Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by dspnyc on June 7, 2006, 10:30 am
Please log in for more thread options trying to solve an issue. environment: pix 515, running 6.3.3 issue: * I'm trying to make IPSEC/PPTP connections into the pix. * client can connect, recieves an address from "ip local pool vpn" * once connected, client cannot reach anything on 192.168.10.0/24 recent changes: * created specific ACLs for nonat, crypto & split tunnel. Same problem persists. thank you for any/all comments. sanitized conf is below. ----------------------------------------------------------------------- interface ethernet0 100full interface ethernet1 100full interface ethernet2 100full interface ethernet3 100full interface ethernet4 auto shutdown interface ethernet5 auto shutdown nameif ethernet0 outside security0 nameif ethernet1 inside security100 nameif ethernet2 failover security20 nameif ethernet3 dmz security20 nameif ethernet4 e4 security0 nameif ethernet5 e5 security0 hostname domain-name fixup protocol dns maximum-length 512 fixup protocol domain 53 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 no fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 no fixup protocol skinny 2000 no fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 no names access-list soc2800 permit ip host 216.74.163.199 host 65.197.254.5 access-list soc2800 permit ip host 216.74.163.199 63.108.175.0 255.255.255.0 access-list inside permit ip 192.168.0.0 255.255.0.0 host 192.168.12.1 access-list inside permit ip 192.168.0.0 255.255.0.0 host 192.168.12.2 access-list inside permit udp 192.168.0.0 255.255.0.0 host 216.74.163.194 eq ntp access-list inside permit udp 192.168.0.0 255.255.0.0 host 216.74.163.195 eq ntp access-list inside permit icmp any any echo access-list inside permit icmp any any unreachable access-list inside permit icmp any any source-quench access-list inside permit icmp any any time-exceeded access-list inside remark ###### allow ftp to ftp.lim.com access-list inside permit tcp 192.168.10.0 255.255.255.0 host 12.43.226.2 eq ftp access-list inside permit tcp host 192.168.10.80 any eq www access-list inside permit tcp host 192.168.10.80 any eq ftp access-list inside permit tcp host 192.168.10.80 any eq https access-list inside permit tcp host 192.168.10.80 any eq ssh access-list inside permit tcp host 192.168.10.80 any eq smtp access-list inside permit ip 10.0.0.0 255.255.0.0 host 192.168.12.1 access-list inside permit ip 10.0.0.0 255.255.0.0 host 192.168.12.2 access-list inside permit ip 192.168.0.0 255.255.0.0 10.0.0.0 255.255.0.0 access-list inside permit ip 192.168.0.0 255.255.0.0 192.168.0.0 255.255.0.0 access-list inside permit tcp host 192.168.10.80 any eq telnet access-list inside permit tcp host 192.168.10.157 any eq https access-list inside permit tcp host 192.168.10.156 any eq smtp access-list inside permit tcp host 192.168.10.156 any eq https access-list inside permit udp host 192.168.10.156 any eq ntp access-list inside permit udp host 192.168.10.157 any eq ntp access-list inside permit udp host 192.168.10.157 any eq domain access-list inside permit udp host 192.168.10.156 any eq domain access-list inside permit tcp host 192.168.10.157 any eq domain access-list inside permit tcp host 192.168.10.156 any eq domain access-list inside permit tcp host 192.168.10.199 any eq domain access-list inside permit udp host 192.168.10.199 any eq domain access-list inside permit tcp host 192.168.10.197 any eq domain access-list inside permit udp host 192.168.10.197 any eq domain access-list inside permit tcp 192.168.10.0 255.255.255.0 209.132.177.0 255.255.255.0 eq www access-list inside permit tcp 192.168.10.0 255.255.255.0 209.132.177.0 255.255.255.0 eq https access-list inside permit tcp 192.168.0.0 255.255.0.0 host 208.173.140.54 eq smtp access-list inside permit tcp host 192.168.10.199 host 192.88.69.69 eq ftp access-list inside permit tcp host 192.168.10.197 host 192.88.69.69 eq ftp access-list inside permit tcp host 192.168.10.185 any eq smtp access-list inside remark ##### allow all machines out to futuresource.com and xml.marketcenter.com on 4004 access-list inside permit tcp 192.168.10.0 255.255.255.0 any eq 4004 access-list inside remark ###### allow specific machines out access-list inside permit tcp host 192.168.10.185 any eq www access-list inside permit tcp host 192.168.10.185 any eq https access-list inside permit tcp host 192.168.10.200 any eq www access-list inside permit tcp host 192.168.10.201 any eq www access-list inside permit tcp host 192.168.10.200 any eq https access-list inside permit tcp host 192.168.10.201 any eq https access-list inside permit tcp host 192.168.10.200 any eq ftp access-list inside permit tcp host 192.168.10.201 any eq ftp access-list inside remark ###### LAN --> border network
access-list inside permit tcp 192.168.10.0 255.255.255.0 216.74.163.192
255.255.255.224 eq telnet access-list inside remark #### allw VPN local pool ips access-list inside permit ip 192.168.0.0 255.255.0.0 172.16.1.0 255.255.255.0 access-list outside permit icmp any any echo-reply access-list outside permit icmp any any unreachable access-list outside permit icmp any any time-exceeded access-list outside permit tcp any host 216.74.163.204 eq https access-list outside permit tcp any host 216.74.163.204 eq www access-list outside permit tcp any host 216.74.163.209 eq www access-list outside permit tcp any host 216.74.163.209 eq https access-list outside permit tcp any host 216.74.163.205 eq www access-list outside permit tcp any host 216.74.163.205 eq https access-list outside permit tcp any host 216.74.163.203 eq www access-list outside permit tcp any host 216.74.163.203 eq https access-list outside permit tcp any host 216.74.163.201 eq www access-list outside permit tcp any host 216.74.163.201 eq https access-list outside permit tcp any host 216.74.146.250 eq www access-list outside permit tcp host 63.145.12.27 host 216.74.146.250 eq ssh access-list outside permit tcp host 63.145.12.27 host 216.74.146.250 eq 10000 access-list outside permit tcp host 63.145.12.27 host 216.74.146.250 eq 8888 access-list outside permit esp host 12.146.1.11 host 216.74.146.244 access-list outside permit esp host 12.146.1.11 host 216.74.146.245 access-list outside permit tcp any host 216.74.163.202 eq 24 access-list outside permit tcp any host 216.74.146.244 eq ssh access-list outside permit tcp any host 216.74.146.245 eq ssh access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.10.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.11.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.12.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.13.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.20.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.21.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.22.0 255.255.255.0 access-list outside permit ip 10.0.0.0 255.255.0.0 192.168.23.0 255.255.255.0 access-list outside remark ##### deny below added per SOC incident 19319363 access-list outside deny tcp any host 67.85.186.115 access-list dmz permit udp 216.74.146.240 255.255.255.240 host 216.74.163.194 eq ntp access-list dmz permit udp 216.74.146.240 255.255.255.240 host 216.74.163.195 eq ntp access-list dmz permit icmp any any echo access-list dmz permit icmp any any unreachable access-list dmz permit icmp any any time-exceeded access-list dmz permit tcp host 216.74.146.250 host 24.213.162.100 eq smtp access-list dmz permit tcp host 216.74.146.250 any eq domain access-list dmz permit udp host 216.74.146.250 any eq domain access-list dmz permit tcp host 216.74.146.250 any eq ssh access-list dmz permit udp host 216.74.146.244 host 12.146.1.11 eq isakmp access-list dmz permit udp host 216.74.146.245 host 12.146.1.11 eq isakmp access-list dmz permit esp host 216.74.146.245 host 12.146.1.11 access-list dmz permit esp host 216.74.146.244 host 12.146.1.11 access-list dmz permit tcp host 216.74.146.245 host 192.168.10.57 eq 2036 access-list dmz permit tcp host 216.74.146.244 host 192.168.10.57 eq 2036 access-list dmz permit tcp host 216.74.146.244 host 192.168.10.57 eq ssh access-list dmz permit tcp host 216.74.146.245 host 192.168.10.57 eq ssh access-list dmz permit tcp host 216.74.146.245 host 192.168.10.55 eq 2036 access-list dmz permit tcp host 216.74.146.244 host 192.168.10.55 eq 2036 access-list dmz permit tcp host 216.74.146.244 host 192.168.10.55 eq ssh access-list dmz permit tcp host 216.74.146.245 host 192.168.10.55 eq ssh access-list 628broadway permit ip 192.168.0.0 255.255.0.0 10.0.0.0 255.255.0.0 access-list exovpn permit ip 172.16.1.0 255.255.255.0 192.168.0.0 255.255.0.0 access-list nonat permit ip 192.168.0.0 255.255.0.0 10.0.0.0 255.255.0.0 access-list nonat permit ip 192.168.0.0 255.255.0.0 172.16.1.0 255.255.255.0 pager lines 24 logging on logging timestamp logging standby logging trap debugging logging history informational logging facility 23 logging device-id hostname logging host outside x.x.x.x logging host inside x.x.x.x no logging message 302015 no logging message 302014 no logging message 302013 icmp permit any inside mtu outside 1500 mtu inside 1500 mtu failover 1500 mtu dmz 1500 mtu e4 1500 mtu e5 1500 ip address outside x.x.x.x 255.255.255.224 ip address inside 192.168.12.1 255.255.255.0 ip address failover 192.168.14.1 255.255.255.252 ip address dmz x.x.x.x 255.255.255.240 no ip address e4 no ip address e5 ip audit info action alarm ip audit attack action alarm ip local pool vpn 172.16.1.1-172.16.1.100 failover failover timeout 0:00:00 failover poll 15 failover ip address outside x.x.x.x failover ip address inside 192.168.12.2 failover ip address failover 192.168.14.2 failover ip address dmz x.x.x.x no failover ip address e4 no failover ip address e5 failover link failover no pdm history enable arp outside 216.74.163.193 0000.0c07.ac00 alias arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list nonat nat (inside) 1 192.168.10.0 255.255.255.0 0 0 nat (inside) 1 192.168.11.0 255.255.255.0 0 0 nat (inside) 1 192.168.12.0 255.255.255.0 0 0 nat (inside) 1 192.168.13.0 255.255.255.0 0 0 nat (inside) 1 192.168.20.0 255.255.255.0 0 0 nat (inside) 1 192.168.21.0 255.255.255.0 0 0 nat (inside) 1 192.168.22.0 255.255.255.0 0 0 nat (inside) 1 192.168.23.0 255.255.255.0 0 0 static (inside,outside) tcp 216.74.163.205 www 192.168.10.99 8022 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.205 https 192.168.10.99 8021 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.201 www 192.168.10.99 8002 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.201 https 192.168.10.99 8001 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.203 www 192.168.10.99 9002 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.203 https 192.168.10.99 9001 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.204 www 192.168.10.99 8032 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.204 https 192.168.10.99 8031 netmask 255.255.255.255 0 0 static (inside,outside) tcp 216.74.163.202 24 192.168.10.156 24 netmask 255.255.255.255 0 0 static (inside,dmz) 192.168.10.0 192.168.10.0 netmask 255.255.255.0 0 0 static (inside,dmz) 192.168.11.0 192.168.11.0 netmask 255.255.255.0 0 0 static (inside,dmz) 192.168.12.0 192.168.12.0 netmask 255.255.255.0 0 0 static (inside,dmz) 192.168.13.0 192.168.13.0 netmask 255.255.255.0 0 0 static (dmz,outside) 216.74.146.240 216.74.146.240 netmask 255.255.255.240 0 0 access-group outside in interface outside access-group inside in interface inside access-group dmz in interface dmz router ospf 100 network 192.168.12.0 255.255.255.0 area 0 log-adj-changes redistribute static subnets route outside 0.0.0.0 0.0.0.0 216.74.163.193 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ (inside) host 192.168.10.156 LehMePo23HHHee timeout 10 aaa-server TACACS+ (inside) host 192.168.10.157 LehMePo23HHHee timeout 10 aaa-server RADIUS protocol radius aaa-server RADIUS (inside) host 192.168.10.201 1p2o3i4u!!! timeout 10 aaa-server LOCAL protocol local aaa authentication telnet console TACACS+ aaa authentication ssh console TACACS+ aaa accounting include telnet inside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 TACACS+ aaa accounting include tcp/22 inside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 TACACS+ aaa accounting include tcp/22 outside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 TACACS+ aaa accounting include telnet outside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 TACACS+ no snmp-server location no snmp-server contact snmp-server community snmp-server enable traps floodguard enable sysopt connection permit-ipsec sysopt connection permit-pptp crypto ipsec transform-set kiodex esp-3des esp-md5-hmac crypto ipsec transform-set riptech esp-3des esp-md5-hmac crypto dynamic-map dynmap 10 set transform-set kiodex crypto map outside 1 ipsec-isakmp crypto map outside 1 match address 628broadway crypto map outside 1 set peer 24.213.162.102 crypto map outside 1 set transform-set kiodex crypto map outside 10 ipsec-isakmp crypto map outside 10 match address soc2800 crypto map outside 10 set peer 65.201.134.9 crypto map outside 10 set transform-set riptech crypto map outside 20 ipsec-isakmp dynamic dynmap crypto map outside client authentication RADIUS crypto map outside interface outside isakmp enable outside isakmp key ******** address x.x.x.x netmask 255.255.255.255 isakmp key ******** address x.x.x.x netmask 255.255.255.255 isakmp identity address isakmp policy 10 authentication pre-share isakmp policy 10 encryption 3des isakmp policy 10 hash md5 isakmp policy 10 group 2 isakmp policy 10 lifetime 86400 vpngroup exovpn address-pool vpn vpngroup exovpn dns-server 192.168.10.156 192.168.10.157 vpngroup exovpn wins-server 192.168.10.200 vpngroup exovpn default-domain kdx.int vpngroup exovpn split-tunnel exovpn vpngroup exovpn idle-time 900 vpngroup exovpn password ******** telnet timeout 10 ssh 192.168.10.0 255.255.255.0 inside ssh timeout 10 console timeout 0 vpdn group exo-pptp accept dialin pptp vpdn group exo-pptp ppp authentication mschap vpdn group exo-pptp ppp encryption mppe auto vpdn group exo-pptp client configuration address local vpn vpdn group exo-pptp client configuration dns 192.168.10.156 192.168.10.157 vpdn group exo-pptp client configuration wins 192.168.10.200 10.0.0.10 vpdn group exo-pptp client authentication aaa RADIUS vpdn group exo-pptp pptp echo 60 vpdn enable outside terminal width 80 | |||||||||||||||||||
Posted by =?iso-8859-1?q?BradReese.Com=A on June 7, 2006, 2:50 pm
Please log in for more thread options traffic are addressed on Cisco's: Resolving Microsoft Routing Problems on Cisco VPN Clients: http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_tech_note09186a00801b7615.shtml Hope this helps. Brad Reese BradReese.Com - Cisco Network Engineer Directory http://www.bradreese.com/network-engineer-directory.htm 1293 Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant Website: http://www.bradreese.com/contact-us.htm | |||||||||||||||||||
Posted by dspnyc on June 7, 2006, 3:32 pm
Please log in for more thread options thanks brad, but the same (windows XP, cisco Secure client 4.7) client
connects fine to another pix (that has a simpler config) I believe the problem lies in the ACLs, but not being a Cisco guru, i'm not 100% sure. BradReese.Com=AE - Leverage Your Cisco Network wrote: > Symptoms showing the VPN tunnel coming up, but the PC cannot pass
> traffic are addressed on Cisco's: > > Resolving Microsoft Routing Problems on Cisco VPN Clients: > > http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_tech_note0= >
> Hope this helps. > > Brad Reese > BradReese.Com - Cisco Network Engineer Directory > http://www.bradreese.com/network-engineer-directory.htm > 1293 Hendersonville Road, Suite 17 > Asheville, North Carolina USA 28803 > USA & Canada: 877-549-2680 > International: 828-277-7272 > Fax: 775-254-3558 > AIM: R2MGrant > Website: http://www.bradreese.com/contact-us.htm | |||||||||||||||||||
Posted by =?iso-8859-1?q?BradReese.Com=A on June 7, 2006, 7:51 pm
Please log in for more thread options One should use either access lists or conduits to permit inbound
traffic into the internal ( DMZ ) networks, but do not use both. At the end of every access list is an implicit "deny ip any any" statement. Therefore, if the access list does not explicitly permit inbound traffic, the traffic will be denied by default. For more help with access lists on the PIX you may wish to investigate Cisco's: Using nat, global, static, conduit, and access-list Commands and Port Redirection on PIX http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094aad.shtml Sincerely, Brad Reese Cisco Repair http://www.bradreese.com/cisco-big-iron-repair.htm | |||||||||||||||||||
Posted by dspnyc on June 14, 2006, 6:18 pm
Please log in for more thread options er...thanks --- i'm trying to allow traffic into the LAN, not DMZ.
BradReese.Com=AE - Leverage Your Cisco Network wrote: > One should use either access lists or conduits to permit inbound
> traffic into the internal ( DMZ ) networks, but do not use both. > > At the end of every access list is an implicit "deny ip any any" > statement. > > Therefore, if the access list does not explicitly permit inbound > traffic, the traffic will be denied by default. > > For more help with access lists on the PIX you may wish to investigate > Cisco's: > > Using nat, global, static, conduit, and access-list Commands and Port > Redirection on PIX > > http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note0= >
> Sincerely, > > Brad Reese > Cisco Repair > http://www.bradreese.com/cisco-big-iron-repair.htm | |||||||||||||||||||
| Similar Threads | Posted |
| vpngroup to pix515 (repost) | June 7, 2006, 10:30 am |
| vpngroup to pix515 (repost 2) | June 21, 2006, 3:58 pm |
| vpngroup to pix515 | May 18, 2006, 5:57 pm |
| Repost: VPN error? | September 5, 2006, 6:38 pm |
| REPOST: OSPF Database Help | September 6, 2006, 10:46 am |
| Extending the PDH/E1 from PBX to VoIP router (repost) | May 19, 2006, 11:35 am |
| PIX 6 ssh login with AAA doesn't set privilege level [REPOST] | January 4, 2008, 11:10 am |
| PIX - VPNgroup statistics. | February 9, 2006, 9:27 am |
| VPNGROUP password | September 22, 2006, 2:04 pm |
| How to log or account PIX vpngroup connections? | December 13, 2005, 5:05 am |
| VPNGROUP command help with PIX 506e | September 1, 2006, 12:32 pm |
| Cisco PIX 501 vpngroup user need to be assigned a static IP | February 5, 2007, 1:59 pm |
| How to rename a vpngroup in Cisco PIX 515e firewall | September 18, 2007, 12:50 pm |
| Help with DMZ on Pix515 | August 28, 2006, 5:03 am |
| 2 ISP on PIX515 | November 25, 2005, 5:03 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
