:45 am
nat (inside) 0, global and VPN September 22, 2005, 4:22 pm
PIX VPN to both DMZ and INSIDE segments October 18, 2005, 2:29 pm
ip nat inside and outside at the same time. November 8, 2005, 6:42 pm
NAT/PAT problem from inside November 30, 2005, 7:10 pm
