A WAN Link as below: HQ ( VLAN1) ----[ ] [ MetroEthernet ]----Remote [ Network ] site ( VLAN1 & VLAN2) HQ ( VLAN2) ----[ ]
Router configuration for both locations: ( VLAN1 or VLAN 2 )
interface GigabitEthernet0/1.xxx bandwidth 5000 encapsulation dot1Q xxxx ip address 10.10.yy.zz 255.255.255.252 ip flow ingress no ip mroute-cache ip ospf cost 10 traffic-shape rate 5000000 5000000 5000000 1000 !
Issue: Both VLAN1 & VLAN2 has not problem for OSPF routing, neighbor,,,,
VLAN1 is working perfectly, but VLAN2 can only ping/traceroute to the connected interface and can not ping to other interface even routes are found in the routing table.
Any hint for this issue ( configuration, IOS or ISP issue ) ? How to fix this problem ? and suggested steps/hints to find out the problem ?
Cheers
