Watchguard / Safenet Client and Cisco VPN Client Compatible?
I have been using the Cisco VPN for quite some time with no issues. Recently we added a Watchguard Firebox in another location and have installed the Watchguard MUVPN Client, otherwise known as Safenet Client.
Ever since the install, I have not been able use the Cisco Client properly. If I disable the two Safenet Services, I get prompted for my user id and password and login to the Cisco concentrator and get an ip, etc. However I cannot ping anything on the network.
My workaround is to completely uninstall both clients and reinstall the Cisco by itself. This is not very practical.
If anyone know of a fix for this I would appreciate some input.
Thanks, Patrick
Patrick Dunnigan
